Sethking86 0 Posted May 21, 2015 Posted May 21, 2015 I did all the steps and it's still asking for a pin when I click on emby need help
Luke 42241 Posted May 21, 2015 Posted May 21, 2015 What steps did you do? The Connect feature is optional, you can also click the skip button and locate your server manually.
Sethking86 0 Posted May 21, 2015 Author Posted May 21, 2015 Hmm I went to emby.media/pin it asked for a pin I put it inside it was successful along with my login but when I click on emby it still brings that message up
Luke 42241 Posted May 21, 2015 Posted May 21, 2015 what you need to do is leave the pin screen open on the roku device while you enter it on the website. after you enter it on the site, the roku will recognize that within about 10 seconds and then take you to your server. the important thing is leaving the pin screen as it is on the roku while you go to the website.
Luke 42241 Posted May 21, 2015 Posted May 21, 2015 in order to improve the process, can i ask why didn't you do that? i suppose the screen should say leave this screen open, but we can only fit so much text onto it. Although it does say go to the website to enter the pin, followed by This screen will automatically update once your Roku player has been linked to your Emby account.
Happy2Play 9811 Posted May 22, 2015 Posted May 22, 2015 (edited) Are you sure Emby Server is running also? With my setup I only get the pin screen when Emby Server isn't running. Edited May 22, 2015 by Happy2Play
