scalda 69 Posted May 27, 2015 Posted May 27, 2015 (edited) Fix for the info screen has been checked in to Git. Giving others an hour or so to test the Git, then I will push to beta repo.I'll check it out in a sec Edit: @@xnappo all seems to be working, will post anything about anything out of the ordinary. Edited May 27, 2015 by scalda
inkubux 7 Posted May 27, 2015 Posted May 27, 2015 Thanks for this fix. I tried the Samba and it worked in Kodi without any issues and progress playback. Not in yatse though as it still try to use a vfs path Http playback did not work in Kodi or in Yatse (the path was a direct http link to The emby server in both case with /Video/[id]/stream.mp4) but failed to start in both app. Thanks again
scalda 69 Posted May 27, 2015 Posted May 27, 2015 Thanks for this fix. I tried the Samba and it worked in Kodi without any issues and progress playback. Not in yatse though as it still try to use a vfs path Http playback did not work in Kodi or in Yatse (the path was a direct http link to The emby server in both case with /Video/[id]/stream.mp4) but failed to start in both app. Thanks again That is very odd as my smb path gets passed to my yatse and can play locally fine. Are you sure you have turned on use direct paths in the config?
inkubux 7 Posted May 27, 2015 Posted May 27, 2015 (edited) That is very odd as my smb path gets passed to my yatse and can play locally fine. Are you sure you have turned on use direct paths in the config? Yes I did, turn on in the plugin And I turned on path substitution in Emby, I used \\[iP]\Media did you use something else ? But in Yatse the path shows as http://[KODI IP]/vsf/smb://[Emby IP]/ Thanks Edited May 27, 2015 by inkubux
scalda 69 Posted May 27, 2015 Posted May 27, 2015 Yes I did, turn on in the plugin And I turned on path substitution in Emby, I used \\[iP]\Media did you use something else ? But in Yatse the path shows as http://[KODI IP]/vsf/smb://[Emby IP]/ Thanks I don't use path substitution in emby, I have the direct smb paths set
inkubux 7 Posted May 27, 2015 Posted May 27, 2015 (edited) I don't use path substitution in emby, I have the direct smb paths set What do you mean by that. If I don't use pat substitution, I only have local paths of the media on my server in Kodi . and then nothing works [/mnt/user/Media], so this path is not available on my Kodi machine Did you mount the smb path in the Os level on Kodi ? Edited May 27, 2015 by inkubux
scalda 69 Posted May 27, 2015 Posted May 27, 2015 (edited) What do you mean by that. If I don't use pat substitution, I only have local paths f the media on my server in Kodi . and then nothing works Did you mount the smb path in the Os level on Kodi ? No I use UNC for my paths on my server, not local paths. UNC is the recommended way to set up the emby server if I remember correctly. Edited May 27, 2015 by scalda
xnappo 1611 Posted May 27, 2015 Author Posted May 27, 2015 @@inkubux - is your Emby server a Windows machine? If so - then yes UNC paths should be used.
scalda 69 Posted May 27, 2015 Posted May 27, 2015 (edited) @@inkubux - is your Emby server a Windows machine? If so - then yes UNC paths should be used. I should have asked that Edited May 27, 2015 by scalda
Angelblue05 4132 Posted May 27, 2015 Posted May 27, 2015 (edited) No, but I've made sure they worked. When it's a local path, there's no need to do anything to it so it should return the local path as playUrl if Kodi says the path exists. Well at least it was working when I reworked the path detection. I wanted to remove the need for UNC/network path when both server and Kodi are on the same machine. Anyway, it's not been tested fully since people already have their setup set according to what was required when using the Mediabrowser add-on. If you get it to work with local path, just let us know! Edited May 27, 2015 by Angelblue05
inkubux 7 Posted May 27, 2015 Posted May 27, 2015 @@inkubux - is your Emby server a Windows machine? If so - then yes UNC paths should be used. No unfortunately my server is on a Docker container on an Unraid server so UNC does not work
xnappo 1611 Posted May 27, 2015 Author Posted May 27, 2015 Okay. @@im85288 - any idea how this should work? I have never used path substitution...
scalda 69 Posted May 27, 2015 Posted May 27, 2015 No unfortunately my server is on a Docker container on an Unraid server so UNC does not work Could you not install a samba(smb) addon so you can use network paths?
