lorac 119 Posted June 23, 2016 Posted June 23, 2016 Do you have it set up for 7.1 under the audio settings in emby? Make sure bitstreaming is also enabled Sent from my STV100-3 using Tapatalk
in2survive 0 Posted June 23, 2016 Posted June 23, 2016 Do you have it set up for 7.1 under the audio settings in emby? Make sure bitstreaming is also enabled Sent from my STV100-3 using Tapatalk Yes, it is all there. I have a similar VM setup with Plex, which is able to play ATMOS. I have the exact same configuration on the Linux network side of the house... I find odd that I can't scroll down past WASAPI audio device. What you see below is all I can see, I really don't know what choice I have under that.
rui no onna 1 Posted June 24, 2016 Posted June 24, 2016 Background brightness and options to turn off theme music and video backdrops would be great to add to this section Question, is this an available option yet and if it is, where can I find it? For the life of me, I can't find a way to disable theme music and video backdrops on Emby Theater (running the latest version). Thanks!
AdrianW 1058 Posted June 24, 2016 Posted June 24, 2016 Question, is this an available option yet and if it is, where can I find it? For the life of me, I can't find a way to disable theme music and video backdrops on Emby Theater (running the latest version). Thanks! There's still no option - I ended up deleting all my theme music and video backdrops. They were just too annoying.
Luke 42241 Posted June 28, 2016 Author Posted June 28, 2016 You can now setup external players for Games. Please try it out and report any feedback. Currently it's one player per game system, so you can't do custom players for specific games (yet). Thanks for crazybbs for helping on this. 2
TrainAss 22 Posted June 28, 2016 Posted June 28, 2016 You can now setup external players for Games. Please try it out and report any feedback. Currently it's one player per game system, so you can't do custom players for specific games (yet). Thanks for crazybbs for helping on this. My server is just doing a database clean (just upgraded to server build 3.1.6023.8862), but once it's done I'll let you know how it works for NES and SNES games (using NESter and zSNES)
Luke 42241 Posted June 29, 2016 Author Posted June 29, 2016 Lots of people have forked the default skin but not too many have publicized their intentions
TrainAss 22 Posted June 29, 2016 Posted June 29, 2016 (edited) @@Luke I have my games list setup in GameBrowser III, added a games library, run a full library refresh yet in Emby Theater 2.4.4 when trying to add the emulator, the list is empty. Server version is 3.1.6023.8862 I've attached the server log, and pasted all that shows in the Theater log. 2016-06-28 19:12:43.8581 Info App: Application version: 2.4.4.02016-06-28 19:12:43.9353 Info App: Application configuration:{"EnableDebugLevelLogging":false,"EnableAutoUpdate":true,"SystemUpdateLevel":"Release","LogFileRetentionDays":3,"RunAtStartup":false,"IsStartupWizardCompleted":true,"EnableCustomPathSubFolders":false}2016-06-28 19:12:43.9409 Info App: Loading MediaBrowser.Model, Version=3.1.5998.21167, Culture=neutral, PublicKeyToken=null2016-06-28 19:12:43.9409 Info App: Loading MediaBrowser.Common, Version=3.1.5998.21166, Culture=neutral, PublicKeyToken=null2016-06-28 19:12:43.9409 Info App: Loading MediaBrowser.Common.Implementations, Version=3.1.5998.21164, Culture=neutral, PublicKeyToken=null2016-06-28 19:12:43.9409 Info App: Loading Emby.Theater, Version=2.4.4.0, Culture=neutral, PublicKeyToken=null2016-06-28 19:12:44.1143 Info TaskManager: Daily trigger for Start new log file set to fire at 6/29/2016 12:00:00 AM, which is 287.26476064 minutes from now.2016-06-28 19:12:44.1143 Info App: Core startup complete2016-06-28 19:12:44.1268 Info App: C:\Users\armst\AppData\Roaming\Emby-Theater\system\x64\electron\electron.exe "C:\Users\armst\AppData\Roaming\Emby-Theater\system\electronapp" "C:\Users\armst\AppData\Roaming\Emby-Theater\data\electron"2016-06-28 19:12:44.5299 Info App: attempting to load pfx:2016-06-28 19:12:44.5299 Error App: Secure requested, but no certificate found at:2016-06-28 19:12:44.5891 Info App: Setting window state to Normal2016-06-28 19:12:44.5891 Info App: SyncWindowSize Top=0 Left=0 Width=1920 Height=10402016-06-28 19:12:47.1280 Info TaskManager: StartupTrigger fired for task: Check for application updates2016-06-28 19:12:47.1280 Info TaskManager: Queueing task SystemUpdateTask2016-06-28 19:12:47.1280 Info TaskManager: Executing Check for application updates2016-06-28 19:12:47.1666 Info HttpClient: HttpClientManager GET: https://api.github.com/repos/MediaBrowser/Emby.Theater.Windows/releases2016-06-28 19:12:48.2346 Debug App: No application update available.2016-06-28 19:12:48.2346 Info TaskManager: Check for application updates Completed after 0 minute(s) and 1 seconds2016-06-28 19:12:48.2561 Info TaskManager: ExecuteQueuedTasks2016-06-28 19:12:49.8561 Info App: Http POST windowsize2016-06-28 19:13:09.7876 Debug App: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 2834897547db4b63aa8450916a9ad3922016-06-28 19:13:22.7146 Info App: Http POST windowstate-Minimized2016-06-28 19:13:22.7146 Info App: Setting window state to minimized2016-06-28 19:13:46.0270 Info App: Http POST windowstate-Normal2016-06-28 19:13:46.0270 Info App: Setting window state to normal2016-06-28 19:14:29.1485 Debug App: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: e957f6221f304d51ba5930e022faad1a Log.txt Edited June 29, 2016 by TrainAss
Luke 42241 Posted June 29, 2016 Author Posted June 29, 2016 Make sure you have configured the game systems within gamebrowser setup.
