WWWestern 94 Posted December 13, 2013 Posted December 13, 2013 @@HTPC can You add server's log (C:\Users\Your_User_Name_Here\AppData\Roaming\MediaBrowser-Server\logs) when trying start MBC & MBT?
Guest HTPC Posted December 14, 2013 Posted December 14, 2013 Take a look http://www.fayloobmennik.net/3421454
Luke 42237 Posted December 14, 2013 Author Posted December 14, 2013 @@Luke & @@ebr can you take a look? There's too much to look through. I just need one log with the problem. The zip file contains other zip files. I don't even know where to begin.
Guest HTPC Posted December 14, 2013 Posted December 14, 2013 Many thanks to all. Problem solved. The problem turned out to be banal. Computer name contains the letters of the Cyrillic alphabet.
trusselo 225 Posted December 17, 2013 Posted December 17, 2013 (edited) Just installed theater the other night, today i noticed it crashes anytime i enter a TV series with a video backdrop, gives error. Tried deleting the video backdrop tried, again still fails, but hangs every time i enter a TV folder that has video backdrop. log 1 https://dl.dropboxusercontent.com/u/19201431/Files/crash_4d504623-8b61-4ad7-a6f8-3f08a181d02f.txt log 2 https://dl.dropboxusercontent.com/u/19201431/Files/crash_fe7e2d0d-1f92-452c-9e61-24433c23bc76.txt Edited December 17, 2013 by trusselo
Redshirt 1487 Posted December 17, 2013 Posted December 17, 2013 that error is usually mis-configured lav filters. Reinstalling lav might fix it.
trusselo 225 Posted December 18, 2013 Posted December 18, 2013 that error is usually mis-configured lav filters. Reinstalling lav might fix it. just downloaded and installed newest lav filters. same error entering most show folders.
pmac 143 Posted December 18, 2013 Posted December 18, 2013 Not sure if this has been brought up before, but for some reason MBT only seems to recognize the x86 version of xy-VSFilters, so I either have to have the x86 and x64 version installed on my machine (64-bit) or uninstall the x64 version. Any reason this should be a problem? or will future releases of MBT recognize both versions, so I can just leave my x64 installation of xy-VSFilter and not worry about the 32-bit version. Thanks
Luke 42237 Posted December 19, 2013 Author Posted December 19, 2013 No, it's a 32-bit app due to 32-bit libraries we depend on, so it will be 32-bit only.
trusselo 225 Posted December 19, 2013 Posted December 19, 2013 (edited) just downloaded and installed newest lav filters. same error entering most show folders. the only way i was able to "fix" this issue was by removing (deleting) all video backdrops (/backdrops folders) from all TV shows, then re-scanning media. Now i am faced with being unable to play any file with AC3 or MP3 audio. I have enabled LAV for those file types. I get error : " Unable to process your request " log: 2013-12-19 10:14:29.9875, Info, App, Loading MediaBrowser.Model, Version=3.0.5096.36440, Culture=neutral, PublicKeyToken=null 2013-12-19 10:14:29.9935, Info, App, Loading MediaBrowser.Common, Version=3.0.5096.36440, Culture=neutral, PublicKeyToken=null 2013-12-19 10:14:29.9935, Info, App, Loading MediaBrowser.Common.Implementations, Version=3.0.5096.36441, Culture=neutral, PublicKeyToken=null 2013-12-19 10:14:29.9935, Info, App, Loading MediaBrowser.UI, Version=3.0.5097.22952, Culture=neutral, PublicKeyToken=null 2013-12-19 10:14:29.9935, Info, App, Loading MediaBrowser.Theater.DirectShow, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2013-12-19 10:14:29.9935, Info, App, Loading MediaBrowser.Theater.Presentation, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2013-12-19 10:14:29.9935, Info, App, Loading MediaBrowser.Theater.