Luke 42239 Posted November 20, 2013 Posted November 20, 2013 for now just find the config file and remove it manually.
Ernst 29 Posted November 20, 2013 Posted November 20, 2013 (edited) I did not find a way in MBT itself, but if you edit the config file, you can delete the lines that refer to the external player and it is gone. Go to C:\users\you\appdata\roaming\MediaBrowser-Theater\config\system.xml and edit that. @@Luke, can you please have a delete possibility within MBT for external player config? damn you beat me to it Edited November 20, 2013 by Ernst
Della Dog 19 Posted November 20, 2013 Posted November 20, 2013 (edited) Not sure if the problems you have are the same I had, but what i did is this: Within MBT I configured the external player section to use TMT for 3D movies and put in the argument {PATH} actualy the external player points to the batch file i'm using to check for 3Dcontent and set the resolution accordingly. Once this is done, the same batch points to TMT (this is an old version and I'm still using the MCE variant because I didn't find the time to change it yet.) you will have to set iso mounting on too. Hope this helps. Thanks. I have the same settings except I point to the .exe, but the ISO neither mounts or plays. Could you possibly show the contents of your .bat file. Edited November 20, 2013 by pdcinc
Ernst 29 Posted November 20, 2013 Posted November 20, 2013 Thats weird, my batch is only doing a few checks and sets the resolution based on 3D or not. Here goes: @echo off REM - Detect 3D and load TMT IF EXIST %1\BDMV\STREAM\SSIF goto Enable3D :start echo %1 >> output.log "F:\Program Files (x86)\tmt3\uMCEDVDPlayer.exe" %1 echo "closing BR DISC",J:, >> output.log "C:\Program Files\UltraMon\UltraMonShortcuts.exe" /l C:\Users\Admin\AppData\Roaming\Realtime Soft\UltraMon\3.1.0\Profiles\default.umprofile echo "3D disabled", >> output.log goto end :Enable3D echo "3D BluRay detected" echo "3D BluRay detected" >> output.log "C:\Program Files\UltraMon\UltraMonShortcuts.exe" /l C:\Users\Admin\AppData\Roaming\Realtime Soft\UltraMon\3.1.0\Profiles\24.umprofile echo "3D enabled", >> output.log REM - Delay 2 seconds to prevent TMT crash PING 1.1.1.1 -n 3 -w 1000 >NUL goto start :end EXIT Note that the {PATH} argument in MBT is picked up by the %1 argument in the batch file and therefore represents the virtual path and filename of the movie (DVD or BRD)
Della Dog 19 Posted November 20, 2013 Posted November 20, 2013 Thats weird, my batch is only doing a few checks and sets the resolution based on 3D or not. Here goes: @echo off REM - Detect 3D and load TMT IF EXIST %1\BDMV\STREAM\SSIF goto Enable3D :start echo %1 >> output.log "F:\Program Files (x86)\tmt3\uMCEDVDPlayer.exe" %1 echo "closing BR DISC",J:, >> output.log "C:\Program Files\UltraMon\UltraMonShortcuts.exe" /l C:\Users\Admin\AppData\Roaming\Realtime Soft\UltraMon\3.1.0\Profiles\default.umprofile echo "3D disabled", >> output.log goto end :Enable3D echo "3D BluRay detected" echo "3D BluRay detected" >> output.log "C:\Program Files\UltraMon\UltraMonShortcuts.exe" /l C:\Users\Admin\AppData\Roaming\Realtime