TrainAss 22 Posted June 29, 2016 Posted June 29, 2016 Make sure you have configured the game systems within gamebrowser setup. They're set correctly. I even went back and re-did them. In both the WebUI and the Theater client, it just shows a mass group of games, nothing is broken down in to systems.
mentasm 43 Posted June 29, 2016 Posted June 29, 2016 (edited) Lots of people have forked the default skin but not too many have publicized their intentions I was trying to work out how to do it last night. I just want to re-order the TV shows page to put latest episodes to the left. I can see the file I need to edit to make my changes but don't understand enough about github and how to complie it all to test it and make it happen Edited June 29, 2016 by mentasm
Luke 42241 Posted June 29, 2016 Author Posted June 29, 2016 I was trying to work out how to do it last night. I just want to re-order the TV shows page to put latest episodes to the left. I can see the file I need to edit to make my changes but don't understand enough about github and how to complie it all to test it and make it happen How far did you get with Github?
mentasm 43 Posted June 30, 2016 Posted June 30, 2016 (edited) Not very far. I basically went trawling through the files on the Web site and found what I think I needed to change. Did find some instructions in the Readme but didn't go any further. I do have a github account so might have a look when I have some time. Not a coder. System and infrastructure engineer. Edit, think I made a few steps forward with it today. Need to get home onto my media centre and have a play. Can't do much from here at work as the proxy stops access working for tv.emby.media Edited June 30, 2016 by mentasm
Luke 42241 Posted July 1, 2016 Author Posted July 1, 2016 Here's a forked version of the default skin: http://emby.media/community/index.php?/topic/36440-forking-and-editting-the-default-skin/ Those of you handy with html and javascript should team up with him and see what you can create.
schmitty 66 Posted July 1, 2016 Posted July 1, 2016 I have forked the default skin. The main thing I would attempt to do, is show ratings icons, and a few other minor cosmetic changes. 1
Luke 42241 Posted July 1, 2016 Author Posted July 1, 2016 @@Xzener loves rating icons. I'm sure he can help with selecting them.
schmitty 66 Posted July 1, 2016 Posted July 1, 2016 I already have them stored in metadata\MediaInfo\All 1
Xzener 729 Posted July 1, 2016 Posted July 1, 2016 Oh... Oh... A new ET skin?!?! Sweet!! Lemme know if you need any design help @@schmitty. 2
schmitty 66 Posted July 3, 2016 Posted July 3, 2016 Ok @@Xzener, will do. I'm just trying to find the correct items to change.
schmitty 66 Posted July 3, 2016 Posted July 3, 2016 I have performed a search in videoosd, nowplaying and item .css, .js and .html for parental and rating, and have found no results
Luke 42241 Posted July 3, 2016 Author Posted July 3, 2016 search for OfficialRating. it's currently being rendered in plain text so you'll have to swap that for images.
Luke 42241 Posted July 3, 2016 Author Posted July 3, 2016 Sorry, its actually being handled by a shared component that lives here:https://github.com/MediaBrowser/emby-webcomponents/tree/master/mediainfoIt's shared by both theater and the mobile web app until they merge. The intention was for the shared component to generate there markup and for skins to style as they please.But skins don't have to use the shared component and can instead create their own version. So it sounds like that's what you want to do. You need to copy part of that mediainfo object into your skin and use that instead of the shared version.It's not hard. @@softworkz is good at this.
