Freenas unable to write metadate to mounted volume
Hi there,
I have just installed the emby plugin on FreeNas at it seems to be working well with one exception...
It is unable to write to the volume where the media is stored...
Logs are filled with access denied messages when trying to write fanart, thumbnails. etc...
eg:
*** Error Report ***
    Version: 3.0.5607.2
    Command line: /usr/pbi/emby-amd64/lib/emby-server/MediaBrowser.Server.Mono.exe -ffmpeg /usr/pbi/emby-amd64/bin/ffmpeg -ffprobe /usr/pbi/emby-amd64/bin/ffprobe -programdata /var/db/emby-server
Error saving image to /Media/Fabrication/fanart.jpg
InnerException: System.UnauthorizedAccessException
    Access to the path "/Media/Fabrication/fanart.jpg" is denied.
I have a volume called Media
It is used for CIFS, guests have read and write access.
This volume is mounted in the emby plugin jail
Jail: customplugin_1
Source: /mnt/Store/Media
Destination: /Media
Mounted? TRUE
Read-Only? FALSE
When I shell into the jail, I can see the mount just fine, and write to it without problems.
Does the emby service run as a different user? Can anyone suggest a way to let its user write metadata to this mount?  (preferably with some rather specific instructions, because FreeNas permissions are not easy for me :(
Many thanks!
Alex
