Ghostm 75 Posted January 21, 2014 Posted January 21, 2014 Just curious trying to apply an update i keep getting during startup. Error attempting to update application Directory Not found Could not find a part of the path. The issue im seeing is its looking for C:\Users\HTPC\AppData\Roaming\System\MediaBrowser.Updater.exe And the path to the updater should be C:\Users\HTPC\AppData\Roaming\MediaBrowser-Theater\System\MediaBrowser.Updater.exe
Ghostm 75 Posted January 21, 2014 Posted January 21, 2014 (edited) Actually seen this. http://mediabrowser.tv/community/index.php?/topic/4056-update-check-not-working-after-update/ my concern with doing a fresh install, and correct me if i am wrong, I would have to reconfigure everything?I have game launchers setup (5 of them) and using the program launcher created a few of them as well, I am guessing I will loose those? Edit-Actually nevermind, took a chance and didnt appear to loose any settings. Edit Again-Actually its back so i guess it means to fix it I need to do complete uninstall of media browser theater, then a complete reinstall which will remove all settings.... Edited January 21, 2014 by Ghostm
Ghostm 75 Posted January 22, 2014 Posted January 22, 2014 Just to clarify for anyone else, what I tried to do was turn off the server, and when that happens it asks to install and setup mbt again, that did not work. I had to download the setup.exe and run that again. I only lost my program launchers that i had previously setup.
ronvp 92 Posted January 28, 2014 Posted January 28, 2014 I am unable to have TMT to just play the 3D MP4 files.. When I configure MBT to play 3D files without any file type selected, it plays all files in the internal player. when I select MP4 and 3D, it play all MP4 files in TMT including non 3D MBC allows for configuration to play only 3D MP4 files in the external player. Regular Mp4 use the internal player 1
Davidtt485 6 Posted January 28, 2014 Posted January 28, 2014 See my thread for additional 3D support, i have the same issue with 3D MkV's
Luke 42237 Posted January 30, 2014 Author Posted January 30, 2014 There's a new build up that adds search and more settings to the video player. We had two different contributors work on them (Shaun and Andy) and they both did a really nice job. 1
pmac 143 Posted January 30, 2014 Posted January 30, 2014 (edited) @@Luke, for some reason the latest build won't let me play any files, here's my log: EDIT: I was watching a video in the previous build, and stopped partway through and quit. I went back in later and it updated, now my files won't play. 2014-01-29 22:03:50.1231 Info - App: Application Configuration: {"ServerHostName":"127.0.0.1","ServerApiPort":8096,"AutoLoginConfiguration":{},"MediaPlayers":[],"WindowState":"Maximized","WindowTop":-8,"WindowLeft":-8,"WindowWidth":1934,"WindowHeight":1094,"EnableHighQualityImageScaling":true,"EnableBackdrops":true,"DownloadCompressedImages":false,"InternalPlayerConfiguration":{"EnableReclock":false,"EnableMadvr":false,"EnableXySubFilter":true,"VideoConfig":{"HwaMode":-1,"HwaResolution":3,"UseMadVrSmoothMotion":true,"MadVrSmoothMotionMode":"avoidJudder","HwaEnabledCodecs":[],"EnabledCodecs":[]},"AudioConfig":{"AudioBitstreaming":"None","Delay":0,"EnableAutoSync":true,"ConvertToStandardLayout":true,"ExpandMono":false,"Expand61":false,"EnableDRC":false,"DRCLevel":100,"EnablePCMMixing":false,"MixingEncoding":"None","MixingLayout":"Stereo","MixingSetting":4,"LfeMixingLevel":0,"CenterMixingLevel":0.7071,"SurroundMixingLevel":0.7071,"EnabledCodecs":[]}},"EnableDebugLevelLogging":false,"EnableAutoUpdate":true,"SystemUpdateLevel":"Release","LogFileRetentionDays":3,"RunAtStartup":false,"IsStartupWizardCompleted":true} 2014-01-29 22:03:50.1431 Info - App: Loading MediaBrowser.Plugins.ProgramLauncher, Version=1.0.5125.23065, Culture=neutral, PublicKeyToken=null 