inkubux 7 Posted May 27, 2015 Posted May 27, 2015 Could you not install a samba(smb) addon so you can use network paths? Yes But I think I will attempt to just mount at the OS level then it will appear as a local path
cgrey000 23 Posted May 28, 2015 Posted May 28, 2015 (edited) Fix for the info screen has been checked in to Git. Giving others an hour or so to test the Git, then I will push to beta repo. Just to be sure - should TV info screens be working correctly in 0.1.92? If it matters, just reset the database with the new path option set to use native paths after upgrading. Edited May 28, 2015 by cgrey000
e123enitan 276 Posted May 28, 2015 Posted May 28, 2015 (edited) Just installed .1.92, both window 7, and Openelec checked the 3rd option on the syn Option tab add-on went through db recycle, follow by system start, process took about 7 min to complete 1600 movies, to establish if direct works I checked one posted to determine path directory, its stamped as Plugin://plugin.video.emby------------ I follow the the process 3 times same result, nothing changes what I noticed was in the log emby play from smb which I presumed it is direct play-correct? it seems not I check past log same info 20:24:16 T:2941076544 NOTICE: EMBY Player -> onPlayBackStarted: smb://WDMYCLOUDEX4/Public/Movies/Analyze That (2002)/Analyze That (2002).mkv I don't think direct is working for me what should I do http://xbmclogs.com/pstv2pv41 http://xbmclogs.com/pjaq2vc5e Thanks Edited May 28, 2015 by e123enitan
xnappo 1611 Posted May 28, 2015 Author Posted May 28, 2015 Did you enter a password for your SMB account? Under playback 'Network Username' and 'Network Password'? I can see it tried to playback correctly, but it looks like some sort of access issue.
xnappo 1611 Posted May 28, 2015 Author Posted May 28, 2015 (edited) Just to be sure - should TV info screens be working correctly in 0.1.92? If it matters, just reset the database with the new path option set to use native paths after upgrading. Yes - it should work. If it is not, is it not working for any shows? To be clear - our primary support is for the addon method right now(not direct). Please use that unless you have a compelling reason not to. Of course - testing is very much welcomed, but for your 'family' boxes I don't recommend this right now. Edited May 28, 2015 by xnappo
e123enitan 276 Posted May 28, 2015 Posted May 28, 2015 (edited) Did you enter a password for your SMB account? Under playback 'Network Username' and 'Network Password'? I can see it tried to playback correctly, but it looks like some sort of access issue. must I have Network User and pass work setup, that would be new level of task, I never have to do this in pass, is this a requirement for this to work. I will pass, the few sec delay diff between addon and direct for me is not the end of world. I when I have time I shall set home network access. But I thought that is what the server does? to control user access why network etc Thanks Edited May 28, 2015 by e123enitan
e123enitan 276 Posted May 28, 2015 Posted May 28, 2015 Yes - it should work. If it is not, is it not working for any shows? To be clear - our primary support is for the addon method right now(not direct). Please use that unless you have a compelling reason not to. I am kool with addon, I dont see this a been a major issue, even on my low power box it plays very nicely. thanks Bud, love your work. Cheers! Of course - testing is very much welcomed, but for your 'family' boxes I don't recommend this right now.
xnappo 1611 Posted May 28, 2015 Author Posted May 28, 2015 I am not sure, but putting in the network username/password is something to try. Otherwise we might need to look at your .db file to see what is wrong.
bluemonkey07 590 Posted May 28, 2015 Posted May 28, 2015 must I have Network User and pass work setup, that would be new level of task, I never have to do this in pass, is this a requirement for this to work. I will pass, the few sec delay diff between addon and direct for me is not the end of world. I when I have time I shall set home network access. But I thought that is what the server does? to control user access why network etc Thanks ...but using this direct file path option you are for the most part bypassing the server
cgrey000 23 Posted May 28, 2015 Posted May 28, 2015 (edited) Yes - it should work. If it is not, is it not working for any shows? To be clear - our primary support is for the addon method right now(not direct). Please use that unless you have a compelling reason not to. Of course - testing is very much welcomed, but for your 'family' boxes I don't recommend this right now. Not working for any shows (well, tried 5 at random, all with the same result) Kodi set to "choose", I pick "show information" from the menu, the file plays (no info screen) Kodi set to "show information", file plays when selected Did NOT try (will tomorrow) the "old" (non direct path) method - made both changes at once. Ya, learned my lesson on the "family boxes" breaking things one too many times. I do it anymore there may not be a family This is a test box (FireTV) Edited May 28, 2015 by cgrey000