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2013-12-19 10:14:29.9935, Info, App, Loading MediaBrowser.IsoMounter, Version=1.0.5079.1480, Culture=neutral, PublicKeyToken=null 2013-12-19 10:14:29.9935, Info, App, Loading MediaBrowser.Plugins.DefaultTheme, Version=3.0.5097.22951, Culture=neutral, PublicKeyToken=null 2013-12-19 10:14:30.0405, Info, App, Version 3.0.5097.22952 initializing 2013-12-19 10:14:30.0625, Debug, ApiClient, Applying Authorization http header: Client="Media Browser Theater", DeviceId="RANDOM-PC7", Device="RANDOM-PC7", Version="3.0.5097.22952" 2013-12-19 10:14:30.1495, Info, App, Core startup complete 2013-12-19 10:14:30.1495, Info, App, Adding resource ResourceDictionary 2013-12-19 10:14:30.1495, Info, App, Loading theme: Default 2013-12-19 10:14:30.1495, Info, App, Adding resource ResourceDictionary 2013-12-19 10:14:30.4355, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/System/Info?format=json 2013-12-19 10:14:30.4575, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/System/Info?format=json 2013-12-19 10:14:30.5745, Debug, ApiClient, Received OK status code after 122.007 ms from GET: http://192.168.0.10:8096/mediabrowser/System/Info?format=json 2013-12-19 10:14:30.5745, Debug, ApiClient, Received OK status code after 119.0068 ms from GET: http://192.168.0.10:8096/mediabrowser/System/Info?format=json 2013-12-19 10:14:30.6305, Info, ApiWebSocket, Created new web socket of type WebSocket4NetClientWebSocket 2013-12-19 10:14:30.6495, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/System/Info?format=json 2013-12-19 10:14:30.6495, Info, ApiWebSocket, Connected to ws://192.168.0.10:8946/mediabrowser 2013-12-19 10:14:30.6495, Info, ApiWebSocket, Sending web socket identification message Media Browser Theater|RANDOM-PC7|3.0.5097.22952|RANDOM-PC7 2013-12-19 10:14:30.6815, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/System/Info?format=json 2013-12-19 10:14:30.6815, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/System/Info?format=json 2013-12-19 10:14:30.7505, Debug, ApiClient, Received OK status code after 100.0058 ms from GET: http://192.168.0.10:8096/mediabrowser/System/Info?format=json 2013-12-19 10:14:30.7545, Debug, ApiClient, POST http://192.168.0.10:8096/mediabrowser/Users/AuthenticateByName?format=json 2013-12-19 10:14:30.7545, Debug, ApiClient, Received OK status code after 1.0001 ms from POST: http://192.168.0.10:8096/mediabrowser/Users/AuthenticateByName?format=json 2013-12-19 10:14:30.7545, Info, ApiWebSocket, Received web socket message: UserUpdated 2013-12-19 10:14:30.7815, Debug, ApiClient, Applying Authorization http header: Client="Media Browser Theater", DeviceId="RANDOM-PC7", Device="RANDOM-PC7", Version="3.0.5097.22952", UserId="a15b6c3574fba386e933f67b3e696667" 2013-12-19 10:14:30.8005, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Users/a15b6c3574fba386e933f67b3e696667/Items/Root?format=json 2013-12-19 10:14:30.8005, Debug, ApiClient, Received OK status code after 3.0002 ms from GET: http://192.168.0.10:8096/mediabrowser/Users/a15b6c3574fba386e933f67b3e696667/Items/Root?format=json 2013-12-19 10:14:30.8005, Debug, ApiClient, Received OK status code after 127.0073 ms from GET: http://192.168.0.10:8096/mediabrowser/System/Info?format=json 2013-12-19 10:14:30.8005, Debug, ApiClient, Received OK status code after 131.0075 ms from GET: http://192.168.0.10:8096/mediabrowser/System/Info?format=json 2013-12-19 10:14:30.9466, Debug, App, Navigating to HomePage 2013-12-19 10:14:30.9566, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/Counts?UserId=a15b6c3574fba386e933f67b3e696667&format=json 2013-12-19 10:14:30.9566, Debug, App, Navigation complete to HomePage 2013-12-19 10:14:30.9766, Debug, ApiClient, Received OK status code after 20.0012 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/Counts?UserId=a15b6c3574fba386e933f67b3e696667&format=json 2013-12-19 10:14:31.0366, Info, App, Adding resource ResourceDictionary 2013-12-19 10:14:31.5276, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/MBT/DefaultTheme/Movies?familyrating=pg&userId=a15b6c3574fba386e933f67b3e696667&ComedyGenre=comedy&RomanceGenre=romance&FamilyGenre=family&LatestMoviesLimit=16&LatestTrailersLimit=6&format=json 2013-12-19 10:14:31.5816, Debug, ApiClient, Received OK status code after 54.0031 ms from GET: http://192.168.0.10:8096/mediabrowser/MBT/DefaultTheme/Movies?familyrating=pg&userId=a15b6c3574fba386e933f67b3e696667&ComedyGenre=comedy&RomanceGenre=romance&FamilyGenre=family&LatestMoviesLimit=16&LatestTrailersLimit=6&format=json 