2014-01-29 22:03:50.1431 Info - App: Loading MediaBrowser.Plugins.WindowsMediaCenter, Version=1.0.5033.14637, Culture=neutral, PublicKeyToken=null 2014-01-29 22:03:50.1431 Info - App: Loading MediaBrowser.Model, Version=3.0.5142.22120, Culture=neutral, PublicKeyToken=null 2014-01-29 22:03:50.1431 Info - App: Loading MediaBrowser.Common, Version=3.0.5142.22121, Culture=neutral, PublicKeyToken=null 2014-01-29 22:03:50.1431 Info - App: Loading MediaBrowser.Common.Implementations, Version=3.0.5142.22121, Culture=neutral, PublicKeyToken=null 2014-01-29 22:03:50.1431 Info - App: Loading MediaBrowser.UI, Version=3.0.5142.39299, Culture=neutral, PublicKeyToken=null 2014-01-29 22:03:50.1431 Info - App: Loading MediaBrowser.Theater.DirectShow, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2014-01-29 22:03:50.1431 Info - App: Loading MediaBrowser.Theater.Presentation, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2014-01-29 22:03:50.1431 Info - App: Loading MediaBrowser.Theater.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2014-01-29 22:03:50.1431 Info - App: Loading MediaBrowser.IsoMounter, Version=1.0.5079.1480, Culture=neutral, PublicKeyToken=null 2014-01-29 22:03:50.1431 Info - App: Loading MediaBrowser.Plugins.DefaultTheme, Version=3.0.5142.39298, Culture=neutral, PublicKeyToken=null 2014-01-29 22:03:50.1911 Info - App: Version 3.0.5142.39299 initializing 2014-01-29 22:03:50.2041 Debug - ApiClient: Applying Authorization http header: Client="Media Browser Theater", DeviceId="PATRICK-HP", Device="PATRICK-HP", Version="3.0.5142.39299" 2014-01-29 22:03:50.4021 Info - App: HttpClientManager POST: http://www.mb3admin.com/admin/service/registration/validate 2014-01-29 22:03:50.4751 Info - App: Core startup complete 2014-01-29 22:03:50.4751 Info - App: Adding resource ResourceDictionary 2014-01-29 22:03:50.4751 Info - App: Loading theme: Default 2014-01-29 22:03:50.4851 Info - App: Adding resource ResourceDictionary 2014-01-29 22:03:50.6541 Debug - ApiClient: GET http://127.0.0.1:8096/mediabrowser/System/Info?format=json 2014-01-29 22:03:50.6551 Debug - ApiClient: GET http://127.0.0.1:8096/mediabrowser/System/Info?format=json 2014-01-29 22:03:50.7161 Debug - ApiClient: Received OK status code after 61.0035 ms from GET: http://127.0.0.1:8096/mediabrowser/System/Info?format=json 2014-01-29 22:03:50.7301 Debug - ApiClient: Received OK status code after 69.004 ms from GET: http://127.0.0.1:8096/mediabrowser/System/Info?format=json 2014-01-29 22:03:50.7701 Info - ApiWebSocket: Created new web socket of type WebSocket4NetClientWebSocket 2014-01-29 22:03:50.7891 Debug - ApiClient: GET http://127.0.0.1:8096/mediabrowser/System/Configuration?format=json 2014-01-29 22:03:50.7891 Debug - ApiClient: Received OK status code after 3.0002 ms from GET: http://127.0.0.1:8096/mediabrowser/System/Configuration?format=json 2014-01-29 22:03:50.7971 Info - ApiWebSocket: Connected to ws://127.0.0.1:8945/mediabrowser 2014-01-29 22:03:50.7971 Info - ApiWebSocket: Sending web socket identification message Media Browser Theater|PATRICK-HP|3.0.5142.39299|PATRICK-HP 2014-01-29 22:03:50.7971 Debug - ApiClient: GET http://127.0.0.1:8096/mediabrowser/System/Info?format=json 2014-01-29 22:03:50.7971 Debug - ApiClient: GET http://127.0.0.1:8096/mediabrowser/System/Info?format=json 2014-01-29 22:03:50.8411 Debug - ApiClient: Received OK status code after 37.0021 ms from GET: http://127.0.0.1:8096/mediabrowser/System/Info?format=json 2014-01-29 22:03:50.8441 Debug - App: Navigating to LoginPage 2014-01-29 22:03:50.8441 Debug - ApiClient: GET http://127.0.0.1:8096/mediabrowser/Users/Public?format=json 2014-01-29 22:03:50.8701 Debug - ApiClient: Received OK status code after 65.0038 ms from GET: http://127.0.0.1:8096/mediabrowser/System/Info?format=json 2014-01-29 22:03:50.8701 Debug - App: Navigation complete to LoginPage 