Soft\UltraMon\3.1.0\Profiles\24.umprofile echo "3D enabled", >> output.log REM - Delay 2 seconds to prevent TMT crash PING 1.1.1.1 -n 3 -w 1000 >NUL goto start :end EXIT Note that the {PATH} argument in MBT is picked up by the %1 argument in the batch file and therefore represents the virtual path and filename of the movie (DVD or BRD) Thanks much. I see you are using TMT3 - maybe it's an issue with TMT6. I'll experiment some more & post back with any findings. Thx again for posting your .bat
Della Dog 19 Posted November 20, 2013 Posted November 20, 2013 Hmm. Problem with most recent version 3.0.5067.29756 It seems the file mounts (as indicated by the Pismo icon ) but now TMT 6 fails to run. 2013-11-20 09:50:48.8855, Info, App, Loading MediaBrowser.Model, Version=3.0.5067.29756, Culture=neutral, PublicKeyToken=null 2013-11-20 09:50:48.9011, Info, App, Loading MediaBrowser.Common, Version=3.0.5067.29756, Culture=neutral, PublicKeyToken=null 2013-11-20 09:50:48.9011, Info, App, Loading MediaBrowser.Common.Implementations, Version=3.0.5067.29756, Culture=neutral, PublicKeyToken=null 2013-11-20 09:50:48.9011, Info, App, Loading MediaBrowser.UI, Version=3.0.5072.23, Culture=neutral, PublicKeyToken=null 2013-11-20 09:50:48.9011, Info, App, Loading MediaBrowser.Theater.DirectShow, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2013-11-20 09:50:48.9011, Info, App, Loading MediaBrowser.Theater.Presentation, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2013-11-20 09:50:48.9011, Info, App, Loading MediaBrowser.Theater.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2013-11-20 09:50:48.9011, Info, App, Loading MediaBrowser.IsoMounter, Version=1.0.5025.12100, Culture=neutral, PublicKeyToken=null 2013-11-20 09:50:48.9011, Info, App, Loading MediaBrowser.Plugins.DefaultTheme, Version=3.0.5072.22, Culture=neutral, PublicKeyToken=null . . . 2013-11-20 09:50:58.2515, Debug, ApiClient, Received OK status code after 0 ms from GET: http://192.168.1.3:8096/mediabrowser/Items/2ea68b95f78f54ec7362479c4f653b60/CriticReviews?format=json 2013-11-20 09:50:58.2515, Debug, App, Navigation complete to DetailPage 2013-11-20 09:50:58.2671, Debug, ApiClient, GET http://192.168.1.3:8096/mediabrowser/Items/2ea68b95f78f54ec7362479c4f653b60/ThemeMedia?InheritFromParent=True&UserId=27a8b3d3a00ba7d7bff28e838cf5d674&format=json 2013-11-20 09:50:58.2984, Debug, ApiClient, Received OK status code after 15.6055 ms from GET: http://192.168.1.3:8096/mediabrowser/Items/2ea68b95f78f54ec7362479c4f653b60/ThemeMedia?InheritFromParent=True&UserId=27a8b3d3a00ba7d7bff28e838cf5d674&format=json 2013-11-20 09:51:02.0492, Info, App, Mounting \\HTPC\HTPC-MEDIA\Media\Videos\ISOs\The Who Live At Royal Albert Hall\The_Who_live_royal_albert_hall_2000.iso 2013-11-20 09:51:02.0649, Debug, App, Start 2013-11-20 09:51:02.1273, Info, App, C:\Program Files (x86)\ArcSoft\TotalMedia Theatre 6\uTotalMediaTheatre6.exe "\\.