cleaning library
Go to solution Solved by marcelveldt,
Hi guys, I am in love with the Emby add-on thank you!
I noticed that whenever I clean my library in kodi it wipes out my emby media. I need to be able to clean the library in kodi because of some other media I have in kodi not piped through Emby. I'm assuming it is because that media doesn't have a listed source in kodi.
  • Solution
marcelveldt
You can still clean your library BUT just not the video library because that one is controlled by the addon. Issuing the native clean command on the video DB will indeed wipe Emby data from it. No way around this. OR use Kodi for your video library OR use Emby, not both...
The exception is for the music library. You can decide to not use Emby for music and still use Kodi for that.
  • Like 2
Guest