2014-01-29 22:03:50.8791 Debug - ApiClient: Received OK status code after 25.0015 ms from GET: http://127.0.0.1:8096/mediabrowser/Users/Public?format=json 2014-01-29 22:03:52.3102 Debug - ApiClient: GET http://127.0.0.1:8096/mediabrowser/System/Info?format=json 2014-01-29 22:03:52.3632 Debug - ApiClient: Received OK status code after 52.003 ms from GET: http://127.0.0.1:8096/mediabrowser/System/Info?format=json 2014-01-29 22:03:52.3632 Debug - ApiClient: POST http://127.0.0.1:8096/mediabrowser/Users/AuthenticateByName?format=json 2014-01-29 22:03:52.3712 Debug - ApiClient: Received OK status code after 2.0001 ms from POST: http://127.0.0.1:8096/mediabrowser/Users/AuthenticateByName?format=json 2014-01-29 22:03:52.3712 Debug - ApiClient: Applying Authorization http header: Client="Media Browser Theater", DeviceId="PATRICK-HP", Device="PATRICK-HP", Version="3.0.5142.39299", UserId="27a8b3d3a00ba7d7bff28e838cf5d674" 2014-01-29 22:03:52.3712 Info - ApiWebSocket: Received web socket message: UserUpdated 2014-01-29 22:03:52.3882 Debug - ApiClient: GET http://127.0.0.1:8096/mediabrowser/Users/27a8b3d3a00ba7d7bff28e838cf5d674/Items/Root?format=json 2014-01-29 22:03:52.3882 Debug - ApiClient: Received OK status code after 2.0001 ms from GET: http://127.0.0.1:8096/mediabrowser/Users/27a8b3d3a00ba7d7bff28e838cf5d674/Items/Root?format=json 2014-01-29 22:03:52.5112 Debug - App: Navigating to HomePage 2014-01-29 22:03:52.5122 Debug - ApiClient: GET http://127.0.0.1:8096/mediabrowser/Items/Counts?UserId=27a8b3d3a00ba7d7bff28e838cf5d674&format=json 2014-01-29 22:03:52.5432 Info - App: Adding resource ResourceDictionary 2014-01-29 22:03:52.5432 Debug - App: Navigation complete to HomePage 2014-01-29 22:03:53.4843 Info - App: StartupTrigger fired for task: Check for application updates 2014-01-29 22:03:53.4843 Info - App: StartupTrigger fired for task: Check for plugin updates 2014-01-29 22:03:53.4843 Info - App: StartupTrigger fired for task: Log file cleanup 2014-01-29 22:03:53.4843 Info - App: StartupTrigger fired for task: Cache file cleanup 2014-01-29 22:03:53.4843 Debug - ApiClient: Received OK status code after 967.0553 ms from GET: http://127.0.0.1:8096/mediabrowser/Items/Counts?UserId=27a8b3d3a00ba7d7bff28e838cf5d674&format=json 2014-01-29 22:03:53.4843 Info - App: Executing Check for plugin updates 2014-01-29 22:03:53.4843 Info - App: Executing Log file cleanup 2014-01-29 22:03:53.4843 Info - App: Executing Cache file cleanup 2014-01-29 22:03:53.4843 Info - App: Executing Check for application updates 2014-01-29 22:03:53.4963 Debug - ApiClient: GET http://127.0.0.1:8096/mediabrowser/System/Info?format=json 2014-01-29 22:03:53.4963 Info - App: HttpClientManager GET: http://www.mb3admin.com/admin/service/MB3Packages.json 2014-01-29 22:03:53.4963 Info - App: StartupTrigger fired for task: Collect stats 2014-01-29 22:03:53.4963 Info - App: Executing Collect stats 2014-01-29 22:03:53.4963 Info - App: Log file cleanup Completed after 0 minute(s) and 0 seconds 2014-01-29 22:03:53.5523 Debug - ApiClient: Received OK status code after 55.0032 ms from GET: http://127.0.0.1:8096/mediabrowser/System/Info?format=json 2014-01-29 22:03:53.5523 Info - App: HttpClientManager GET: http://www.mb3admin.com/admin/service/MB3Packages.json 2014-01-29 22:03:53.5643 Info - App: Cache file cleanup Completed after 0 minute(s) and 0 seconds 2014-01-29 22:03:53.6043 Info - App: HttpClientManager POST: http://www.mb3admin.com/admin/service/registration/ping 2014-01-29 22:03:53.9953 Debug - ApiClient: GET http://127.0.0.1:8096/mediabrowser/MBT/DefaultTheme/Movies?familyrating=pg&userId=27a8b3d3a00ba7d7bff28e838cf5d674&ComedyGenre=comedy&RomanceGenre=romance&FamilyGenre=family&LatestMoviesLimit=16&LatestTrailersLimit=6&format=json 2014-01-29 22:03:54.0363 Info - App: Collect stats Completed after 0 minute(s) and 0 seconds 2014-01-29 22:03:54.4693 Info - App: Check for plugin updates Completed after 0 minute(s) and 0 seconds 2014-01-29 22:03:54.6533 Debug - App: No application update available. 