$DU.pfmfs_7DB\The_Who_live_royal_albert_hall_2000.iso-42" 2013-11-20 09:51:02.1586, Debug, ApiClient, ReportPlaybackStart: Item 2ea68b95f78f54ec7362479c4f653b60 2013-11-20 09:51:02.1586, Debug, App, Calling SetThreadExecutionState to prevent system idle 2013-11-20 09:51:02.6742, Info, ApiWebSocket, Received web socket message: UserDataChanged 2013-11-20 09:51:22.5024, Info, App, Unmounting \\HTPC\HTPC-MEDIA\Media\Videos\ISOs\The Who Live At Royal Albert Hall\The_Who_live_royal_albert_hall_2000.iso 2013-11-20 09:51:22.5024, Debug, App, Calling SetThreadExecutionState to allow system idle 2013-11-20 09:51:22.5024, Debug, ApiClient, ReportPlaybackStopped: Item 2ea68b95f78f54ec7362479c4f653b60, Position: --- 2013-11-20 09:51:23.0181, Info, ApiWebSocket, Received web socket message: UserDataChanged 2013-11-20 09:51:51.1900, Info, HiddenWindow, Closing 2013-11-20 09:51:51.1900, Debug, App, HiddenWindow_IsVisibleChanged. 2013-11-20 09:51:51.1900, Info, HiddenWindow, Closed 2013-11-20 09:51:51.1900, Info, App, Disposing ApplicationHost 2013-11-20 09:51:51.2057, Info, App, Disposing TaskManager 2013-11-20 09:51:51.2057, Info, App, Disposing HttpClientManager 2013-11-20 09:51:51.2057, Info, App, Disposing InstallationManager 2013-11-20 09:51:51.2057, Info, App, Disposing IsoManager 2013-11-20 09:51:51.2057, Info, App, Disposing PfmPapi 2013-11-20 09:51:51.2057, Info, App, PfmStatic.ApiUnload 2013-11-20 09:51:51.2057, Info, App, Disposing ApiClient 2013-11-20 09:51:51.2057, Info, App, Disposing ApiWebSocket 2013-11-20 09:51:51.2057, Debug, ApiWebSocket, Stopping web socket timer 2013-11-20 09:51:51.2213, Debug, ApiWebSocket, Disposing client web socket 2013-11-20 09:51:51.2213, Info, ApiWebSocket, Sending web socket close message. 2013-11-20 09:51:51.2213, Warn, ApiWebSocket, Web socket connection closed. 2013-11-20 09:51:51.2213, Info, App, Disposing PismoIsoManager 2013-11-20 09:51:51.2213, Info, App, Disposing PfmPapi 2013-11-20 09:51:51.2213, Info, App, PfmStatic.ApiUnload 2013-11-20 09:51:51.2213, Info, App, Disposing BackdropsEntryPoint 2013-11-20 09:51:51.2213, Info, ApiWebSocket, Created new web socket of type NativeClientWebSocket 2013-11-20 09:51:51.2213, Info, App, Disposing ScreensaverEntryPoint 2013-11-20 09:51:51.2213, Info, ApiWebSocket, Connected to ws://192.168.1.3:8096/mediabrowser 2013-11-20 09:51:51.2213, Info, ApiWebSocket, Sending web socket identification message Media Browser Theater|HTPC|3.0.5072.23|HTPC 2013-11-20 09:51:51.2369, Debug, ApiClient, GET http://192.168.1.3:8096/mediabrowser/System/Info?format=json 2013-11-20 09:51:51.2213, Info, App, Disposing ThemeSongEntryPoint 2013-11-20 09:51:51.2369, Info, App, Disposing WebSocketEntryPoint 2013-11-20 09:51:51.2369, Debug, ApiWebSocket, Disposing client web socket 2013-11-20 09:51:51.2369, Info, ApiWebSocket, Sending web socket close message. 2013-11-20 09:51:51.2369, Warn, ApiWebSocket, Web socket connection closed. 2013-11-20 09:51:51.2525, Debug, ApiClient, Received OK status code after 15.6092 ms from GET: http://192.168.1.3:8096/mediabrowser/System/Info?format=json
Della Dog 19 Posted November 20, 2013 Posted November 20, 2013 for kicks can you try mpc. i know it doesn't have full bluray support. all i want to know is if it can understand the mounted iso. thanks. Will do.