2013-12-19 10:14:31.7236, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/e1a30dea611c1cd2f17328cd0125137b/Images/Backdrop?Width=677&Height=381&Quality=100&Tag=d57c8d3e-1313-a635-cdd1-3bcf6d5de585&EnableImageEnhancers=True 2013-12-19 10:14:31.7236, Debug, ApiClient, Received OK status code after 4.0003 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/e1a30dea611c1cd2f17328cd0125137b/Images/Backdrop?Width=677&Height=381&Quality=100&Tag=d57c8d3e-1313-a635-cdd1-3bcf6d5de585&EnableImageEnhancers=True 2013-12-19 10:14:31.7836, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/48cd777ae9594c1d6e458ff446cdc91f/Images/Backdrop?Width=336&Height=189&Quality=100&Tag=54b25123-0e2c-6c79-60df-2ae0dd105ff6&EnableImageEnhancers=True 2013-12-19 10:14:31.7836, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/485e3c3ae6ec8cf2b5b3905e96da8481/Images/Backdrop?Width=336&Height=189&Quality=100&Tag=502442d3-a622-0fe0-8c02-701c45c7d8d9&EnableImageEnhancers=True 2013-12-19 10:14:31.7836, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/dc7b21003d0d15f36d4aa44e3f3b2042/Images/Backdrop?Width=672&Quality=100&Tag=37d6b58a-5095-eaa4-9ec0-863503017667&EnableImageEnhancers=False 2013-12-19 10:14:31.9616, Debug, ApiClient, Received OK status code after 177.0101 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/485e3c3ae6ec8cf2b5b3905e96da8481/Images/Backdrop?Width=336&Height=189&Quality=100&Tag=502442d3-a622-0fe0-8c02-701c45c7d8d9&EnableImageEnhancers=True 2013-12-19 10:14:32.0186, Debug, ApiClient, Received OK status code after 231.0132 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/dc7b21003d0d15f36d4aa44e3f3b2042/Images/Backdrop?Width=672&Quality=100&Tag=37d6b58a-5095-eaa4-9ec0-863503017667&EnableImageEnhancers=False 2013-12-19 10:14:32.0606, Debug, ApiClient, Received OK status code after 277.0158 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/48cd777ae9594c1d6e458ff446cdc91f/Images/Backdrop?Width=336&Height=189&Quality=100&Tag=54b25123-0e2c-6c79-60df-2ae0dd105ff6&EnableImageEnhancers=True 2013-12-19 10:14:32.5256, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/7cc2c6946aa6f90f854c68ec399bcb07/Images/Backdrop?Quality=100&Tag=6aee104f-96e9-26b3-5e7d-65406f39a68e&EnableImageEnhancers=True 2013-12-19 10:14:32.5786, Debug, ApiClient, Received OK status code after 52.0029 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/7cc2c6946aa6f90f854c68ec399bcb07/Images/Backdrop?Quality=100&Tag=6aee104f-96e9-26b3-5e7d-65406f39a68e&EnableImageEnhancers=True 2013-12-19 10:14:33.0187, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/MBT/DefaultTheme/TV?userId=a15b6c3574fba386e933f67b3e696667&ComedyGenre=comedy&RomanceGenre=romance&TopCommunityRating=8.5&NextUpEpisodeLimit=15&LatestEpisodeLimit=9&ResumableEpisodeLimit=3&format=json 2013-12-19 10:14:33.1027, Debug, ApiClient, Received OK status code after 83.0047 ms from GET: http://192.168.0.10:8096/mediabrowser/MBT/DefaultTheme/TV?userId=a15b6c3574fba386e933f67b3e696667&ComedyGenre=comedy&RomanceGenre=romance&TopCommunityRating=8.5&NextUpEpisodeLimit=15&LatestEpisodeLimit=9&ResumableEpisodeLimit=3&format=json 2013-12-19 10:14:33.1227, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/e2b74b5074011d977cfb3f57037ccbb7/Images/Backdrop?Width=677&Height=381&Quality=100&Tag=6bf73143-acd6-36cc-acb8-b895265bc1c4&EnableImageEnhancers=True 2013-12-19 10:14:33.1307, Debug, ApiClient, Received OK status code after 8.0005 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/e2b74b5074011d977cfb3f57037ccbb7/Images/Backdrop?Width=677&Height=381&Quality=100&Tag=6bf73143-acd6-36cc-acb8-b895265bc1c4&EnableImageEnhancers=True 2013-12-19 10:14:33.1457, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/c0416860df742d3bb32ab72c0f7ad6c2/Images/Primary?Width=336&Quality=100&Tag=031b1357-bd4a-6449-39ee-0275554b0b52&EnableImageEnhancers=False 2013-12-19 10:14:33.1457, Debug, ApiClient, Received OK status code after 5.0003 