kjp4756 41 Posted May 19, 2015 Posted May 19, 2015 I'm having a strange issue with the artic zephyr skin and movie fan art. TV fan art shows up fine. Movie fan art doesn't show on the home screen when the movie spotlight widget is on. All I get is a blank background. If I use the ongoing episodes widget, TV backgrounds show fine. I'm not sure if this is a skin problem or an emby problem. I am seeing this in the logs: WARNING: Create - unsupported protocol(image) in image://http%3a%2f%2f10.1.1.231%3a8096%2fmediabrowser%2fItems%2f77fbe24909aea05d9ba8b4132d3cf069%2fImages%2fBackdrop%2f0%3fMaxWidth%3d10000%26MaxHeight%3d10000%26Format%3doriginal%26Tag%3de3ab56fe27d389446754d0fb04910a34/ - Asus chromebox - Openelec 5.0.8 - Emby for kodi 0.1.91 - Emby server Version 3.0.5607.2 FreeNAS 9.3 jail 01_KODI.log
Solution xnappo 1611 Posted May 19, 2015 Solution Posted May 19, 2015 You need to run the texture cache tool. Unfortunately the 'easy' write up on this isn't quite done, but you should be able to find what you need here: http://emby.media/community/index.php?/topic/21469-instructions-to-cache-images/ 1
