Iorifly 15 Posted May 29, 2015 Posted May 29, 2015 friends, I know it will insert features after the beta. However it is expected or is already in motion a version that supports the tvtunner? I miss in my series and movies.
xnappo 1611 Posted May 29, 2015 Posted May 29, 2015 We cannot integrate the Emby tuner stuff into Kodi. However Kodi supports the same back ends and Emby, so you should be able to use the native Kodi tuner stuff.
Iorifly 15 Posted May 29, 2015 Author Posted May 29, 2015 @@xnappo, I think you got me wrong. I'm talking about TvTunes addon. Sorry, I wrote wrong.
Iorifly 15 Posted May 29, 2015 Author Posted May 29, 2015 (edited) I checked the @@Angelblue05, this contact @rob_webset. I think we have reached a solution we will wait for the @@Angelblue05. Edited May 29, 2015 by Iorifly
Angelblue05 4132 Posted May 29, 2015 Posted May 29, 2015 Ahhh, yes TV Tunes. I figured the line that was preventing our addon from working with TV Tunes and reached out to Rob to see if a fix could be implemented in the official version. This should be coming soon Or you can also install the zip found here, until the official repo is updated: http://forum.kodi.tv/showthread.php?tid=214287&pid=2015639#pid2015639 To test. The only thing you need to make sure of, is to use a custom path to save your themes to. script.tvtunes-4.7.2b.zip 1
Iorifly 15 Posted May 29, 2015 Author Posted May 29, 2015 I downloaded version "script.tvtunes-4.7.2b.zip" but it does not need to update the addon Emby? I did not understand the part that you talk personalized way. It would be the kodi that changed? Line 608-609
Angelblue05 4132 Posted May 29, 2015 Posted May 29, 2015 You don't need to do any modifications, just install the zip to update the TV Tunes add-on. The custom path is a TV Tunes setting.
xnappo 1611 Posted May 29, 2015 Posted May 29, 2015 Ah - sorry! TVTunes not TVTuner! Yes @@Angelblue05 is all over that!
Iorifly 15 Posted May 29, 2015 Author Posted May 29, 2015 I did not find the option. It only has to set up the directory you are in, put my movies are in some hard drives .... Some admin could set the title of the topic?
Angelblue05 4132 Posted May 29, 2015 Posted May 29, 2015 (edited) So once you installed the zip, go to Addons > Enabled Add-ons > Video Add-ons > TV Tunes > Configure > Filesystem > Store tunes in a custom path > - Path: set a custom folder to save the themes to. Does this help? After that, any theme you get via TV Tunes will be saved in the custom path. Then enter your shows and enjoy themes playing. TV Tunes wiki: http://kodi.wiki/view/Add-on:TvTunes Edited May 29, 2015 by Angelblue05 1
Iorifly 15 Posted May 29, 2015 Author Posted May 29, 2015 (edited) I had done it. And this was my fear. I'll have to download all the issues again! For my themes already estam the folder of your movies Movie X> ThemaX.mp3 .... I'll have to download all the issues again, right? * I had found this way. Thank you for always having patience and willingness to help !! Edited May 29, 2015 by Iorifly
im85288 1493 Posted May 29, 2015 Posted May 29, 2015 You can get TV tunes to work with your existing theme music by turning on the option to use local paths in the emby settings. You will need to rebuild your database for it to pick up the changes. Then you can use TV tunes stored with your media 1
Angelblue05 4132 Posted May 29, 2015 Posted May 29, 2015 Yes as im85288 said, but we will keep looking to see if anything can be done on our side. For now, you can use the direct paths option. Also, are your current themes imported into Emby too? This might give me an idea. 1
Iorifly 15 Posted May 29, 2015 Author Posted May 29, 2015 Redo the database is no problem. And I use only direct play, do not do stream.
Angelblue05 4132 Posted May 29, 2015 Posted May 29, 2015 (edited) Yes, this is the option. @@Iorifly Can you confirm that the theme you have are imported into Emby too? (Do they play in the webclient too) Edited May 29, 2015 by Angelblue05 1
Iorifly 15 Posted May 29, 2015 Author Posted May 29, 2015 ALL RUNNING! Thank@@im85288 and @@Angelblue05 !!!!! Tvtuners functional, I will try in a moment in my mini mac 1
Angelblue05 4132 Posted May 30, 2015 Posted May 30, 2015 (edited) @@Iorifly Do you download your themes via Emby or via TV Tunes on Kodi, normally? Edited May 30, 2015 by Angelblue05
Iorifly 15 Posted May 30, 2015 Author Posted May 30, 2015 No. Unfortunately I can not search and download the tvtuners in kodi own. What I do is go on youtube and get the theme and download mp3.
Angelblue05 4132 Posted May 30, 2015 Posted May 30, 2015 Ok, that's good to know because I'm working on a solution to be able to play your Emby theme songs, without the need for direct paths. Sent from my iPhone using Tapatalk 1
Iorifly 15 Posted May 30, 2015 Author Posted May 30, 2015 @@Angelblue05, The important thing is not necessary to change the path where this theme. I would have to redo it. Using direct path is good because it did not have to change the locatio
Angelblue05 4132 Posted May 30, 2015 Posted May 30, 2015 Yea, but will not have to change location either, with what I'm working on. The problem with direct path is that it doesn't give us enough control for what needs to be done to be fully compatible with the Emby server. Anyway for now, you can use this solution Sent from my iPhone using Tapatalk
