careca 11 Posted May 18, 2015 Posted May 18, 2015 I have link to youtube trailers as part of my movies metadata in Emby Server. I also have installed the Emby add-on for Kodi and the YouTube addon. I am using Aeon Nox with Helix 14.2. Issue - Lauch Kodi, go to movie detail and click on Watch trailer. All I get is the YouTube login, search, etc, screen. On Emby Server you tube trailers works fine and last time I checked they also worked on Emby Theater. Does the current Kodi plug-in support the trailer metadata stored @ Emby server? Thanks
smidley 22 Posted June 16, 2015 Posted June 16, 2015 I have the same issue. Wondering if this is being worked on.
Angelblue05 4132 Posted June 16, 2015 Posted June 16, 2015 It's on our trello board. When someone has time to look over it, we will....or you can always do a pull request to fix it yourself
