Guest asrequested Posted July 7, 2017 Posted July 7, 2017 When selecting repeat in the music player, it's supposed to change from white to green, indicating repeat all. Then if you select once more, a 1 is added to the icon to indicate that only the present song will repeat. Neither of these, happen. In the picture, repeat 1 is selected. It stays white.
ShoutingMan 101 Posted July 8, 2017 Posted July 8, 2017 Is there a quick guide for setting up MadVR to do Refresh Rate Switching (and nothing else). I want to try that out, as I need refresh rate switching but I've only got HD630 integrated graphics.
Luke 42237 Posted July 8, 2017 Author Posted July 8, 2017 Is there a quick guide for setting up MadVR to do Refresh Rate Switching (and nothing else). I want to try that out, as I need refresh rate switching but I've only got HD630 integrated graphics. The website has some links that might have some information: http://madvr.com/ Some community members here may also have some tips.
Guest asrequested Posted July 8, 2017 Posted July 8, 2017 (edited) Is there a quick guide for setting up MadVR to do Refresh Rate Switching (and nothing else). I want to try that out, as I need refresh rate switching but I've only got HD630 integrated graphics. It's pretty easy. Click on the link in the settings. It will open that folder. Double click madHcCtrl.exe. You will see the MadVR icon in the system tray. Right click and select MadVR settings. Then add the refresh rates you wish to use. Edited July 8, 2017 by Doofus 2
PrincessClevage 175 Posted July 8, 2017 Posted July 8, 2017 So if you select madvr will it be used to play all video footage or only some? Sent from my iPhone using Tapatalk
Guest asrequested Posted July 8, 2017 Posted July 8, 2017 So if you select madvr will it be used to play all video footage or only some? Sent from my iPhone using Tapatalk All video except live TV. Mpv is used for live tv
Luke 42237 Posted July 8, 2017 Author Posted July 8, 2017 All video files actually. So no http streams
ShoutingMan 101 Posted July 8, 2017 Posted July 8, 2017 (edited) It's pretty easy. Click on the link in the settings. It will open that folder. Double click madHcCtrl.exe. You will see the MadVR icon in the system tray. Right click and select MadVR settings. Then add the refresh rates you wish to use. Thanks. Video Switching worked. But... MadVR breaks audio output. Dolby TrueHD is output as Stereo. Edited July 8, 2017 by ShoutingMan
Guest asrequested Posted July 8, 2017 Posted July 8, 2017 (edited) Thanks. Video Switching worked. But... MadVR breaks audio output. Dolby TrueHD is output as Stereo. It's switching to LAV audio, so Luke may have to take a look at that. Maybe post your Theater logs? Edited July 8, 2017 by Doofus 1
Luke 42237 Posted July 8, 2017 Author Posted July 8, 2017 It's resolved for the next update to the app, thanks. 1
PrincessClevage 175 Posted July 9, 2017 Posted July 9, 2017 All video files actually. So no http streamsWhat is used to render http streams? I am using nextpvr and I noticed in stats for nerds original media is http video/audio streams not recognised so transcoding Sent from my iPhone using Tapatalk
Guest asrequested Posted July 9, 2017 Posted July 9, 2017 What is used to render http streams? I am using nextpvr and I noticed in stats for nerds original media is http video/audio streams not recognised so transcoding Sent from my iPhone using Tapatalk There are only two players, directshow and mpv. Directshow will be LAV and MadVR. The http streams will all go through mpv, as it handles that, better.
rewsteruk 5 Posted August 6, 2017 Posted August 6, 2017 Just installed Emby Theater 2.8.2 on new Windows 10 machine, the installer says it will install C++ 2015 Runtime, but it installs C++ 2013 runtime instead, so it asks to install C++ 2015 each time Emby is run. It stops once C++ 2015 installer is installed. Sorry it this has already been reported. Also, my last look at Emby Theater was early July, it appears that the exclusive mode audio is still not working as 96000Hz music files are output as 44100Hz and the system sounds can be heard and system volume can be adjusted log info: [ 0.397][v][cplayer] Run command: hook-ack, flags=0, args=[on_preloaded] [ 0.397][i][cplayer] (+) Audio --aid=1 (flac 2ch 96000Hz) [ 0.397][i][display-tags] File tags: [ 0.397][i][display-tags] Artist: Diana Krall [ 0.397][i][display-tags] Album: The Girl in The Other Room (24/96) [ 0.397][i][display-tags] Album_Artist: Diana Krall [ 0.397][i][display-tags] Title: Stop This World [ 0.397][i][display-tags] Track: 01 [ 0.398][v][ad] Codec list: [ 0.398][v][ad] flac - FLAC (Free Lossless Audio Codec) [ 0.398][v][ad] Opening audio decoder flac [ 0.398][v][ad] Requesting 1 threads for decoding. [ 0.398][v][ad] Selected audio codec: flac (FLAC (Free Lossless Audio Codec)) [ 0.398][v][cplayer] Starting playback... [ 0.400][v][af] Audio filter chain: [ 0.400][v][af] [in] 96000Hz stereo 2ch s32 [ 0.400][v][af] [out] 96000Hz stereo 2ch s32 [ 0.400][v][af] [ao] 96000Hz stereo 2ch s32 [ 0.400][v][ao] Trying audio driver 'wasapi' [ 0.400][v][ao/wasapi] requested format: 96000 Hz, stereo channels, s32 [ 0.409][v][ao/wasapi] No device specified. Selecting default. [ 0.413][v][ao/wasapi] Selecting device '{fc73ba36-e643-4936-b688-b823516807bd}' (marantz-AVR (Intel(R) Display Audio)) [ 0.413][v][ao/wasapi] Monitoring changes in device {0.0.0.00000000}.