bnwbass 3 Posted May 25, 2015 Posted May 25, 2015 Hello all, I am asking for a recommendation from MBC users on which player actually works and is stable for DVD .vob file structure rips and Blu ray m2ts files. Thx Bw
ebr 16334 Posted May 25, 2015 Posted May 25, 2015 You are probably best off with the internal one with LAV installed since WMC was actually designed to play DVD folder structures (and no modern player probably ever will be again). If they have menus, you'll need to turn off the custom interface for DVD rips though.