2014-01-29 22:03:54.6533 Info - App: Check for application updates Completed after 0 minute(s) and 1 seconds 2014-01-29 22:03:55.0284 Debug - ApiClient: Received OK status code after 1032.059 ms from GET: http://127.0.0.1:8096/mediabrowser/MBT/DefaultTheme/Movies?familyrating=pg&userId=27a8b3d3a00ba7d7bff28e838cf5d674&ComedyGenre=comedy&RomanceGenre=romance&FamilyGenre=family&LatestMoviesLimit=16&LatestTrailersLimit=6&format=json 2014-01-29 22:03:57.8635 Debug - ApiClient: GET http://127.0.0.1:8096/mediabrowser/Users/27a8b3d3a00ba7d7bff28e838cf5d674/Items/ef460db61b1d2d2bb2a2bcce13575057?format=json 2014-01-29 22:03:58.1515 Debug - ApiClient: Received OK status code after 287.0164 ms from GET: http://127.0.0.1:8096/mediabrowser/Users/27a8b3d3a00ba7d7bff28e838cf5d674/Items/ef460db61b1d2d2bb2a2bcce13575057?format=json 2014-01-29 22:03:58.2095 Debug - App: Navigating to DetailPage 2014-01-29 22:03:58.2245 Debug - ApiClient: GET http://127.0.0.1:8096/mediabrowser/Items/ef460db61b1d2d2bb2a2bcce13575057/CriticReviews?format=json 2014-01-29 22:03:58.2245 Debug - App: Navigation complete to DetailPage 2014-01-29 22:03:58.2416 Debug - ApiClient: GET http://127.0.0.1:8096/mediabrowser/Items/ef460db61b1d2d2bb2a2bcce13575057/ThemeMedia?InheritFromParent=True&UserId=27a8b3d3a00ba7d7bff28e838cf5d674&format=json 2014-01-29 22:03:58.2416 Debug - ApiClient: Received OK status code after 2.0001 ms from GET: http://127.0.0.1:8096/mediabrowser/Items/ef460db61b1d2d2bb2a2bcce13575057/ThemeMedia?InheritFromParent=True&UserId=27a8b3d3a00ba7d7bff28e838cf5d674&format=json 2014-01-29 22:03:58.2626 Info - App: Removing resource ResourceDictionary 2014-01-29 22:03:58.2626 Debug - ApiClient: GET http://127.0.0.1:8096/mediabrowser/Items/ef460db61b1d2d2bb2a2bcce13575057/Images/Logo?Quality=100&Tag=8434e918-7fcd-1b4f-cb68-8ee53c1130e1&EnableImageEnhancers=True 2014-01-29 22:03:58.2906 Debug - ApiClient: Received OK status code after 66.0038 ms from GET: http://127.0.0.1:8096/mediabrowser/Items/ef460db61b1d2d2bb2a2bcce13575057/CriticReviews?format=json 2014-01-29 22:03:58.8536 Debug - ApiClient: GET http://127.0.0.1:8096/mediabrowser/Items/ef460db61b1d2d2bb2a2bcce13575057/Images/Primary?Width=550&Quality=100&Tag=6f3ecb4b-f2b8-29dc-88f1-4df122013425&EnableImageEnhancers=True 2014-01-29 22:03:58.9206 Debug - ApiClient: Received OK status code after 654.0374 ms from GET: http://127.0.0.1:8096/mediabrowser/Items/ef460db61b1d2d2bb2a2bcce13575057/Images/Logo?Quality=100&Tag=8434e918-7fcd-1b4f-cb68-8ee53c1130e1&EnableImageEnhancers=True 2014-01-29 22:03:59.0746 Debug - ApiClient: Received OK status code after 220.0126 ms from GET: http://127.0.0.1:8096/mediabrowser/Items/ef460db61b1d2d2bb2a2bcce13575057/Images/Primary?Width=550&Quality=100&Tag=6f3ecb4b-f2b8-29dc-88f1-4df122013425&EnableImageEnhancers=True 2014-01-29 22:03:59.1046 Debug - ApiClient: GET http://127.0.0.1:8096/mediabrowser/Items/ef460db61b1d2d2bb2a2bcce13575057/Images/Backdrop/0?Width=1920&Quality=100&Tag=eaccff50-b2da-320c-9a5d-6b8e9469c61c&EnableImageEnhancers=True 2014-01-29 22:03:59.1046 Debug - ApiClient: Received OK status code after 4.0003 ms from GET: http://127.0.0.1:8096/mediabrowser/Items/ef460db61b1d2d2bb2a2bcce13575057/Images/Backdrop/0?Width=1920&Quality=100&Tag=eaccff50-b2da-320c-9a5d-6b8e9469c61c&EnableImageEnhancers=True 2014-01-29 22:04:00.6857 Debug - ApiClient: GET http://127.0.0.1:8096/mediabrowser/Users/27a8b3d3a00ba7d7bff28e838cf5d674/Items/ef460db61b1d2d2bb2a2bcce13575057/Intros?format=json 2014-01-29 22:04:00.6887 Debug - ApiClient: Received OK status code after 3.0002 ms from GET: http://127.0.0.1:8096/mediabrowser/Users/27a8b3d3a00ba7d7bff28e838cf5d674/Items/ef460db61b1d2d2bb2a2bcce13575057/Intros?format=json 