{fc73ba36-e643-4936-b688-b823516807bd} [ 0.460][v][ao/wasapi] Trying stereo s32 (32/32 bits) @ 96000hz (shared) -> ok [ 0.460][v][ao/wasapi] Closest match is stereo float (32/32 bits) @ 44100hz [ 0.460][v][ao/wasapi] Accepted as stereo float @ 44100hz (shared) -> stereo float (32/32 bits) @ 44100hz [ 0.461][v][ao/wasapi] Device period: 10 ms [ 0.477][v][ao/wasapi] Buffer frame count: 2240 (51 ms) [ 0.478][v][ao/wasapi] IAudioClock::GetFrequency gave a frequency of 352800. [ 0.483][v][ao/wasapi] device buffer: 2240 samples. [ 0.483][v][ao/wasapi] using soft-buffer of 8820 samples. [ 0.483][i][cplayer] AO: [wasapi] 44100Hz stereo 2ch float [ 0.483][v][cplayer] AO: Description: Windows WASAPI audio output (event mode) [ 0.484][v][af] Adding filter lavrresample [ 0.487][v][af] Audio filter chain: [ 0.487][v][af] [in] 96000Hz stereo 2ch s32 [ 0.487][v][af] [lavrresample] 44100Hz stereo 2ch float [a] [ 0.487][v][af] [out] 44100Hz stereo 2ch float [ 0.487][v][af] [ao] 44100Hz stereo 2ch float [ 0.491][v][cplayer] starting audio playback [ 0.491][v][cplayer] playback restart complete [ 0.494][i][cplayer] Track switched: [ 0.494][i][cplayer] (+) Audio --aid=1 (flac 2ch 96000Hz) [ 0.494][v][cplayer] Set property: sid="no" -> 1 [ 4.319][v][cache] EOF reached. [ 14.080][v][cplayer] Inserting volume filter. [ 14.080][v][af] Adding filter volume [ 14.080][v][af] Setting option 'warn' = 'no' (flags = 0) [ 14.080][v][af] Removing filter lavrresample [ 14.080][v][af] Adding filter lavrresample [ 14.080][v][af] Adding filter lavrresample [ 14.083][v][af] Audio filter chain: [ 14.083][v][af] [in] 96000Hz stereo 2ch s32 [ 14.083][v][af] [lavrresample] 96000Hz stereo 2ch float [a] [ 14.083][v][af] [volume] "softvol" 96000Hz stereo 2ch float [ 14.083][v][af] [lavrresample] 44100Hz stereo 2ch float [a] [ 14.083][v][af] [out] 44100Hz stereo 2ch float [ 14.083][v][af] [ao] 44100Hz stereo 2ch float
Luke 42237 Posted August 6, 2017 Author Posted August 6, 2017 We only use exclusive audio mode for video files, not for music.
rewsteruk 5 Posted August 6, 2017 Posted August 6, 2017 @@Luke, this was working after you did a quick fix post on #1971 on this thread, is it possible for me to add the changes you made to my mpv.conf to get pure lossless output working again? with default Windows 10 settings all audio is upsampled to 48000Hz (DVD Quality) with shared audio.
Luke 42237 Posted August 6, 2017 Author Posted August 6, 2017 The feedback from the community was that we should not apply it for music. I don't think mpv.conf will work because when the setting in Theater is no, we'll pass exclusive=no which will override your mpv.conf. What we can do for the next release is just omit it from the options we're sending unless it's yes. That will allow you to keep it off in Emby Theater and use mpv.conf to set it as desired.
Guest asrequested Posted August 6, 2017 Posted August 6, 2017 (edited) The feedback from the community was that we should not apply it for music. I don't think mpv.conf will work because when the setting in Theater is no, we'll pass exclusive=no which will override your mpv.conf. What we can do for the next release is just omit it from the options we're sending unless it's yes. That will allow you to keep it off in Emby Theater and use mpv.conf to set it as desired. That would explain why I've been having an issue with that! I wanted to make theater have exclusive audio, when in use. Just as it was before the move to mpv. And I would ask that when any setting is off, to allow the .conf to be in effect. There are other issues in this area, that I have raised. Such as the upmix setting, that doesn't work and the .conf setting is blocked. Edited August 6, 2017 by Doofus
Luke 42237 Posted September 19, 2017 Author Posted September 19, 2017 I've updated the list of accepted keyboard commands: https://github.com/MediaBrowser/Wiki/wiki/Keyboard%20and%20Remote%20Support Most of the netflix keyboad shortcuts are now supported. Enjoy. 2
daedalus 434 Posted September 19, 2017 Posted September 19, 2017 control-shift-a: cycle through audio tracks <-- this one never worked please fix it and add a additional shortcut to cycle trough subtitle tracks
Luke 42237 Posted September 19, 2017 Author Posted September 19, 2017 control-shift-a: cycle through audio tracks please fix it and add a additional shortcut to cycle trough subtitle tracks @@daedalus That was never actually implemented, however I just did that and you should have that update by tomorrow. I'll look at what shortcut to use for subtitles. Thanks. 2
Luke 42237 Posted September 21, 2017 Author Posted September 21, 2017 Any suggestion of a key combination to use for changing the subtitle track? We are already using control-shift-s for stop. Thanks.
daedalus 434 Posted September 21, 2017 Posted September 21, 2017 why not keep following windows media center and use Crtl+U ? https://msdn.microsoft.com/en-us/library/windows/desktop/bb189249.aspx
Luke 42237 Posted September 21, 2017 Author Posted September 21, 2017 Perfect, thanks. I think I just didn't realize there was already one.
Luke 42237 Posted September 22, 2017 Author Posted September 22, 2017 control-u has been added, and wiki updated: https://github.com/MediaBrowser/Wiki/wiki/Keyboard-and-Remote-Support Thanks. 2