Ernst 29 Posted November 20, 2013 Posted November 20, 2013 (edited) The only difference I notice between your log and mine is a line that says Debug, App, Hidden window activated between Userdatachanged and unmounting, but that could be the batchfile window? Everything else looks the same. It appears the file has been running for about 20 seconds. I do recall having read somewhere long ago you need to have autorun dvd in TMT unticked, could you check your settings of TMT? In TMT3 this is in the general tab from the settings. Look at this post on the old forum: http://community.mediabrowser.tv/permalinks/8989/tmt5-integration-with-iso-s-i-must-be-missing-something it says: also, make sure you have autoplay turned to “take no action” for how windows deals with bluray discs. Edited November 20, 2013 by Ernst
Luke 42239 Posted November 21, 2013 Posted November 21, 2013 for kicks can you try mpc. i know it doesn't have full bluray support. all i want to know is if it can understand the mounted iso. thanks.
Della Dog 19 Posted November 21, 2013 Posted November 21, 2013 Well getting closer after a reboot. Pizmo mounts, TMT loads & shows file name in last played, but no play. I suspect it's something to do with the mount. Dunno. 2013-11-20 12:12:51.9863, Info, App, Mounting \\HTPC\HTPC-MEDIA\Media\Videos\ISOs\The Who Live At Royal Albert Hall\The_Who_live_royal_albert_hall_2000.iso 2013-11-20 12:12:52.0020, Debug, App, Start 2013-11-20 12:12:52.1269, Info, App, C:\Program Files (x86)\ArcSoft\TotalMedia Theatre 6\uTotalMediaTheatre6.exe "\\.$DU.pfmfs_7DB\The_Who_live_royal_albert_hall_2000.iso-3" 2013-11-20 12:12:52.1426, Debug, ApiClient, ReportPlaybackStart: Item 2ea68b95f78f54ec7362479c4f653b60 2013-11-20 12:12:52.1426, Debug, App, Calling SetThreadExecutionState to prevent system idle 2013-11-20 12:12:52.6747, Info, ApiWebSocket, Received web socket message: UserDataChanged 2013-11-20 12:12:54.0673, Info, ApiWebSocket, Received web socket message: LibraryChanged 2013-11-20 12:12:54.0673, Error, ApiWebSocket, Error deserializing web socket message Type definitions should start with a '{', expecting serialized type 'WebSocketMessage', got string starting with: adfaeed86c89fb11cb70b19351","9b0f4d307a7d31642950b System.Runtime.Serialization.SerializationException at ServiceStack.Text.Common.DeserializeTypeRefJson.StringToType(Type type, String strType, EmptyCtorDelegate ctorFn, Dictionary`2 typeAccessorMap) at ServiceStack.Text.Common.DeserializeType`1.<>c__DisplayClass3.<GetParseMethod>b__1(String value) at ServiceStack.Text.Json.JsonReader`1.Parse(String value) at ServiceStack.Text.JsonSerializer.DeserializeFromString[T](String value) at MediaBrowser.Common.Implementations.Serialization.JsonSerializer.DeserializeFromString[T](String text) at MediaBrowser.ApiInteraction.WebSocket.BaseApiWebSocket.GetMessageType(String json) at MediaBrowser.ApiInteraction.WebSocket.BaseApiWebSocket.OnMessageReceived(String json) 2013-11-20 12:12:54.0673, Error, ApiWebSocket, Error deserializing web socket message Type definitions should start with a '{', expecting serialized type 'WebSocketMessage', got string starting with: 70db1534072f0cbd57c889e66","60367124536c4e817d94e2 System.Runtime.Serialization.SerializationException at ServiceStack.Text.Common.DeserializeTypeRefJson.StringToType(Type type, String strType, EmptyCtorDelegate ctorFn, Dictionary`2 typeAccessorMap) at ServiceStack.Text.Common.DeserializeType`1.