dirkdigs 10 Posted May 21, 2015 Posted May 21, 2015 hello is it possible to get the chocolate theme for emby without having media center version of windows? (specifically looking for the cover flow UI) thanks,
dirkdigs 10 Posted May 21, 2015 Author Posted May 21, 2015 since Microsoft has discontinued WMC with windows 10 . is there any plans to have the chocolate theme plugin work with any other apps? (ie. MBT)?
ebr 16342 Posted May 22, 2015 Posted May 22, 2015 Not specifically. The goal is to make the default theme in MBT the best it can be but MBT will also be theme-able.
dirkdigs 10 Posted May 22, 2015 Author Posted May 22, 2015 so how about adding cover flow to the default theme as a display option?