2014-01-29 22:04:00.7077 Info - DirectShowPlayer: Playing Watchmen. Reclock: False, Madvr: False, xySubFilter: True 2014-01-29 22:04:00.7077 Info - DirectShowPlayer: Playing Path \\PATRICK-HP\Media Browser2\HD Movies\Watchmen\Watchmen (2009) - [MKV].mkv 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: H264 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: VC1 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: MPEG1 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: MPEG2 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: MPEG4 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: MSMPEG4 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: VP8 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: WMV3 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: WMV12 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: MJPEG 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: Theora 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: FLV1 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: VP6 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: SVQ 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: H261 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: H263 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: Indeo 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: TSCC 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: Fraps 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: HuffYUV 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: QTRle 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: DV 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: Bink 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: Smacker 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: RV34 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: Lagarith 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: Camstudio 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: ZLIB 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: QTRpza 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: PNG 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: ProRes 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: UtVideo 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: Dirac 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: DNxHD 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: MSVideo1 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: EightBPS 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: LOCO 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: ZMBV 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: VCR1 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: Snow 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable support for: FFV1 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable HWA support for: H264 2014-01-29 22:04:04.3689 Debug - DirectShowPlayer: Disable HWA support for: VC1 2014-01-29 22:04:04.3839 Debug - DirectShowPlayer: Disable HWA support for: MPEG2 2014-01-29 22:04:04.3839 Debug - DirectShowPlayer: Disable HWA support for: MPEG2DVD 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: Disable support for: AAC 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: Disable support for: AC3 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: Disable support for: EAC3 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: Disable support for: DTS 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: Disable support for: MP2 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: Disable support for: MP3 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: Disable support for: TRUEHD 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: Disable support for: FLAC 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: Disable support for: VORBIS 