Cruise 2 Posted May 24, 2015 Posted May 24, 2015 Version 3.0.5621.1 The recent update that changed the web client has broken the selection button. When you click a video to select instead of the video being selected the new screen pops up and the video is not selected. I am not sure exactly how to explain but this should show it.
Happy2Play 9799 Posted May 24, 2015 Posted May 24, 2015 (edited) Did you see the blog "New Slide Down Menus"? Edit - Sorry looks like New Slide Down Menus broke Select for "playlists/grouping/collections" Edited May 24, 2015 by Happy2Play
yardameus 221 Posted May 24, 2015 Posted May 24, 2015 Version 3.0.5621.1 I was just going to create a collection in the web client, and chose the select option, and then went to check off what I wanted in the collection. When I did this, instead of checking off the item I wanted, the new pop-up info screen just appeared, and nothing was selected. In this photo I was trying to select the hellboy collection (which I was trying to create when I noticed this issue).
Cruise 2 Posted June 3, 2015 Author Posted June 3, 2015 Under Version 3.0.5621.4 it has changed to just do nothing when you click on a movie, so no more slide down menu, but also I am still not able to select any movies.
Happy2Play 9799 Posted June 3, 2015 Posted June 3, 2015 This appears to be broke in the current Dev cycle also.
