mediacowboy 438 Posted May 17, 2015 Posted May 17, 2015 (edited) I noticed today that my Fire TV Stick is not showing up in the remote control portion of the Web client. Please let me know of this is a known issue or I need to gets logs. Edited May 17, 2015 by mediacowboy
ebr 16335 Posted May 17, 2015 Posted May 17, 2015 Remote control has not been implemented in the FTV app yet. There is an issue with the common libs we need to work out before I can get to it and we just haven't gotten there yet.
mediacowboy 438 Posted May 17, 2015 Author Posted May 17, 2015 Not a problem I have to remotes and will keep one at my desk. I just thought I would check to see if this was a known issue. Thank you for all your hard work.
BlueKachina 4 Posted June 12, 2015 Posted June 12, 2015 Remote control has not been implemented in the FTV app yet. There is an issue with the common libs we need to work out before I can get to it and we just haven't gotten there yet.Hey ebr, is this also true for the Android TV app? They could be one and the same for all I know, so I didn't start a new thread about it. Same problem when I use my nvidia shield though. Cheers
ebr 16335 Posted June 12, 2015 Posted June 12, 2015 They share most of their code so, yes, also true of the ATV app. This should be available sometime in July.
ebr 16335 Posted July 12, 2015 Posted July 12, 2015 The latest version of the ATV/FTV app now supports being a remote control target from other Emby apps.