<>c__DisplayClass3.<GetParseMethod>b__1(String value) at ServiceStack.Text.Json.JsonReader`1.Parse(String value) at ServiceStack.Text.JsonSerializer.DeserializeFromString[T](String value) at MediaBrowser.Common.Implementations.Serialization.JsonSerializer.DeserializeFromString[T](String text) at MediaBrowser.ApiInteraction.WebSocket.BaseApiWebSocket.GetMessageType(String json) at MediaBrowser.ApiInteraction.WebSocket.BaseApiWebSocket.OnMessageReceived(String json) 2013-11-20 12:14:26.6653, Info, ApiWebSocket, Received web socket message: ScheduledTaskStarted 2013-11-20 12:14:31.4163, Info, ApiWebSocket, Received web socket message: ScheduledTaskEnded 2013-11-20 12:14:49.3624, Info, ApiWebSocket, Received web socket message: LibraryChanged 2013-11-20 12:15:10.5916, Debug, App, Hidden window activated. 2013-11-20 12:15:10.6072, Info, App, Unmounting \\HTPC\HTPC-MEDIA\Media\Videos\ISOs\The Who Live At Royal Albert Hall\The_Who_live_royal_albert_hall_2000.iso 2013-11-20 12:15:10.6072, Debug, App, Calling SetThreadExecutionState to allow system idle 2013-11-20 12:15:10.6072, Debug, ApiClient, ReportPlaybackStopped: Item 2ea68b95f78f54ec7362479c4f653b60, Position: --- 2013-11-20 12:15:11.1385, Info, ApiWebSocket, Received web socket message: UserDataChanged 2013-11-20 12:15:13.0916, Info, HiddenWindow, Closing 2013-11-20 12:15:13.0916, Debug, App, HiddenWindow_IsVisibleChanged. 2013-11-20 12:15:13.0916, Info, HiddenWindow, Closed 2013-11-20 12:15:13.0916, Info, App, Disposing ApplicationHost 2013-11-20 12:15:13.1072, Info, App, Disposing TaskManager 2013-11-20 12:15:13.1072, Info, App, Disposing HttpClientManager 2013-11-20 12:15:13.1072, Info, App, Disposing InstallationManager 2013-11-20 12:15:13.1072, Info, App, Disposing IsoManager 2013-11-20 12:15:13.1072, Info, App, Disposing PfmPapi 2013-11-20 12:15:13.1072, Info, App, PfmStatic.ApiUnload 2013-11-20 12:15:13.1072, Info, App, Disposing ApiClient 2013-11-20 12:15:13.1072, Info, App, Disposing ApiWebSocket 2013-11-20 12:15:13.1072, Debug, ApiWebSocket, Stopping web socket timer 2013-11-20 12:15:13.1228, Debug, ApiWebSocket, Disposing client web socket 2013-11-20 12:15:13.1228, Info, ApiWebSocket, Sending web socket close message. 2013-11-20 12:15:13.1228, Info, App, Disposing PismoIsoManager 2013-11-20 12:15:13.1228, Info, App, Disposing PfmPapi 2013-11-20 12:15:13.1228, Info, App, PfmStatic.ApiUnload 2013-11-20 12:15:13.1228, Info, App, Disposing BackdropsEntryPoint 2013-11-20 12:15:13.1228, Info, App, Disposing ScreensaverEntryPoint 2013-11-20 12:15:13.1228, Info, App, Disposing ThemeSongEntryPoint 2013-11-20 12:15:13.1385, Warn, ApiWebSocket, Web socket connection closed. 2013-11-20 12:15:13.1385, Info, App, Disposing WebSocketEntryPoint 2013-11-20 12:15:13.1385, Info, ApiWebSocket, Created new web socket of type NativeClientWebSocket 2013-11-20 12:15:13.1385, Info, ApiWebSocket, Connected to ws://192.168.1.3:8096/mediabrowser 2013-11-20 12:15:13.1385, Info, ApiWebSocket, Sending web socket identification message Media Browser Theater|HTPC|3.0.5072.23|HTPC 2013-11-20 12:15:13.1385, Debug, ApiClient, GET http://192.168.1.3:8096/mediabrowser/System/Info?format=json
Luke 42239 Posted November 21, 2013 Posted November 21, 2013 mpc? also while tmt is still open, see if you can browse using the unc path generated in the log.
