speechles 2062 Posted May 16, 2015 Posted May 16, 2015 (edited) Suppose playing music from android to the roku via chrome on android. All is great, except when it moves to the next/previous song. Once you do that, the roku blanks what is actually playing. Chrome on android correctly lists the song connected as remote. This doesn't affect the song playing on the roku at all. You can still move to next/previous just fine, using the real roku remote, or using the remote client. It's just the screen isn't updating on the roku. Otherwise this works rather nicely. Note: When you play all the songs in the playlist the song circles back to the original song you started. At this point the display then shows everything correctly and it is no longer blank. But just for that one song in the playlist. Soon as you next/previous it goes blank again. That's an oddity isn't it? Edited May 16, 2015 by speechles
Luke 42241 Posted May 16, 2015 Posted May 16, 2015 You know, the beta was available for a full month before it made it into the public channel