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: Disable support for: LPCM 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: Disable support for: PCM 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: Disable support for: WAVPACK 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: Disable support for: TTA 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: Disable support for: Cook 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: Disable support for: RealAudio 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: Disable support for: ALAC 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: Disable support for: Opus 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: Disable support for: AMR 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: Disable support for: Nellymoser 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: Disable support for: MSPCM 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: Disable support for: Truespeech 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: Disable support for: TAK 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: AC3 bitstreaming: False 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: EAC3 bitstreaming: False 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: TRUEHD bitstreaming: False 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: DTS bitstreaming: False 2014-01-29 22:04:04.4039 Debug - DirectShowPlayer: DTSHD bitstreaming: False 2014-01-29 22:04:04.5079 Error - DirectShowPlayer: Error beginning playback There is no common media type between these pins. System.Runtime.InteropServices.COMException at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous) at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args) at System.Windows.Forms.Control.Invoke(Delegate method) at MediaBrowser.Theater.DirectShow.InternalDirectShowPlayer.InvokeOnPlayerThread(Action action) at MediaBrowser.Theater.DirectShow.InternalDirectShowPlayer.<PlayTrack>d__d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Theater.DirectShow.InternalDirectShowPlayer.<Play>d__2.MoveNext() 2014-01-29 22:04:09.0982 Debug - ApiClient: GET http://127.0.0.1:8096/mediabrowser/Items/ef460db61b1d2d2bb2a2bcce13575057/Images/Backdrop/1?Width=1920&Quality=100&Tag=524c9437-e04c-7162-5be7-d4b41f27a9fa&EnableImageEnhancers=True 2014-01-29 22:04:09.2162 Info - App: Disposing ApplicationHost 2014-01-29 22:04:09.2162 Info - App: Disposing TaskManager 2014-01-29 22:04:09.2192 Info - App: Disposing HttpClientManager 2014-01-29 22:04:09.2192 Info - App: Disposing InstallationManager 2014-01-29 22:04:09.2192 Info - App: Disposing IsoManager 2014-01-29 22:04:09.2192 Info - App: Disposing ApiClient 2014-01-29 22:04:09.2192 Info - App: Disposing ApiWebSocket 2014-01-29 22:04:09.2192 Debug - ApiWebSocket: Stopping web socket timer 2014-01-29 22:04:09.2192 Debug - ApiWebSocket: Disposing client web socket 2014-01-29 22:04:09.2192 Info - ApiWebSocket: Sending web socket close message 2014-01-29 22:04:09.2192 Info - App: Disposing PismoIsoManager 2014-01-29 22:04:09.2192 Info - App: Disposing BackdropsEntryPoint 2014-01-29 22:04:09.2192 Info - App: Disposing ScreensaverEntryPoint 2014-01-29 22:04:09.2192 Info - App: Disposing ThemeSongEntryPoint 2014-01-29 22:04:09.2192 Info - App: Disposing WebSocketEntryPoint Edited January 30, 2014 by pmac
Luke 42237 Posted January 30, 2014 Author Posted January 30, 2014 Try updating again. I was able to restore playback with a hack. Andy I'm sure will provide a better fix tomorrow, but for now that should get you back up and running.
pmac 143 Posted January 30, 2014 Posted January 30, 2014 Ok thanks, seems to be playing fine now. What is the search feature you mentioned? I haven't noticed anything new...
pmac 143 Posted January 30, 2014 Posted January 30, 2014 Ohhh, Didn't notice that somehow, haha. Very nice!
