dirkdigs 10 Posted May 24, 2015 Posted May 24, 2015 hi my DLNA Client (Panasonic Viera 2012 model) all of a sudden stopped transcoding MKV files with DCA Audio codec. video files appear all blurry and eventually error out , has anything chnaged with the default panaosnci profile?
dirkdigs 10 Posted May 24, 2015 Author Posted May 24, 2015 i checked the logs and it looks like the movie is being tansocding im just not seeing anything on the tv
Luke 42184 Posted May 24, 2015 Posted May 24, 2015 we'll need more info http://emby.media/community/index.php?/topic/790-how-to-report-a-problem/
dirkdigs 10 Posted May 24, 2015 Author Posted May 24, 2015 here you go transcode-dd2bebc5-2a2a-4ff9-a645-445f43806a19.zip
Luke 42184 Posted May 26, 2015 Posted May 26, 2015 Unfortunately we do not have a panasonic viera for testing so this aspect of Dlna is very much a community project. We're all working together to improve support for devices by trying to get to the root of the problem when we run into something. If the tv is having trouble with transcoded video, have you tried increasing the bitrate in the panasonic profile to attempt to encourage more direct play? have you tried comparing your model's supported media format list to what appears in the panasonic profile, just to make sure nothing was missed?
dirkdigs 10 Posted May 28, 2015 Author Posted May 28, 2015 it worked 2 weeks ago. so you guys must have changed something that broke it? or is that wrong.
