corey 317 Posted May 19, 2015 Posted May 19, 2015 I'm having trouble recently on my encodes for an Xbox 360 that's used as a WMC Extender with Emby. There's significant audio / video sync issues, and the video will sometimes just stop playing.Here's the MediaInfo for both a file that played fine (Interstellar) and one that does not (Breaking Bad, all are like this, I've provided sample info for an episode):Interstellar: General Complete name : \\MEDIASERVER\media\film\Interstellar (2014)\Interstellar (2014).m4v Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 File size : 13.5 GiB Duration : 2h 49mn Overall bit rate mode : Variable Overall bit rate : 11.4 Mbps Encoded date : UTC 2015-05-16 23:07:43 Tagged date : UTC 2015-05-16 23:07:43 Writing application : HandBrake 7168svn 2015051001 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 2h 49mn Bit rate : 7 429 Kbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 23.976 fps Minimum frame rate : 17.026 fps Maximum frame rate : 23.981 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.149 Stream size : 8.77 GiB (65%) Writing library : x264 core 144 r2525 40bb568 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=25000 / vbv_bufsize=31250 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00 Encoded date : UTC 2015-05-16 23:07:43 Tagged date : UTC 2015-05-16 23:07:43 Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio #1 ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 2h 49mn Bit rate mode : Variable Bit rate : 255 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 308 MiB (2%) Title : Stereo / Stereo Language : English Encoded date : UTC 2015-05-16 23:07:43 Tagged date : UTC 2015-05-16 23:07:43 Audio #2 ID : 3 Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Mode : 16 Format settings, Endianness : Big Codec ID : A9 Duration : 2h 49mn Bit rate mode : Variable Bit rate : Unknown / 1 509 Kbps Channel(s) : 2 channels Channel(s)_Original : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossless / Lossy Stream size : 4.36 GiB (32%) Title : Surround / Surround Language : English Encoded date : UTC 2015-05-16 23:07:43 Tagged date : UTC 2015-05-16 23:07:43 Menu ID : 4 Codec ID : text Duration : 2h 49mn Language : English Encoded date : UTC 2015-05-16 23:07:43 Tagged date : UTC 2015-05-16 23:07:43 00:00:00.000 : Chapter 1 00:09:35.592 : Chapter 2 00:17:12.423 : Chapter 3 00:25:00.850 : Chapter 4 00:35:45.494 : Chapter 5 00:42:16.968 : Chapter 6 00:50:19.992 : Chapter 7 00:54:48.177 : Chapter 8 00:58:59.803 : Chapter 9 01:06:15.113 : Chapter 10 01:17:28.286 : Chapter 11 01:25:32.102 : Chapter 12 01:34:32.100 : Chapter 13 01:46:14.802 : Chapter 14 01:55:34.653 : Chapter 15 02:02:14.344 : Chapter 16 02:12:56.944 : Chapter 17 02:20:53.921 : Chapter 18 02:35:12.195 : Chapter 19 02:43:59.930 : Chapter 20 Bit rate mode : VBR Breaking Bad: General Complete name : \\MEDIASERVER\media\TV\Breaking Bad\Season 1\Breaking Bad.s01e07.m4v Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 File size : 8.39 GiB Duration : 47mn 42s Overall bit rate mode : Variable Overall bit rate : 25.2 Mbps Encoded date : UTC 2015-05-18 04:35:44 Tagged date : UTC 2015-05-18 04:35:44 Writing application : HandBrake 7168svn 2015051001 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 47mn 42s Bit rate : 21.5 Mbps Width : 1 918 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 23.976 fps Minimum frame rate : 17.026 fps Maximum frame rate : 23.981 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.433 Stream size : 7.17 GiB (85%) Writing library : x264 core 144 r2525 40bb568 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=25000 / vbv_bufsize=31250 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00 Encoded date : UTC 2015-05-18 04:35:44 Tagged date : UTC 2015-05-18 04:35:44 Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio #1 ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 47mn 42s Bit rate mode : Variable Bit rate : 256 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 87.3 MiB (1%) Title : Stereo / Stereo Language : English Encoded date : UTC 2015-05-18 04:35:44 Tagged date : UTC 2015-05-18 04:35:44 Audio #2 ID : 3 Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Mode : 16 Format settings, Endianness : Big Codec ID : A9 Duration : 47mn 42s Bit rate mode : Variable Bit rate : Unknown / 1 509 Kbps Channel(s) : 2 channels Channel(s)_Original : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossless / Lossy Stream size : 1.13 GiB (13%) Title : Surround / Surround Language : English Encoded date : UTC 2015-05-18 04:35:44 Tagged date : UTC 2015-05-18 04:35:44 Menu ID : 4 Codec ID : text Duration : 47mn 42s Language : English Encoded date : UTC 2015-05-18 04:35:44 Tagged date : UTC 2015-05-18 04:35:44 Bit rate mode : CBR 00:00:00.000 : Chapter 1 00:04:03.635 : Chapter 2 00:14:42.190 : Chapter 3 00:26:15.758 : Chapter 4 00:31:47.005 : Chapter 5 00:35:09.416 : Chapter 6 00:46:57.123 : Chapter 7 00:47:40.958 : Chapter 8 Any thoughts or insights? The bitrate jumps out to me as potentially being the issue (via http://support.xbox.com/en-US/xbox-360/system/audio-video-playback).My version of Emby Server is: 3.0.5607.2 and MediaBrowser Classic is: 3.0.266.0Thanks!
Luke 42240 Posted May 19, 2015 Posted May 19, 2015 The bitrate is the likely culprit. in my experience the xbox 360 has difficulty with anything over 10-12. i am surprised your first file plays well, to be honest.
corey 317 Posted May 19, 2015 Author Posted May 19, 2015 Thanks for the quick response Luke! Follow-up question. Is there any way to force a transcode at the server so it will playback properly on my Xbox 360?
Luke 42240 Posted May 20, 2015 Posted May 20, 2015 @@ebr will have to respond to that one, i'm not sure.
ebr 16334 Posted May 20, 2015 Posted May 20, 2015 Not exactly, but, depending on your exact requirements, you may be able to trick it... As long as we can directly access it MBC just feeds the item to WMC and it takes it from there. So, if you were to put that item in a location that the MBC machine could not see, then we would ask the server to transcode it instead. You could give that a try with just that TV series and see if it works for you.
corey 317 Posted May 20, 2015 Author Posted May 20, 2015 Thanks @@ebr. I'm not sure if that'll work for my use case because I have MBC and Emby Server on the same machine.
