soundsnake8 27 Posted May 6, 2017 Posted May 6, 2017 Still no iso playback with external player PowerDVD 16
Luke 42239 Posted May 6, 2017 Author Posted May 6, 2017 Still no iso playback with external player PowerDVD 16 To my knowledge this is not an Emby Theater problem. The focus here was on the internal video player. If you feel there is something we need to address then please start a new topic about it, thanks.
soundsnake8 27 Posted May 6, 2017 Posted May 6, 2017 I have no idea what you are talking about. sorry if I offended you but I was using version 2.5.40 and it played iso's just fine. I updated to the new version and overwrote the older version and now part of it does not work. where would I start to address this issue ?
Luke 42239 Posted May 6, 2017 Author Posted May 6, 2017 I have no idea what you are talking about. sorry if I offended you but I was using version 2.5.40 and it played iso's just fine. I updated to the new version and overwrote the older version and now part of it does not work. where would I start to address this issue ? As always by following the guidelines of how to report a problem. Thanks !
jbl77 3 Posted May 6, 2017 Posted May 6, 2017 2.6 is headed up and includes the new video player. You will need to reconfigure your audio and video settings. Enjoy the new performance after i got the broken install fixed....playback performance degradation.
aptalca 71 Posted May 7, 2017 Posted May 7, 2017 I'm using the latest uwp on win 10 (sp3) and on the homescreen, the "more" buttons next to each section leads me to an all white screen and the app becomes unresponsive. Everything else seems to work, though.
Luke 42239 Posted May 7, 2017 Author Posted May 7, 2017 I'm using the latest uwp on win 10 (sp3) and on the homescreen, the "more" buttons next to each section leads me to an all white screen and the app becomes unresponsive. Everything else seems to work, though. Thanks for the feedback. We'll take a look.
rewsteruk 5 Posted May 7, 2017 Posted May 7, 2017 (edited) I only installed Emby Theater for Windows on the 1 May (version 2.5), was happy that it seemed to handle bitperfect lossless HiRes audio because it used WASAPI and exclusive mode, yesterday it autoupdated to 2.6, 2.6.1, now 2.6.4 this morning and these options are gone and i can hear the cursor UI sound whilst music is playing so not bitstreamed. Also the upmix audio channels for > music, really should be off by default but is always switches itself back on when switched off. My TV does not display refresh rate, but it appears that option to switch refresh rate is missing too. Is there a way to go back to 2.5? Edited May 7, 2017 by rewster
Luke 42239 Posted May 7, 2017 Author Posted May 7, 2017 I only installed Emby Theater for Windows on the 1 May (version 2.5), was happy that it seemed to handle bitperfect lossless HiRes audio because it used WASAPI and exclusive mode, yesterday it autoupdated to 2.6, 2.6.1, now 2.6.4 this morning and these options are gone and i can hear the cursor UI sound whilst music is playing so not bitstreamed. Also the upmix audio channels for > music, really should be off by default but is always switches itself back on when switched off. My TV does not display refresh rate, but it appears that option to switch refresh rate is missing too. Is there a way to go back to 2.5? @ we can add an exclusive audio mode setting. We will add it for the next update. Thanks.
Luke 42239 Posted May 7, 2017 Author Posted May 7, 2017 @ there is a setting for exclusive audio mode in 2.6.5. Thanks !
rewsteruk 5 Posted May 8, 2017 Posted May 8, 2017 @@Luke, thanks for the quick fix, seems to work (ie cannot hear emby and system gui sounds and system volume does not turn volume up and down, amp shows 96kHz 2 channel). One little issue when you stop playing audio the Emby GUI sounds do not return. Can I ask, is the music now playing in WASAPI exclusive mode? (like the video audio passthrough probably is), there was a separate options in 2.5.40 for WASAPI and exclusive mode and Sound Device, are they all being used then this new option is selected and applied to the current default audio device (mine being a Marantz AVR).