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/c0416860df742d3bb32ab72c0f7ad6c2/Images/Primary?Width=336&Quality=100&Tag=031b1357-bd4a-6449-39ee-0275554b0b52&EnableImageEnhancers=False 2013-12-19 10:14:33.1577, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/11b12922e253f0f47eee5ecb0efdc05c/Images/Primary?Width=336&Height=189&Quality=100&Tag=6c67e60f-e7d5-140c-c702-fe6f80abcff3&EnableImageEnhancers=False 2013-12-19 10:14:33.1577, Info, App, StartupTrigger fired for task: Cache file cleanup 2013-12-19 10:14:33.1577, Info, App, StartupTrigger fired for task: Log file cleanup 2013-12-19 10:14:33.1577, Info, App, StartupTrigger fired for task: Check for application updates 2013-12-19 10:14:33.1577, Info, App, StartupTrigger fired for task: Check for plugin updates 2013-12-19 10:14:33.1577, Info, App, Executing Cache file cleanup 2013-12-19 10:14:33.1577, Info, App, Executing Log file cleanup 2013-12-19 10:14:33.1577, Info, App, Executing Check for plugin updates 2013-12-19 10:14:33.1577, Info, App, Executing Check for application updates 2013-12-19 10:14:33.1757, Info, App, Log file cleanup Completed after 0 minute(s) and 0 seconds 2013-12-19 10:14:33.1757, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/System/Info?format=json 2013-12-19 10:14:33.1757, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/261338832b35f576624f3ef6e0f7452b/Images/Backdrop?Height=672&Quality=100&Tag=79a249ca-d703-e139-8ff2-617f07851fa2&EnableImageEnhancers=False 2013-12-19 10:14:33.1757, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/648cd7c0edfcb60eae81e40f3abd2a11/Images/Primary?Width=336&Quality=100&Tag=ba97ff81-9502-b195-0c70-2ae611bdb4c5&EnableImageEnhancers=False 2013-12-19 10:14:33.1757, Info, App, Cache file cleanup Completed after 0 minute(s) and 0 seconds 2013-12-19 10:14:33.1757, Info, App, HttpClientManager.GET url: http://www.mb3admin.com/admin/service/MB3Packages.json 2013-12-19 10:14:33.2497, Debug, ApiClient, Received OK status code after 91.0052 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/11b12922e253f0f47eee5ecb0efdc05c/Images/Primary?Width=336&Height=189&Quality=100&Tag=6c67e60f-e7d5-140c-c702-fe6f80abcff3&EnableImageEnhancers=False 2013-12-19 10:14:33.2587, Debug, ApiClient, Received OK status code after 74.0042 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/648cd7c0edfcb60eae81e40f3abd2a11/Images/Primary?Width=336&Quality=100&Tag=ba97ff81-9502-b195-0c70-2ae611bdb4c5&EnableImageEnhancers=False 2013-12-19 10:14:33.3087, Debug, ApiClient, Received OK status code after 130.0074 ms from GET: http://192.168.0.10:8096/mediabrowser/System/Info?format=json 2013-12-19 10:14:33.3087, Info, App, HttpClientManager.GET url: http://www.mb3admin.com/admin/service/MB3Packages.json 2013-12-19 10:14:33.3377, Debug, ApiClient, Received OK status code after 153.0087 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/261338832b35f576624f3ef6e0f7452b/Images/Backdrop?Height=672&Quality=100&Tag=79a249ca-d703-e139-8ff2-617f07851fa2&EnableImageEnhancers=False 2013-12-19 10:14:33.9257, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/35c390bacf20d4a1d6192effb5c05c44/Images/Backdrop?Quality=100&Tag=fcf736e1-0780-5cac-f1cf-1fa5988f0ebe&EnableImageEnhancers=True 2013-12-19 10:14:33.9257, Debug, ApiClient, Received OK status code after 4.0003 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/35c390bacf20d4a1d6192effb5c05c44/Images/Backdrop?Quality=100&Tag=fcf736e1-0780-5cac-f1cf-1fa5988f0ebe&EnableImageEnhancers=True 2013-12-19 10:14:34.2647, Info, App, Check for plugin updates Completed after 0 minute(s) and 1 seconds 2013-12-19 10:14:34.4218, Debug, App, No application update available. 