Problems playing any movie
Go to solution Solved by Iorifly,
Iorifly
I think I understand why funcinou. The movie has no accent.
line- 403
smb://servidornas/Filmes4Tb/The.Conjuring.2013.1080p.BluRay.x264.Dual.ALLiANCE-Highvoltage/The.Conjuring.2013.1080p.BluRay.x264.Dual.ALLiANCE-Highvoltage.mkv
Now the film "Invencível"
It has special caracters in the file name.
see line - 1209
smb://servidornas/Filmes4Tb/Invencível (2015) 1080p 5.1 Dublado - Alan_680/Invencível (2015) 1080p Dublado - Alan_680.mp4
Edited by Iorifly
Angelblue05
@@Iorifly
Look at this, it works because
23:11:01 T:140735245472512   ERROR: GetMasterProfile: master profile doesn't exist
23:11:01 T:140735245472512   DEBUG: CPlayerCoreFactory::GetPlayers(smb://servidornas/Filmes4Tb/Invencível (2015) 1080p 5.1 Dublado - Alan_680/Invencível (2015) 1080p Dublado - Alan_680.mp4)
23:11:01 T:140735245472512  NOTICE: DVDPlayer: Opening: smb://servidornas/Filmes4Tb/Invencível (2015) 1080p 5.1 Dublado - Alan_680/Invencível (2015) 1080p Dublado - Alan_680.mp4
It did detect it as direct play because or else the path would be already converted to http://. The problem is something else....it almost seems at the time the line happened, the profile was shutting down (switch profile or Kodi restart)
  • Like 1
Angelblue05
Can you try to disable TV tunes to see if it works better? I don't know that they are currently compatible alongside Emby for Kodi.
  • Like 1
Iorifly
I got it!
Let me explain my environment.
The Emby runs on a windows maquian, not mac ... tavelz the delay in resolving the name ?? ?
Iorifly
Ok. I'll go off.
  • Solution
Iorifly
That was it !!! The tvtunner.
   I remade the database, deactivated the tvtunner and is working.
  • Like 1
Iorifly
Guy!
    Thank you! For your patience and help!
Now I will wait for the version compatible with tvtunner! Before it worked !!!
Thank you!
Angelblue05
Wooooo! Yes, I'm glad this is now resolved! Great job :) Yeah, we will support TV Tunes eventually, once we push out the first stable version. Thanks again for reporting.
  • Like 1
Iorifly
Now they need to see the repo.
   For is not updating. Not updated the Mac or on Windows. I had to remove the addon.
   Thank you!
Angelblue05
Yes, there was something with the last version. It is available in the repo, it just doesn't seem to be recognized as a higher version number, for some reason. It will resolve itself when we release the next version. For now, users can just uninstall/install the addon.
  • Like 1
xnappo
We need to call it .90. 85 is a bigger number than 9 :)
Angelblue05
Doh! :(
Sent from my iPhone using Tapatalk
Guest
