schmitty 66 Posted May 20, 2016 Posted May 20, 2016 Is there a way to get Australian ratings images to show in coverart, series, episodes and movie info screens? I have them stored under \\SERVER\Emby\ImagesByName\MediaInfo\All
Heuer 76 Posted May 20, 2016 Posted May 20, 2016 Delete function is now available Great to have this however after deleting (from 'Live TV') it takes you back to the Home screen. This means deleting multiple shows is a pain. It would be better if after delete it took you one step back to the recordings screen.
puithove 209 Posted May 20, 2016 Posted May 20, 2016 Great to have this however after deleting (from 'Live TV') it takes you back to the Home screen. This means deleting multiple shows is a pain. It would be better if after delete it took you one step back to the recordings screen. I wanted to report the same. It also adds that to the navigation stack, so "back" takes you back to something that is no longer there - and if you delete multiple recordings, your stack gets pretty deep to go back through in order to get to the point where "back" will open the settings.
Luke 42241 Posted May 20, 2016 Author Posted May 20, 2016 I've implemented keyboard shortcuts to match windows media center, ctrl+g and ctrl+t for the guide and live tv. 1
Nikolaech 32 Posted May 20, 2016 Posted May 20, 2016 I've implemented keyboard shortcuts to match windows media center, ctrl+g and ctrl+t for the guide and live tv. In both cases, the guide opens. The remote control doesn't work for me.
Luke 42241 Posted May 20, 2016 Author Posted May 20, 2016 yea i went cheap for now and just had them both open the guide since we don't really have a separate live tv screen.
Nikolaech 32 Posted May 21, 2016 Posted May 21, 2016 For example, you can open the last viewed channel. It would be cool. 2
hpooni 6 Posted May 21, 2016 Posted May 21, 2016 Channel Up (Page Up) and Channel Down (Page Down) while watching TV would also be nice. 4
puithove 209 Posted May 21, 2016 Posted May 21, 2016 Channel Up (Page Up) and Channel Down (Page Down) while watching TV would also be nice. Yes please, and also fix the grid guide so that page up/down moves the cursor to the new spot. Right now it scrolls the page, but the cursor stays on the same line it was on. 1
SikSlayer 254 Posted May 21, 2016 Posted May 21, 2016 Channel Up (Page Up) and Channel Down (Page Down) while watching TV would also be nice. Yes please, and also fix the grid guide so that page up/down moves the cursor to the new spot. Right now it scrolls the page, but the cursor stays on the same line it was on. Yes well, Page Up and Page Down needs to be implemented in a number of places. 1
sangerhonda 2 Posted May 22, 2016 Posted May 22, 2016 Is it possible to add the ability to select "pictures" for screen saver in addition to back drops? 1
Luke 42241 Posted May 22, 2016 Author Posted May 22, 2016 Is it possible to add the ability to select "pictures" for screen saver in addition to back drops? It's a great idea for the future. 1
Luke 42241 Posted May 22, 2016 Author Posted May 22, 2016 Good news - "Add to Collection" is now available in the 3-dot menu.
Luke 42241 Posted May 22, 2016 Author Posted May 22, 2016 Just a heads up with 2.3.7, on a one-time basis, your data will be reset and you'll need to reconnect to your server again. I've resolved the issue of the electron cache not getting stored in the app's data directory, and changing the location also means starting with a clean slate. thanks.
Guest asrequested Posted May 23, 2016 Posted May 23, 2016 I have a suggestion/request for music playback in ET. Presently, whn I select an album I see the cover, track list, etc. So here you can click on a song and it will play....BUT...there's no indication on this page that it's playing, let alone any control. For that you have to click the music note at the top, which takes you here From here you can pause, play the track. Now, if you want to skip to another, specific track, you have to click to yet another page. This gives you the play list and you click whatever track you want, but there's no further control, and this page tends not to always function well (sometimes hangs or skips). Here's my suggestion. When you click to play a track on the first screen, have the controls appear on that screen, if not directly on the track. This would eliminate having to go to another screen just for the purpose of pausing, stopping, etc. This would also eliminate the need for he third screen, which could be reserved purely for playlist operation, should one be made.
Luke 42241 Posted May 23, 2016 Author Posted May 23, 2016 My plan is to have starting audio playback take you to the now playing screen, if that's what you mean, yes. But this is an app designed for a remote so the controls are not going to be present on every screen. Maybe one day later that can happen when the mobile and desktop layouts get further enhanced.
Guest asrequested Posted May 23, 2016 Posted May 23, 2016 (edited) My plan is to have starting audio playback take you to the now playing screen, if that's what you mean, yes. But this is an app designed for a remote so the controls are not going to be present on every screen. Maybe one day later that can happen when the mobile and desktop layouts get further enhanced. No, I'm suggesting only one screen. Have it all happen here When you select the track, have the play/pause appear on that track. It will also serve to let you know which track is playing. Don't even have a now playing screen. Edited May 23, 2016 by Doofus
Guest asrequested Posted May 23, 2016 Posted May 23, 2016 Right now, when you click to play a track, that track goes to the top of the now playing, which changes the order of the music.
the1poet 5 Posted May 23, 2016 Posted May 23, 2016 Since moving house a month ago I've been unable to get fixed internet, so I've resorted to Kodi and the plugin for now. Is Emby Theater still needing internet access and updating constantly still? Just wondering when I can go back to the Emby client, as it's not feasible for me at the moment if it's still in dev mode.
Luke 42241 Posted May 23, 2016 Author Posted May 23, 2016 Right now it requires an internet connection, yes.
Luke 42241 Posted May 23, 2016 Author Posted May 23, 2016 I've improved the performance of the horizontal scroll on Xbox One - or rather, resolved an issue that was recently created relating to that.
pünktchen 1411 Posted May 24, 2016 Posted May 24, 2016 What makes me always wonder when testing Theater, why is live tv "Channels" under "Recordings"? (Doesn't make any sense) It would be better suit to the homescreen:
Guest asrequested Posted May 24, 2016 Posted May 24, 2016 I LOVE the new update. No more endless scrolling! Great job, Luke!