2013-12-19 10:14:34.4218, Info, App, Check for application updates Completed after 0 minute(s) and 1 seconds 2013-12-19 10:14:37.0689, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Users/a15b6c3574fba386e933f67b3e696667/Items/3b45274577c5bffbf5b3b8ff1bb8481a?format=json 2013-12-19 10:14:37.0759, Debug, ApiClient, Received OK status code after 7.0004 ms from GET: http://192.168.0.10:8096/mediabrowser/Users/a15b6c3574fba386e933f67b3e696667/Items/3b45274577c5bffbf5b3b8ff1bb8481a?format=json 2013-12-19 10:14:37.1059, Info, ApiWebSocket, Received web socket message: LibraryChanged 2013-12-19 10:14:37.1059, Debug, App, Navigating to DetailPage 2013-12-19 10:14:37.1239, Debug, App, Navigation complete to DetailPage 2013-12-19 10:14:37.1239, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/3b45274577c5bffbf5b3b8ff1bb8481a/ThemeMedia?InheritFromParent=True&UserId=a15b6c3574fba386e933f67b3e696667&format=json 2013-12-19 10:14:37.1629, Debug, ApiClient, Received OK status code after 35.002 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/3b45274577c5bffbf5b3b8ff1bb8481a/ThemeMedia?InheritFromParent=True&UserId=a15b6c3574fba386e933f67b3e696667&format=json 2013-12-19 10:14:37.1659, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/3b45274577c5bffbf5b3b8ff1bb8481a/CriticReviews?format=json 2013-12-19 10:14:37.1989, Debug, ApiClient, Received OK status code after 33.0019 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/3b45274577c5bffbf5b3b8ff1bb8481a/CriticReviews?format=json 2013-12-19 10:14:37.1989, Info, App, Removing resource ResourceDictionary 2013-12-19 10:14:37.2149, Info, DirectShowPlayer, Playing 1377302569__temp_1377302565. Reclock: False, Madvr: False, xySubFilter: False 2013-12-19 10:14:37.2149, Info, DirectShowPlayer, Playing Path \\Random-pc7\tv\Nurse Jackie\theme-music\1377302569__temp_1377302565.mp3 2013-12-19 10:14:37.3609, Info, DirectShowPlayer, Completed RenderStreams with 1 pins. 2013-12-19 10:14:37.3759, Debug, DirectShowPlayer, Received media event code ClockChanged 2013-12-19 10:14:37.3759, Debug, ApiClient, ReportPlaybackStart: Item 8ab190a8eeffc63a0f3fe2bc32b94f2e 2013-12-19 10:14:37.3759, Debug, App, Calling SetThreadExecutionState to prevent system idle 2013-12-19 10:14:37.3919, Debug, DirectShowPlayer, Received media event code Paused 2013-12-19 10:14:37.8830, Info, ApiWebSocket, Received web socket message: UserDataChanged 2013-12-19 10:14:37.9320, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/874ac12b9eaddb109ca6f32b98be7b47/Images/Backdrop/0?Width=4320&Quality=100&Tag=74be0071-dcd3-3f7f-2f02-eec4f1227257&EnableImageEnhancers=True 2013-12-19 10:14:37.9320, Debug, ApiClient, Received OK status code after 5.0003 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/874ac12b9eaddb109ca6f32b98be7b47/Images/Backdrop/0?Width=4320&Quality=100&Tag=74be0071-dcd3-3f7f-2f02-eec4f1227257&EnableImageEnhancers=True 2013-12-19 10:14:46.7915, Debug, DirectShowPlayer, Disposing player 2013-12-19 10:14:46.8235, Debug, ApiClient, ReportPlaybackStopped: Item 8ab190a8eeffc63a0f3fe2bc32b94f2e, Position: 00:00:09.2923901 2013-12-19 10:14:46.8235, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Users/a15b6c3574fba386e933f67b3e696667/Items/3b45274577c5bffbf5b3b8ff1bb8481a/Intros?format=json 2013-12-19 10:14:46.8235, Debug, App, Calling SetThreadExecutionState to allow system idle 2013-12-19 10:14:46.8235, Debug, ApiClient, Received OK status code after 2.0001 ms from GET: http://192.168.0.10:8096/mediabrowser/Users/a15b6c3574fba386e933f67b3e696667/Items/3b45274577c5bffbf5b3b8ff1bb8481a/Intros?format=json 2013-12-19 10:14:46.8235, Info, DirectShowPlayer, Playing Kettle-Kettle-Black-Black. Reclock: False, Madvr: False, xySubFilter: False 2013-12-19 10:14:46.8235, Info, DirectShowPlayer, Playing Path \\Random-pc7\tv\Nurse Jackie\Season 4\Nurse Jackie.S04E01.Kettle-Kettle-Black-Black.avi 2013-12-19 10:14:47.2285, Error, DirectShowPlayer, Error beginning playback There is no common media type between these pins. System.Runtime.InteropServices.COMException at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous) at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args) at System.Windows.Forms.Control.Invoke(Delegate method) at MediaBrowser.Theater.DirectShow.InternalDirectShowPlayer.InvokeOnPlayerThread(Action action) at MediaBrowser.Theater.DirectShow.InternalDirectShowPlayer.<PlayTrack>d__d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Theater.DirectShow.InternalDirectShowPlayer.