hellboymike 5 Posted May 18, 2015 Posted May 18, 2015 i am succesfully logged in at home, but at work when i go to http://app.emby.media/connectlogin.html to log in with username and password, i get invalid Login failure invalid username or password
hellboymike 5 Posted May 18, 2015 Author Posted May 18, 2015 Do i have to donate in order to see my drives from another computer internet, or i should be able for free to see my home computer drives when i log into emby
Luke 42243 Posted May 18, 2015 Posted May 18, 2015 Hi, welcome. Have you gone through the Connect setup? See here: https://github.com/MediaBrowser/Wiki/wiki/Emby%20Connect See the bottom section Guide for Administrators
hellboymike 5 Posted May 18, 2015 Author Posted May 18, 2015 thank you i saw my mistake but i can log in now, but when i click on server i get connection server, we're unable to connect to the selected server right now. please ensure it is running and try again
hellboymike 5 Posted May 18, 2015 Author Posted May 18, 2015 Am i doing something wrong or have setup wrong?
Luke 42243 Posted May 18, 2015 Posted May 18, 2015 it sounds like Connect can't reach your server. You may need to setup port forwarding on your router to allow access to the server. The internal and external ports are both 8096. See here: http://netforbeginners.about.com/od/p/f/What-Is-Port-Forwarding.htm Or if you prefer a video
hellboymike 5 Posted May 18, 2015 Author Posted May 18, 2015 on my verizon fios i see at port foward both ports already 8096 8920, now what? ANd thanks for the help eager to see this happen and i will donate asap.
hellboymike 5 Posted May 18, 2015 Author Posted May 18, 2015 i used simple port fowardng and did port foward success, still same answer
hellboymike 5 Posted May 18, 2015 Author Posted May 18, 2015 omg got it i restared sever and now i see it at work, BUT if i have an .ISO movie it doesnt play the movie it starts with the extras, so is it a seeting im missing. I figured if i hit play the movie will just play.
hellboymike 5 Posted May 18, 2015 Author Posted May 18, 2015 Ok weird if i choose movie it plays some other type of movies or trailers, but if i hit next movie is there, weird.
Luke 42243 Posted May 18, 2015 Posted May 18, 2015 Ok weird if i choose movie it plays some other type of movies or trailers, but if i hit next movie is there, weird. that is cinema mode, enabled by the trailer plugin
hellboymike 5 Posted May 18, 2015 Author Posted May 18, 2015 THANK YOU GREAT, now i have to figure out why some dont play, LOVING IT 1
ebr 16335 Posted May 19, 2015 Posted May 19, 2015 ISOs will be very hit or miss. We won't always be able to tell what is the movie and what is some other feature on the disc.
hellboymike 5 Posted May 19, 2015 Author Posted May 19, 2015 Almost all my movies are .iso I'm so unlucky.
Spaceboy 2573 Posted May 19, 2015 Posted May 19, 2015 Extract all the videos from the ISO, you can get all the extras
hellboymike 5 Posted May 19, 2015 Author Posted May 19, 2015 Thanks but I would have to do all toouch work Now I just tried on iPhone to login to server connection failure unable to connect Does this happen often
thefirstofthe300 292 Posted May 29, 2015 Posted May 29, 2015 Thanks but I would have to do all toouch work Now I just tried on iPhone to login to server connection failure unable to connect Does this happen often Is this with the native app or with the web client?
