Ghostm 75 Posted July 30, 2014 Posted July 30, 2014 (edited) I have an ati 5770 in my desktop its working fairly well on as well. But my htpc im adding a R9 270 shortly. Currently I have an A10 integrated gpu and it cannot handle it in my htpc. Another thing people might want to try is disabling hardware acceleration, i actually get smooth playback on my 5770 with it disabled for some reason. I think some people need to keep in mind its easy to use madvr with mpc-hc because of full screen exclusive and the lightweight gui, but mbt has a very nice gui/osd and i love the fact you can bring up actors/scene selection/movie synopsis, i dont think that would be possible in fullscreen exclusive, some wont care about that but i do, but as of right now to do all that stuff you need a decent gpu with madvr being used inside the mbt gui. Edited July 30, 2014 by Ghostm
Luke 42239 Posted July 31, 2014 Author Posted July 31, 2014 Just put a dev build that adds a new config setting under Video. You can control max streaming bitrate if you're away from home or if the content has to be streamed for whatever reason.
Ghostm 75 Posted July 31, 2014 Posted July 31, 2014 (edited) This will be useful for some users for sure i seen a few requests on here for it. Out of curiosity could we also have an option to turn it off completely, my mbt does duties playing full bluray copies and i want to avoid transcoding, 40mbps is pretty high but i know some blu rays can have short bursts where they go beyond 40mbps. I seen at least two high bitrate bluray force trancoding even at 40mbps trying this out which i want to avoid especially on a slower pc (one was the watchmen director cut from the UK), i want to direct play everything to mbt. I know bluray standard has a maximum bitrate of 40mpbs but i think their is some caveats where it can exceed 40mbps for a short time frame. Otherwise i tried setting the bitrate to 8 and it definitely works fine. Edited July 31, 2014 by Ghostm 1
bulls 1 Posted August 2, 2014 Posted August 2, 2014 (edited) yeah whats up with that ...40mbs network streaming over my "1000mbs" network is still choppy Edited August 2, 2014 by bulls
shaefurr 1340 Posted August 3, 2014 Posted August 3, 2014 What happened to the movie resume section? now we just have 3 random movie titles in its place, isnt that what the spotlight is for...?
blublub 10 Posted August 3, 2014 Posted August 3, 2014 Hi I currently use Mediaportal as my main software and I switch randomly to MBT to play a little. I have noticed that video quality with MBT set to LAV is a lot different than with Mediaportal which also uses LAV. It looks actually pretty ugly in MBT. when I switch do MadVR it does look good - maybe a little better than MePo but thats hard to tell without side by side comparison. Does any one have an idea what could be the problem?
psykix 97 Posted August 3, 2014 Posted August 3, 2014 Hi I currently use Mediaportal as my main software and I switch randomly to MBT to play a little. I have noticed that video quality with MBT set to LAV is a lot different than with Mediaportal which also uses LAV. It looks actually pretty ugly in MBT. when I switch do MadVR it does look good - maybe a little better than MePo but thats hard to tell without side by side comparison. Does any one have an idea what could be the problem? I never had much success with the internal MBT player to be honest - panning scenes were juddering slightly and I seemed to have lip sync issues. It could have been configuration issues at my end. Using MadVR however is worlds apart. Picture is superb. If MadVR works well for you then stick with that maybe? My whole reason for using MBT (and its USP as far as I am concerned) is the fact that it CAN use MadVR.
swhitmore 781 Posted August 3, 2014 Posted August 3, 2014 I keep meaning to try MadVR. Is there much to setting it up?
psykix 97 Posted August 3, 2014 Posted August 3, 2014 I keep meaning to try MadVR. Is there much to setting it up? Yeah, a fair bit... I followed a guide here http://garteal.hostoi.com/how-to-setup-media-player-classic-home-cinema/ (just ignore the MPC-HC stuff unless you want to use the external player - but then you lose the overlay and resume states) 1
psykix 97 Posted August 3, 2014 Posted August 3, 2014 Once you are using MadVR, CTRL+J toggles the stats. Then do a CTRL-R to reset them as you will get some initial dropped frames. Then you can monitor the queues and dropped frames to make sure your performance is ok :-) 1
Koleckai Silvestri 1154 Posted August 3, 2014 Posted August 3, 2014 You have to go into the XML configuration for MBT and turn off the custom video renderer to get any kind of decent playback without using an external player. I am guessing it was designed to help and provide better playback but it destroys the quality of anything less than 1080p. Just search the XML for custom and change true to false on that line. Restart the client and you should get better quality.