<Play>d__2.MoveNext() 2013-12-19 10:14:47.3255, Info, ApiWebSocket, Received web socket message: UserDataChanged 2013-12-19 10:14:47.9315, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/874ac12b9eaddb109ca6f32b98be7b47/Images/Backdrop/1?Width=4320&Quality=100&Tag=fa63fb2c-2e5b-56b3-1b11-493c3d20aa37&EnableImageEnhancers=True 2013-12-19 10:14:47.9315, Debug, ApiClient, Received OK status code after 3.0002 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/874ac12b9eaddb109ca6f32b98be7b47/Images/Backdrop/1?Width=4320&Quality=100&Tag=fa63fb2c-2e5b-56b3-1b11-493c3d20aa37&EnableImageEnhancers=True 2013-12-19 10:14:51.5997, Info, App, Adding resource ResourceDictionary 2013-12-19 10:15:01.6023, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/cd158d46823c397466625c06044d25c9/Images/Backdrop?Width=677&Height=381&Quality=100&Tag=b5f23908-4c29-03cd-f8c0-5ad952acccfd&EnableImageEnhancers=True 2013-12-19 10:15:01.6973, Debug, ApiClient, Received OK status code after 95.0054 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/cd158d46823c397466625c06044d25c9/Images/Backdrop?Width=677&Height=381&Quality=100&Tag=b5f23908-4c29-03cd-f8c0-5ad952acccfd&EnableImageEnhancers=True 2013-12-19 10:15:02.4384, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/e2b74b5074011d977cfb3f57037ccbb7/Images/Backdrop?Quality=100&Tag=6bf73143-acd6-36cc-acb8-b895265bc1c4&EnableImageEnhancers=True 2013-12-19 10:15:02.4384, Debug, ApiClient, Received OK status code after 4.0002 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/e2b74b5074011d977cfb3f57037ccbb7/Images/Backdrop?Quality=100&Tag=6bf73143-acd6-36cc-acb8-b895265bc1c4&EnableImageEnhancers=True 2013-12-19 10:15:04.4525, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Users/a15b6c3574fba386e933f67b3e696667/Items/11b12922e253f0f47eee5ecb0efdc05c?format=json 2013-12-19 10:15:04.4525, Debug, ApiClient, Received OK status code after 4.0002 ms from GET: http://192.168.0.10:8096/mediabrowser/Users/a15b6c3574fba386e933f67b3e696667/Items/11b12922e253f0f47eee5ecb0efdc05c?format=json 2013-12-19 10:15:04.4525, Debug, App, Navigating to DetailPage 2013-12-19 10:15:04.4685, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/11b12922e253f0f47eee5ecb0efdc05c/CriticReviews?format=json 2013-12-19 10:15:04.4905, Debug, ApiClient, Received OK status code after 21.0012 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/11b12922e253f0f47eee5ecb0efdc05c/CriticReviews?format=json 2013-12-19 10:15:04.4905, Info, App, Removing resource ResourceDictionary 2013-12-19 10:15:04.5145, Debug, App, Navigation complete to DetailPage 2013-12-19 10:15:04.5145, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/11b12922e253f0f47eee5ecb0efdc05c/ThemeMedia?InheritFromParent=True&UserId=a15b6c3574fba386e933f67b3e696667&format=json 2013-12-19 10:15:04.5585, Debug, ApiClient, Received OK status code after 42.0024 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/11b12922e253f0f47eee5ecb0efdc05c/ThemeMedia?InheritFromParent=True&UserId=a15b6c3574fba386e933f67b3e696667&format=json 2013-12-19 10:15:05.0615, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/11b12922e253f0f47eee5ecb0efdc05c/Images/Primary?Width=550&Quality=100&Tag=6c67e60f-e7d5-140c-c702-fe6f80abcff3&EnableImageEnhancers=True 2013-12-19 10:15:05.1455, Debug, ApiClient, Received OK status code after 66.0037 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/11b12922e253f0f47eee5ecb0efdc05c/Images/Primary?Width=550&Quality=100&Tag=6c67e60f-e7d5-140c-c702-fe6f80abcff3&EnableImageEnhancers=True 2013-12-19 10:15:08.2967, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Users/a15b6c3574fba386e933f67b3e696667/Items/11b12922e253f0f47eee5ecb0efdc05c/Intros?format=json 2013-12-19 10:15:08.2967, Debug, ApiClient, Received OK status code after 3.0002 ms from GET: http://192.168.0.10:8096/mediabrowser/Users/a15b6c3574fba386e933f67b3e696667/Items/11b12922e253f0f47eee5ecb0efdc05c/Intros?format=json 2013-12-19 10:15:08.2967, Info, DirectShowPlayer, Playing Teachable Moments. Reclock: False, Madvr: False, xySubFilter: False 