medric 5 Posted May 27, 2015 Posted May 27, 2015 2015-05-26 21:27:54.5265 Debug - SessionManager: Disposing session controller PlayToController 2015-05-26 21:27:55.5736 Error - App: Error getting response from http://10.1.10.106:7676/smp_26_ *** Error Report *** Version: 3.0.5621.3 Command line: C:\Users\media\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\media\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\media\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe The request was aborted: The operation has timed out. System.Net.WebException at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) 2015-05-26 21:27:55.5736 Error - Dlna: Error updating device info for [TV] Home *** Error Report *** Version: 3.0.5621.3 Command line: C:\Users\media\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\media\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\media\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe The request was aborted: The operation has timed out. MediaBrowser.Model.Net.HttpException at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__1e.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsync>d__7.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Dlna.PlayTo.SsdpHttpClient.<SendCommandAsync>d__0.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Dlna.PlayTo.Device.<GetTransportInfo>d__84.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Dlna.PlayTo.Device.<TimerCallback>d__51.MoveNext() InnerException: System.Net.WebException The request was aborted: The operation has timed out. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) these is the error i am getting it seems the client 10.1.10.106 is not responding or something
medric 5 Posted May 27, 2015 Author Posted May 27, 2015 as you can see this issue is one of two things. the app is downloaded but the one that is downloaded does not work properly it give two errors the client talking to the server on a port does not seem to work and it is having a hard time identity my dlna device. Samsung UN32H5300
CBers 7554 Posted May 27, 2015 Posted May 27, 2015 2015-05-26 21:27:54.5265 Debug - SessionManager: Disposing session controller PlayToController 2015-05-26 21:27:55.5736 Error - App: Error getting response from http://10.1.10.106:7676/smp_26_ *** Error Report *** Version: 3.0.5621.3 Command line: C:\Users\media\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\media\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\media\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe The request was aborted: The operation has timed out. System.Net.WebException at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) 2015-05-26 21:27:55.5736 Error - Dlna: Error updating device info for [TV] Home *** Error Report *** Version: 3.0.5621.3 Command line: C:\Users\media\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\media\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\media\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe The request was aborted: The operation has timed out. MediaBrowser.Model.Net.HttpException at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsyncInternal>d__1e.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager.<SendAsync>d__7.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Dlna.PlayTo.SsdpHttpClient.<SendCommandAsync>d__0.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Dlna.PlayTo.Device.<GetTransportInfo>d__84.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Dlna.PlayTo.Device.<TimerCallback>d__51.MoveNext() InnerException: System.Net.WebException The request was aborted: The operation has timed out. at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) these is the error i am getting it seems the client 10.1.10.106 is not responding or something as you can see this issue is one of two things. the app is downloaded but the one that is downloaded does not work properly it give two errors the client talking to the server on a port does not seem to work and it is having a hard time identity my dlna device. Samsung UN32H5300 @@medric - they look like DLNA/Server issues, so perhaps I can move your posts to the DLNA forums ??
medric 5 Posted May 27, 2015 Author Posted May 27, 2015 okay no problem i have two of these tvs i just tried the other one it load the app but it wont let me log in it gives me this is the log it says i succed to log in but the client app does not log me in. but at least the app loads 2015-05-27 17:07:32.0099 Error - HttpServer: Error processing request for /mediabrowser/Users/AuthenticateByName?format=json *** Error Report *** Version: 3.0.5621.3 Command line: C:\Users\media\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\media\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\media\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Invalid user or password entered. ServiceStack.HttpError No Stack Trace Available 2015-05-27 17:07:46.5155 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:07:47.4676 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:07:48.4597 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:10:27.1219 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:10:29.7087 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:10:30.8956 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:10:33.9122 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:10:34.7230 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:10:35.2924 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:10:35.8937 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:10:36.4598 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:10:36.9152 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:10:37.2784 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:10:38.0784 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:10:38.3730 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:10:38.6503 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:10:40.3173 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:10:41.9935 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:10:44.9350 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:10:46.0623 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:10:53.7561 Info - App: IntervalTrigger fired for task: Convert media 2015-05-27 17:10:53.7561 Info - App: Queueing task SyncConvertScheduledTask 2015-05-27 17:10:53.7561 Info - App: Executing Convert media 2015-05-27 17:10:53.7561 Info - App: Convert media Completed after 0 minute(s) and 0 seconds 2015-05-27 17:10:53.7561 Info - ServerManager: Sending web socket message ScheduledTaskEnded 2015-05-27 17:10:54.1610 Info - App: IntervalTrigger fired for task: Download channel content 2015-05-27 17:10:54.1610 Info - App: Queueing task ChannelDownloadScheduledTask 2015-05-27 17:10:54.1610 Info - App: Executing Download channel content 2015-05-27 17:10:54.6484 Info - App: Download channel content Completed after 0 minute(s) and 0 seconds 2015-05-27 17:10:54.6484 Info - ServerManager: Sending web socket message ScheduledTaskEnded 2015-05-27 17:10:59.8338 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:00.4600 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:03.1962 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:03.9064 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:04.6520 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:08.3869 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:09.0253 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:09.3413 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:09.8617 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:10.0433 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:10.2744 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:10.5112 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:10.6935 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:10.9230 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:11.1385 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:11.3806 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:11.6307 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:11.8659 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:12.1056 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:12.4200 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:12.6597 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:32.5131 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:33.1385 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:41.6235 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:42.1653 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:45.3918 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:46.0937 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:47.6116 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:47.8828 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:48.1001 Info - UserManager: Authentication request for medric has succeeded. 2015-05-27 17:11:58.6699 Info - UserManager: Authentication request for medric has been denied. 2015-05-27 17:11:58.6699 Error - DtoUtils: ServiceBase<TRequest>::Service Exception *** Error Report *** Version: 3.0.5621.3 Command line: C:\Users\media\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 8 64-Bit OS: True 64-Bit Process: False Program data path: C:\Users\media\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\media\AppData\Roaming\MediaBrowser-Server\system\MediaBrowser.ServerApplication.exe Invalid user or password entered. System.UnauthorizedAccessException at MediaBrowser.Server.Implementations.Session.SessionManager.<AuthenticateNewSession>d__eb.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Api.UserService.<Post>d__17.MoveNext()
medric 5 Posted June 1, 2015 Author Posted June 1, 2015 I preform a system reset on the tv restarted and then logged into develop sync/downloaded the app again and after i did that i logged out of develop mode and restarted and it worked. 1