Luke 42237 Posted January 30, 2014 Author Posted January 30, 2014 It's very simplistic and easy to use with just directionals and an OK press. So the WAF should be pretty good on that screen, I think.
bigjohn 754 Posted January 30, 2014 Posted January 30, 2014 (edited) Holy *% the new search feature is SHARP! Very nice work, Shaun! Edited January 30, 2014 by bigjohn322 1
pmac 143 Posted January 30, 2014 Posted January 30, 2014 It's definitely a nice start! I'm glad to see some search functionality in MBT I find one issue though, is the fact that it's still hard (In some cases impossible) to get up to the top right corner without using a mouse. It's completely inaccessible from the EHS with just a remote. Also, I like the wealth of information the new search feature brings you, and I believe this will be a very useful feature once it's completely polished. But I also enjoyed the "snappiness", and simplicity of using triple-tap, or keyboard search while searching through titles. If you are trying to stay away from such search devices, and keeping things more "visual", some sort of on-screen search (similar to the one just implemented) would be nice to have available for searching individual collections, to keep it simple. I posted an (extremely) rough image of how such an on-screen search could be utilized, a little ways back on this thread. I think keeping the "search bar" on the screen while browsing collections would really aid in how quickly users figure out how to use it, and the fact they can already see it, takes the guess work out of whether they find it at all or not. 2
candybar213 7 Posted January 30, 2014 Posted January 30, 2014 Could use a shortcut to search and then map it to a key on remote that would make it easy to get to The Candybar213 1
shaefurr 1340 Posted January 30, 2014 Posted January 30, 2014 Search looks fantastic, but does it only pull up 9 results? For instance if I type harry potter, all I get are my ebooks.
pmac 143 Posted January 30, 2014 Posted January 30, 2014 Something along the lines of this would be a nice, simple search function for collections, in my opinion. All the user would have to do to search the current collection would be to scroll down with the remote to get to the "search bar", and select the letter they would like to browse to. Also, on either side would be chevrons for skipping through the collection faster. (After doing the mock-up, I realized the chevrons would work better if they were separate from the alphabetical search bar, so they could be used more efficiently.) Maybe the user could scroll down once more to access the chevrons, or something along those lines. Again, just my opinion!
pmac 143 Posted January 30, 2014 Posted January 30, 2014 Or the user could scroll up for the quick-scroll chevrons 2
Ghostm 75 Posted January 30, 2014 Posted January 30, 2014 (edited) ^^^ Can we enable cases or is there a way to have cases in mbt? Or is that a Photoshop picture? Edited January 30, 2014 by Ghostm
pmac 143 Posted January 30, 2014 Posted January 30, 2014 @@Ghostm, you need to install the CoverArt plugin to get your images to look like that.
Koleckai Silvestri 1154 Posted January 30, 2014 Posted January 30, 2014 There is a cover art plugin for the server. That will create case images for you if you want them.
Danee 57 Posted January 30, 2014 Posted January 30, 2014 The search function is a great addition, I like it! @@Luke, wat can you say about triple-tap support? I've seen it mentioned here and there around the forum but have not seen a reaction yet.
Aphid 212 Posted January 30, 2014 Posted January 30, 2014 Something along the lines of this would be a nice, simple search function for collections, in my opinion. Skipping to a location within the scroll viewer is something very different to the new search feature, but it is something I would expect to see implemented eventually.
Jdiesel 1435 Posted January 31, 2014 Posted January 31, 2014 Is there any future plans to add the ability to set the directory for the local cache? I would like to be able to set the local cache for the images and metadata to a small SSD to speed up browsing. With a large collection the size grows very quickly and it would be nice to keep it separate from the main OS drive.