2013-12-19 10:15:08.2967, Info, DirectShowPlayer, Playing Path \\Random-pc7\tv\Nurse Jackie\Season 5\Nurse Jackie.S05E07.Teachable Moments.mkv 2013-12-19 10:15:08.5567, Error, DirectShowPlayer, Error beginning playback Cannot play back the audio stream: the audio format is not supported. System.Runtime.InteropServices.COMException at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous) at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args) at System.Windows.Forms.Control.Invoke(Delegate method) at MediaBrowser.Theater.DirectShow.InternalDirectShowPlayer.InvokeOnPlayerThread(Action action) at MediaBrowser.Theater.DirectShow.InternalDirectShowPlayer.<PlayTrack>d__d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Theater.DirectShow.InternalDirectShowPlayer.<Play>d__2.MoveNext() 2013-12-19 10:15:19.8904, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Persons/Adam Ferrara/Images/Primary?Quality=100&Tag=30621422-2faf-0076-8459-ed75250ab6f1&EnableImageEnhancers=True 2013-12-19 10:15:20.0104, Debug, ApiClient, Received OK status code after 118.0068 ms from GET: http://192.168.0.10:8096/mediabrowser/Persons/Adam Ferrara/Images/Primary?Quality=100&Tag=30621422-2faf-0076-8459-ed75250ab6f1&EnableImageEnhancers=True 2013-12-19 10:15:25.3397, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/874ac12b9eaddb109ca6f32b98be7b47/Images/Backdrop/2?Width=4320&Quality=100&Tag=1bf1efb6-6d09-346f-7b19-e65b70f05aa0&EnableImageEnhancers=True 2013-12-19 10:15:25.3397, Debug, ApiClient, Received OK status code after 4.0002 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/874ac12b9eaddb109ca6f32b98be7b47/Images/Backdrop/2?Width=4320&Quality=100&Tag=1bf1efb6-6d09-346f-7b19-e65b70f05aa0&EnableImageEnhancers=True 2013-12-19 10:15:28.8319, Info, App, Adding resource ResourceDictionary 2013-12-19 10:15:30.2739, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/MBT/DefaultTheme/Movies?familyrating=pg&userId=a15b6c3574fba386e933f67b3e696667&ComedyGenre=comedy&RomanceGenre=romance&FamilyGenre=family&LatestMoviesLimit=16&LatestTrailersLimit=6&format=json 2013-12-19 10:15:30.3510, Debug, ApiClient, Received OK status code after 77.0044 ms from GET: http://192.168.0.10:8096/mediabrowser/MBT/DefaultTheme/Movies?familyrating=pg&userId=a15b6c3574fba386e933f67b3e696667&ComedyGenre=comedy&RomanceGenre=romance&FamilyGenre=family&LatestMoviesLimit=16&LatestTrailersLimit=6&format=json 2013-12-19 10:15:30.3620, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/d918150a1fc51aeb0bc8bbc1fa6b75b5/Images/Backdrop?Width=677&Height=381&Quality=100&Tag=b79a7225-c6e3-cfeb-1b74-fce0b9fc0daa&EnableImageEnhancers=True 2013-12-19 10:15:30.4670, Debug, ApiClient, Received OK status code after 105.0061 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/d918150a1fc51aeb0bc8bbc1fa6b75b5/Images/Backdrop?Width=677&Height=381&Quality=100&Tag=b79a7225-c6e3-cfeb-1b74-fce0b9fc0daa&EnableImageEnhancers=True 2013-12-19 10:15:30.6930, Error, ApiWebSocket, Error deserializing web socket message Type definitions should start with a '{', expecting serialized type 'WebSocketMessage', got string starting with: 19/12/2013 10:15:30 AM System.Runtime.Serialization.SerializationException at ServiceStack.Text.Common.DeserializeTypeRefJson.StringToType(Type type, String strType, EmptyCtorDelegate ctorFn, Dictionary`2 typeAccessorMap) at ServiceStack.Text.Common.DeserializeType`1.<>c__DisplayClass3.<GetParseMethod>b__1(String value) at ServiceStack.Text.Json.JsonReader`1.Parse(String value) at ServiceStack.Text.JsonSerializer.DeserializeFromString[T](String value) at MediaBrowser.Common.Implementations.Serialization.JsonSerializer.DeserializeFromString[T](String text) at MediaBrowser.ApiInteraction.WebSocket.BaseApiWebSocket.GetMessageType(String json) at MediaBrowser.ApiInteraction.WebSocket.BaseApiWebSocket.OnMessageReceived(String json) 2013-12-19 10:15:31.1220, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/MBT/DefaultTheme/TV?userId=a15b6c3574fba386e933f67b3e696667&ComedyGenre=comedy&RomanceGenre=romance&TopCommunityRating=8.5&NextUpEpisodeLimit=15&LatestEpisodeLimit=9&ResumableEpisodeLimit=3&format=json 