Luke 42239 Posted May 8, 2017 Author Posted May 8, 2017 @@Luke, thanks for the quick fix, seems to work (ie cannot hear emby and system gui sounds and system volume does not turn volume up and down, amp shows 96kHz 2 channel). One little issue when you stop playing audio the Emby GUI sounds do not return. Can I ask, is the music now playing in WASAPI exclusive mode? (like the video audio passthrough probably is), there was a separate options in 2.5.40 for WASAPI and exclusive mode and Sound Device, are they all being used then this new option is selected and applied to the current default audio device (mine being a Marantz AVR). @, it's intended to be for video only.
rewsteruk 5 Posted May 19, 2017 Posted May 19, 2017 @@Luke, updated to 2.7.1, I don't know which version inbetween broke it, but exclusive mode for audio is no longer working, I can hear system sounds and system volume is active.
rewsteruk 5 Posted May 20, 2017 Posted May 20, 2017 @@Luke, updated to 2.7.2 still not working I can hear the UI sounds and main volume still works. I tried foobar2000 to test, that behaved the same way on your first fix for me in Emby, No UI/System sounds and the main volume control has no effect in exclusive mode.
Luke 42239 Posted May 20, 2017 Author Posted May 20, 2017 Check the settings in the app and make sure it is enabled, thanks.
Guest asrequested Posted May 20, 2017 Posted May 20, 2017 (edited) Audio exclusivity isn't working for music, but it is for video. Video [ao/wasapi] Trying 7.1 spdif-truehd @ 192000hz (exclusive) -> ok Music [ao/wasapi] Trying 7.1(wide) s16 @ 44100hz (shared) -> ok Edited May 20, 2017 by Doofus 1
PrincessClevage 175 Posted May 21, 2017 Posted May 21, 2017 (edited) Adding to the FF and RW not working in the latest ET stable, also when you select an actor inside a movie I can not click down on the remote to view/select the movie the actor has been involved in (although I can see the tops of several movies listed) Edited May 21, 2017 by PrincessClevage
blade005 185 Posted May 21, 2017 Posted May 21, 2017 Adding to the FF and RW not working in the latest ET stable, also when you select an actor inside a movie I can not click down on the remote to view/select the movie the actor has been involved in (although I can see the tops of several movies listed) @@PrincessClevage FF and RW working in updated ET stable. I did an uninstall and a fresh install from website earlier this afternoon and it is working.
PrincessClevage 175 Posted May 21, 2017 Posted May 21, 2017 @@PrincessClevage FF and RW working in updated ET stable. I did an uninstall and a fresh install from website earlier this afternoon and it is working. Thanks, I did the same and FF and RW are also working on my system. When selecting an actor from within a single movie view I still can not use the down button on the remote to select/view other movies the actor has been involved in my collection ( I can see the top of several movie covers tho)
Guest asrequested Posted May 21, 2017 Posted May 21, 2017 There's a lot of wasted space here. Guide information is the most important. We still have one more day at the top than there is in the guide. If you correct that, you can move the day/date selection to the top of the screen. And the new edition of the arrows at the bottom? I don't see any real use for those. They are taking up valuable space.
Luke 42239 Posted May 21, 2017 Author Posted May 21, 2017 The arrows at the bottom only show up if you have a massive number of channels. They are really just temporary until we implement virtual scrolling and then we won't need them at all anymore.
Luke 42239 Posted May 21, 2017 Author Posted May 21, 2017 Version 2.7.6 brings a few important improvements: Downloads are now split by x86/x64 architecture. The sizes are now cut in half which means that both installations and updates will be faster now. We have reverted to an older version of Electron. This has restored the 60fps animation in the UI that you were previously accustomed to. We have noticed that in some limited environments, newer versions of Electron are not reaching 60fps and this is resulting in degraded UI performance. If you have been noticing this then you will want to update asap. When launching videos there is a nice little splash screen just like the web app has. Enjoy. 1
mattyg8 18 Posted May 21, 2017 Posted May 21, 2017 I am having an issue were when I exit Emby Theater then try to restart it that it wont start, I have to go to the task manager and kill emby theater before it will re open.
