twilightrazor 0 Posted May 29, 2015 Posted May 29, 2015 So I'm trying to use retroarch as an external player for my emulation need. When I pass what emby theater passes through the command prompt it works fine, but when i try to launch any rom trough emby theater it self it does not work please help me
Luke 42240 Posted May 29, 2015 Posted May 29, 2015 can you give more information? you are probably one of the first to try retroarch. we'd love to get that working, but we need you to roll up your sleeves a little.
twilightrazor 0 Posted June 23, 2015 Author Posted June 23, 2015 I would really love to use retroarch, it seems that the command window might need to stay open? Not really sure
astraldragon 7 Posted July 30, 2015 Posted July 30, 2015 (edited) I have attempted to use RetroArch with the client as well with no luck. I'd be willing to help debug this because I really like RetroArch (currently have it configured through Kodi) and would love to use it with this client. EDIT - I lied, I actually got it to work properly tonight. If you are still having issues twilightrazor maybe I can help you out. Edited July 31, 2015 by astraldragon
