makakam 2 Posted November 20, 2013 Posted November 20, 2013 @@DigiTM http://www.free-codecs.com/download/ReClock_DirectShow_Filter.htm You can use it for such purposes as long as you don't bitstream. BTW I found out that disabling reclock solves my a/v sync issue.
shaefurr 1340 Posted November 21, 2013 Posted November 21, 2013 TBH I've tried every update level ! Jusy use the installer from this forum. It will install the latest update. Happened to me before and that fixed it. Updates worked after that too
Boredcat 34 Posted November 21, 2013 Posted November 21, 2013 Wooow looks great. Can't wait how MBT develops into the future.
WWWestern 94 Posted November 21, 2013 Posted November 21, 2013 Crestj, are win account where previously installed MBT and account where starting MBT the same? If no, then in starting account delete folders: System, System.old, Updates. Or, at all, kill MediaBrowser-Theater anwehere and re-install MBT from site. Abobader, early alpha stage of the product assumes Dev level for sync.
Luke 42235 Posted November 21, 2013 Author Posted November 21, 2013 i never said anyone needed to change their update level. default settings are fine. 1
Abobader 3485 Posted November 21, 2013 Posted November 21, 2013 Abobader, early alpha stage of the product assumes Dev level for sync. Buddy, that what Luke told us to put the update level on, it on Beta by default tho.
Luke 42235 Posted November 21, 2013 Author Posted November 21, 2013 Crestj, are win account where previously installed MBT and account where starting MBT the same? If no, then in starting account delete folders: System, System.old, Updates. Or, at all, kill MediaBrowser-Theater anwehere and re-install MBT from site. Abobader, early alpha stage of the product assumes Dev level for sync. I would never design a product that immediately requires changing setting in order to function, unless it was something that is designed to be disabled by default.
Scals37 1 Posted November 21, 2013 Posted November 21, 2013 (edited) I get a "PSX Bios not found" when trying to launch PSX games. The BIOS is in the right folder, and I'm able to launch and play ePSXe outside of MB. Running on MBT version 3.0.5072.23 and ePSXe 170, which is the only version that seems to work on my system *update* Redownloaded the latest version of ePSXe (190) and it works outside of MBT, but getting the same exact error in MBT Edited November 21, 2013 by Scals37
yucca1960 0 Posted November 21, 2013 Posted November 21, 2013 Hi! I just installed MBT and the problem that I have is with the remote functions after the movie start, I have no control for stop, play,ff, rew. My case is an antec and I have the Imon sofware which work perfect with media center, vlc, mpc-hc, media browser3, but not with the internal player of MBT. Any advice?
swhitmore 781 Posted November 21, 2013 Posted November 21, 2013 Hi! I just installed MBT and the problem that I have is with the remote functions after the movie start, I have no control for stop, play,ff, rew. My case is an antec and I have the Imon sofware which work perfect with media center, vlc, mpc-hc, media browser3, but not with the internal player of MBT. Any advice? Hmm I'll have to crack out my Imon software and give it a try.
Rasputin 2 Posted November 21, 2013 Posted November 21, 2013 I have two client computers running MBT and after the 5072.23 update, both PCs are getting an error "There was an error processing the request" and won't play any content from the server. I've tried restarting the server and reinstalling the update from the link, no dice. Any ideas?
hedgehogg 104 Posted November 21, 2013 Posted November 21, 2013 @yucca1960 - Go into IMON Manager > settings > Program commands > add MBT as anew progmans . in the setup area 'Import@ the xp mediacenter settings andall will be good 1
elshagon 44 Posted November 22, 2013 Posted November 22, 2013 (edited) With 5072.23 I can't browse around or do anything with my Harmony One remote, worked before. Using the mouse for now. And btw the screensaver is brilliant as well as how theme videos play in the background. Just love how the default theme looks. UPDATE: ok feel dumb, user error on the above remote control issue. My harmony one receiver sensor was covered up by my kids sock, doh Edited November 21, 2013 by elshagon 4
Longrifle 33 Posted November 22, 2013 Posted November 22, 2013 thanks OK I found them and install them but I don't know how to use them? how do I pick them.
zakraket 3 Posted November 22, 2013 Posted November 22, 2013 (edited) nice The installer gave me the instruction/option to install xy-VSfilter, although I already installed it in the tutorial for LAV/playback in MBclassic. The installer did detect that I have LAV installed, but not xy-VSfilter. I cannot complete the installation without installing it (again) but I don't think thats a problem (installing it over the current xy-VSfilter) First impression: very nice! It seems a bit slow atm when navigating or opening certain movies, although my CPU isn't that high. Probably it's building some librarystuff on the background? edit: CPU is kinda high, running at 20-50% constantly while doing nothing (Athlon2X2 250 3Ghz, 2Gb RAM) Edited November 22, 2013 by zakraket
the.chad 0 Posted November 22, 2013 Posted November 22, 2013 (edited) Been meaning to make an account here forever. Seeing how awesome this programs been so far (and it's only in alpha!) I had to give you my compliments of how good it is. Really easy install (server was already configured) and it looks like it's only gonna get more awesome. Looking good guys! edit: Just used Steam's big picture add in, works perfectly. can really minimize the need of a keyboard/mouse when I finally get a htpc up & running Edited November 22, 2013 by the.chad
Pirlo1966 22 Posted November 23, 2013 Posted November 23, 2013 Wow!!! Well done Luke & sons. I particularly love how Theater automatically becomes transparent when new mail is coming in :-)
gcw07 347 Posted November 23, 2013 Posted November 23, 2013 Hi a question about local trailers. I can't seem to see and play them for films in my collection. I have tried searching the forum but I'm sure I did it wrong as i got no results when searching 'trailer' or 'trailers'. Thanks for your help. Probably just not something that is completed yet.
elshagon 44 Posted November 23, 2013 Posted November 23, 2013 When I start MBT I have to select the user before entering. Is there any way to go straight into MBT, especially since I only have one user?
mattykellyuk 18 Posted November 23, 2013 Posted November 23, 2013 Probably just not something that is completed yet. sorry they are there when i went back. 1
mattykellyuk 18 Posted November 23, 2013 Posted November 23, 2013 Hi a question about local trailers. I can't seem to see and play them for films in my collection. I have tried searching the forum but I'm sure I did it wrong as i got no results when searching 'trailer' or 'trailers'. Thanks for your help.
Junkyard 0 Posted November 23, 2013 Posted November 23, 2013 WOW guys it's looking really good even at this early stage. So many things to like about it already!! Well done and thank you for all your effort so far.