Della Dog 19 Posted November 21, 2013 Posted November 21, 2013 mpc? also while tmt is still open, see if you can browse using the unc path generated in the log. Need to install MPC first, haven't done so yet. Will try this first: \\.$DU.pfmfs_7DB\The_Who_live_royal_albert_hall_2000.iso-3
soundsnake8 27 Posted November 21, 2013 Posted November 21, 2013 Amazing is not good enough ! Stunning, I MEAN WOW ! I am having a great time watching movies and tinkering with MBT. Thanks so much. I have not been able to get TMT 6 to launch an iso but using MPC checking "mount" and {path} works on everything I have tried: BD folders and iso's, DVD folders, WTV files to name a few it plays 3D in 2D but it plays them flawlessly. I will keep playing withTMT6 for 3D playback right now I do not have the batch file knowledge so I will keep reading and searching on that. But for now many thanks and congratulations Luke this is absolutely stunning a great leap forward 1
Ernst 29 Posted November 21, 2013 Posted November 21, 2013 Just to be sure, can you tell me whether this is a BRD or DVD and if you have set your autoplay in windows to "take no action" 1
Della Dog 19 Posted November 21, 2013 Posted November 21, 2013 Just to be sure, can you tell me whether this is a BRD or DVD and if you have set your autoplay in windows to "take no action" DVD - Autoplay OFF. Windows 8.1
Luke 42239 Posted November 21, 2013 Posted November 21, 2013 i don't think autoplay makes any difference. it's being mounted to a folder, not a drive letter. if you look at these items in the web client, is there media info metadata? that will tell us if the server was able to mount and read the iso, or if it had the same problem.
Della Dog 19 Posted November 21, 2013 Posted November 21, 2013 (edited) i don't think autoplay makes any difference. it's being mounted to a folder, not a drive letter. if you look at these items in the web client, is there media info metadata? that will tell us if the server was able to mount and read the iso, or if it had the same problem. And it streams to the browser - cool. Edited November 20, 2013 by pdcinc
Luke 42239 Posted November 21, 2013 Posted November 21, 2013 So the server is able to mount it. try re-installing the visual c++ 2010 runtime for x86.
Della Dog 19 Posted November 21, 2013 Posted November 21, 2013 So the server is able to mount it. try re-installing the visual c++ 2010 runtime for x86. This is my production machine, I'll do as asked if you think there's a link & not specific to TMT.
Luke 42239 Posted November 21, 2013 Posted November 21, 2013 yea there might be. and it won't harm anyting.
Della Dog 19 Posted November 21, 2013 Posted November 21, 2013 yea there might be. and it won't harm anyting. It appears I have the latest (visual c++ 2010 runtime for x86 SP1) installed. Only option was repair, chose it, no help. You want for me to remove and install? (gulp)
bluc 21 Posted March 28, 2014 Posted March 28, 2014 (edited) Im having the same issue with powerdvd13 pro I only need it for full 3d bluray isos(inbuilt player works fine for standard blu ray) the player starts but the movie does not perhaps I need a bat file to tell powerdvd13 the movie is in the unc mount path? But have no idea how to help appreciated.cheers FIXED needed to put in the argument section "{PATH} /play" that is for powerdvd13 pro cheers edit 2 cant get it working with powerdvd12 anyone know what to put instead of "/Play"? Edited March 28, 2014 by bluc
byngo 6 Posted December 4, 2014 Posted December 4, 2014 Im having the same issue with powerdvd13 pro I only need it for full 3d bluray isos(inbuilt player works fine for standard blu ray) the player starts but the movie does not perhaps I need a bat file to tell powerdvd13 the movie is in the unc mount path? But have no idea how to help appreciated.cheers FIXED needed to put in the argument section "{PATH} /play" that is for powerdvd13 pro cheers edit 2 cant get it working with powerdvd12 anyone know what to put instead of "/Play"? Bluc, did you ever resolve the above issue? Im on PDVD 11 and although my bluray ISO play fine in MBT I would like a 3d one to be handled by PDVD 11. (although I suspect I will have to switch PDVD to 3D mode manually)
