EduardoSantos 40 Posted May 19, 2015 Posted May 19, 2015 Dear sirs, The web client could not play some movies from my library. These movies are nicely played by Roku and Android apps. Checking the transcoding log I found: http://pf304.no-ip.biz:8096/mediabrowser/videos/9e8a3d5169a643207d29af7ed206ea91/stream.webm?DeviceId=ff13285f90809b2fce0a077bfe7c64793c6d5763&MediaSourceId=9e8a3d5169a643207d29af7ed206ea91&VideoCodec=vpx&AudioCodec=vorbis&AudioStreamIndex=1&SubtitleStreamIndex=2&VideoBitrate=29680000&AudioBitrate=320000&MaxWidth=1920&ClientTime=635676407043961337&PlaySessionId=14ddc7a104474a8d9dbb71a5b8fd3ff8&api_key=68dff2d78c194d0b8641ab54870af156 {"Protocol":"File","Id":"9e8a3d5169a643207d29af7ed206ea91","Path":"E:\\Videos\\Filmes\\One Flew Over the Cuckoo's Nest (1975)\\One Flew Over the Cuckoo's Nest (1975).mkv","Type":"Default","Container":"mkv","Name":"1080P/H264/AC3","RunTimeTicks":80222720000,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","Language":"eng","IsInterlaced":false,"BitRate":10833197,"BitDepth":8,"RefFrames":4,"IsDefault":true,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":23.97599,"RealFrameRate":23.97599,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false,"IsCabac":true},{"Codec":"ac3","Language":"eng","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":640000,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"srt","Language":"por","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":2,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":false,"Level":0},{"Codec":"srt","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":3,"IsExternal":true,"IsTextSubtitleStream":true,"SupportsExternalStream":false,"Path":"E:\\Videos\\Filmes\\One Flew Over the Cuckoo's Nest (1975)\\One Flew Over the Cuckoo's Nest (1975).srt"}],"PlayableStreamFileNames":[],"Formats":["mkv","webm"],"Bitrate":10833197,"RequiredHttpHeaders":{}} C:\Users\Eduardo\AppData\Roaming\MediaBrowser-Server\ffmpeg\20150331\ffmpeg.exe -fflags +genpts -i file:"E:\Videos\Filmes\One Flew Over the Cuckoo's Nest (1975)\One Flew Over the Cuckoo's Nest (1975).mkv" -map 0:0 -map 0:1 -codec:v:0 libvpx -force_key_frames expr:gte(t,n_forced*5) -copyts -vf "scale=min(iw\,1920):trunc(ow/dar/2)*2,subtitles='E\:/Videos/Filmes/One Flew Over the Cuckoo's Nest (1975)/One Flew Over the Cuckoo's Nest (1975).mkv:si=0',setpts=PTS -0/TB" -pix_fmt yuv420p -speed 16 -quality good -profile:v 0 -slices 8 -crf 4 -qmin 0 -qmax 50 -maxrate:v 10833197 -bufsize:v (10833197*2) -b:v 10833197 -vsync vfr -map_metadata -1 -threads 7 -codec:a:0 libvorbis -ab 320000 -af "aresample=async=1,asetpts=PTS-0/TB" -y "C:\Users\Eduardo\AppData\Roaming\MediaBrowser-Server\transcoding-temp\b2cd06aab078084eb806f0b0a22b0351.webm" ffmpeg version N-71182-g5cba529 Copyright (c) 2000-2015 the FFmpeg developers built with gcc 4.9.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-lzma --enable-decklink --enable-zlib libavutil 54. 21.100 / 54. 21.100 libavcodec 56. 32.100 / 56. 32.100 libavformat 56. 27.100 / 56. 27.100 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 13.101 / 5. 13.101 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 1.100 / 1. 1.100 libpostproc 53. 3.100 / 53. 3.100 Input #0, matroska,webm, from 'file:E:\Videos\Filmes\One Flew Over the Cuckoo's Nest (1975)\One Flew Over the Cuckoo's Nest (1975).mkv': Metadata: title : One Flew Over the Cuckoo's Nest (1975) encoder : libebml v1.2.3 + libmatroska v1.3.0 creation_time : 2015-05-19 12:29:04 Duration: 02:13:42.27, start: 0.000000, bitrate: 10833 kb/s Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x1080, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) Metadata: title : One Flew Over the Cuckoo's Nest (1975) Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s (default) Metadata: title : English Stream #0:2(por): Subtitle: subrip Metadata: title : Português [Parsed_subtitles_1 @ 0000000004aec800] Unable to open E:/Videos/Filmes/One Flew Over the Cuckoos Nest (1975)/One Flew Over the Cuckoos Nest (1975).mkv [AVFilterGraph @ 0000000004aed220] Error initializing filter 'subtitles' with args 'E\:/Videos/Filmes/One Flew Over the Cuckoos Nest (1975)/One Flew Over the Cuckoos Nest (1975).mkv:si=0' Error opening filters! I was able to circunvent it by renaming both folder, file and subtitle excluding the apostrophe. Same occurs to "Singin' in the Rain (1952)". But only when trying to play by the web client. server-63567629869.txt transcode-3b2161b6-58a2-409f-bcbd-9cded1590b85.txt
Solution Luke 42184 Posted May 20, 2015 Solution Posted May 20, 2015 This should be resolved for the next release. 1