shaefurr 1340 Posted August 3, 2014 Posted August 3, 2014 I keep meaning to try MadVR. Is there much to setting it up? You should definitely give it a try, the difference is amazing on SD content. Using a guide it only takes a few minutes to setup. 1
Luke 42239 Posted August 3, 2014 Author Posted August 3, 2014 madvr seems like a throwback nowadays to the era of the big honkin, complicated htpc. sure it might look a little better, but give me an android tv that just works and i'm much happier. 2
Luke 42239 Posted August 3, 2014 Author Posted August 3, 2014 Yup. People want it so we'll give it to them 1
bulls 1 Posted August 3, 2014 Posted August 3, 2014 You have to go into the XML configuration for MBT and turn off the custom video renderer to get any kind of decent playback without using an external player. I am guessing it was designed to help and provide better playback but it destroys the quality of anything less than 1080p. Just search the XML for custom and change true to false on that line. Restart the client and you should get better quality. ist that related to Madvr only or in general ??
shaefurr 1340 Posted August 3, 2014 Posted August 3, 2014 (edited) ist that related to Madvr only or in general ?? In general, SD playback looks pixelated and terrible unless you change it. See this post for some screens http://mediabrowser.tv/community/index.php?/topic/7586-videos-are-very-pixelated/?hl=pixelated Edited August 3, 2014 by shaefurr
Koleckai Silvestri 1154 Posted August 4, 2014 Posted August 4, 2014 ist that related to Madvr only or in general ?? General. I don't use an external player. Mostly because it is too much work to setup and maintain.
swhitmore 781 Posted August 4, 2014 Posted August 4, 2014 Thanks guys. Gave it a go last night. I haven't played with the settings too much yet, but I can see a slight difference. Most of my content is 1080p though, so its not that noticeable on that stuff. It was easy to setup. (sorry for derailing the thread, back to MBT now) I noticed last night that I can no longer press 'play' on items from the menu screen. I'll post some logs tonight, but if anyone else getting this issue?
bulls 1 Posted August 5, 2014 Posted August 5, 2014 im putting the computer to sleep now, but the issue is -when it wakes up- the MBT crashes , it says something like no connection to server, click ok, then crash, so it diesnt seem to have a tolerance/retry for network interruptions (im on win 7)
Koleckai Silvestri 1154 Posted August 5, 2014 Posted August 5, 2014 im putting the computer to sleep now, but the issue is -when it wakes up- the MBT crashes , it says something like no connection to server, click ok, then crash, so it diesnt seem to have a tolerance/retry for network interruptions (im on win 7) This has been an issue for a long time. Hoping the refactoring handles it and it is available soon. 1
Ghostm 75 Posted August 5, 2014 Posted August 5, 2014 im putting the computer to sleep now, but the issue is -when it wakes up- the MBT crashes , it says something like no connection to server, click ok, then crash, so it diesnt seem to have a tolerance/retry for network interruptions (im on win 7) Are you on the latest dev? I used to have this issue, but have not had it for awhile. I have my pc set to sleep after 25 minutes.
Danee 57 Posted August 5, 2014 Posted August 5, 2014 If I remember correctly this had to do with the MBT screensaver, if the system went to sleep after the screensaver had started it would have a problem when woken up. 1
Ghostm 75 Posted August 5, 2014 Posted August 5, 2014 If I remember correctly this had to do with the MBT screensaver, if the system went to sleep after the screensaver had started it would have a problem when woken up. Ah yes, forgot why i no longer have this issue, i turned off the screen saver.
Koleckai Silvestri 1154 Posted August 11, 2014 Posted August 11, 2014 Don't know of one. The Github project hasn't had any issues closed since July 11th.