2013-12-19 10:15:31.1810, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/009938686fe6efd0291f86820fa95b17/Images/Backdrop?Quality=100&Tag=8f673fd2-6147-cd5d-9dd5-e67b315d1550&EnableImageEnhancers=True 2013-12-19 10:15:31.2150, Debug, ApiClient, Received OK status code after 34.0019 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/009938686fe6efd0291f86820fa95b17/Images/Backdrop?Quality=100&Tag=8f673fd2-6147-cd5d-9dd5-e67b315d1550&EnableImageEnhancers=True 2013-12-19 10:15:31.2790, Debug, ApiClient, Received OK status code after 156.0089 ms from GET: http://192.168.0.10:8096/mediabrowser/MBT/DefaultTheme/TV?userId=a15b6c3574fba386e933f67b3e696667&ComedyGenre=comedy&RomanceGenre=romance&TopCommunityRating=8.5&NextUpEpisodeLimit=15&LatestEpisodeLimit=9&ResumableEpisodeLimit=3&format=json 2013-12-19 10:15:31.2920, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/0ab9580d369bfe6ef55115a6724b22df/Images/Backdrop?Width=677&Height=381&Quality=100&Tag=b599614b-6e9a-2b2e-6b91-669f145e1785&EnableImageEnhancers=True 2013-12-19 10:15:31.3710, Debug, ApiClient, Received OK status code after 79.0046 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/0ab9580d369bfe6ef55115a6724b22df/Images/Backdrop?Width=677&Height=381&Quality=100&Tag=b599614b-6e9a-2b2e-6b91-669f145e1785&EnableImageEnhancers=True 2013-12-19 10:15:31.7160, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/MBT/DefaultTheme/Movies?familyrating=pg&userId=a15b6c3574fba386e933f67b3e696667&ComedyGenre=comedy&RomanceGenre=romance&FamilyGenre=family&LatestMoviesLimit=16&LatestTrailersLimit=6&format=json 2013-12-19 10:15:31.7960, Debug, ApiClient, Received OK status code after 80.0046 ms from GET: http://192.168.0.10:8096/mediabrowser/MBT/DefaultTheme/Movies?familyrating=pg&userId=a15b6c3574fba386e933f67b3e696667&ComedyGenre=comedy&RomanceGenre=romance&FamilyGenre=family&LatestMoviesLimit=16&LatestTrailersLimit=6&format=json 2013-12-19 10:15:31.7970, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/9a22fd4ce042e1d0f885ec6eb4bd1fae/Images/Backdrop?Width=677&Height=381&Quality=100&Tag=29cc0873-3f73-d555-eb7c-305a04123762&EnableImageEnhancers=True 2013-12-19 10:15:31.7970, Debug, ApiClient, Received OK status code after 5.0003 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/9a22fd4ce042e1d0f885ec6eb4bd1fae/Images/Backdrop?Width=677&Height=381&Quality=100&Tag=29cc0873-3f73-d555-eb7c-305a04123762&EnableImageEnhancers=True 2013-12-19 10:15:32.6101, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/3686f6d87a6bfbda3b5c68cdf4478a29/Images/Backdrop?Quality=100&Tag=092677cc-b07f-0b03-053e-dc3b74c55a78&EnableImageEnhancers=True 2013-12-19 10:15:32.6561, Debug, ApiClient, Received OK status code after 46.0027 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/3686f6d87a6bfbda3b5c68cdf4478a29/Images/Backdrop?Quality=100&Tag=092677cc-b07f-0b03-053e-dc3b74c55a78&EnableImageEnhancers=True 2013-12-19 10:15:41.7976, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/ed3d78689bb578089ffa2c41423344f0/Images/Backdrop?Width=677&Height=381&Quality=100&Tag=85e1ad47-d31d-d3bd-2399-1fa31e1a7f49&EnableImageEnhancers=True 2013-12-19 10:15:41.7976, Debug, ApiClient, Received OK status code after 6.0003 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/ed3d78689bb578089ffa2c41423344f0/Images/Backdrop?Width=677&Height=381&Quality=100&Tag=85e1ad47-d31d-d3bd-2399-1fa31e1a7f49&EnableImageEnhancers=True 2013-12-19 10:15:42.6467, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/f9a22720efc25967aea5b385aee65a1f/Images/Backdrop?Quality=100&Tag=dad179df-901a-907b-d039-2ee66a783618&EnableImageEnhancers=True 2013-12-19 10:15:42.6897, Debug, ApiClient, Received OK status code after 43.0025 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/f9a22720efc25967aea5b385aee65a1f/Images/Backdrop?Quality=100&Tag=dad179df-901a-907b-d039-2ee66a783618&EnableImageEnhancers=True 2013-12-19 10:15:44.3388, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Users/a15b6c3574fba386e933f67b3e696667/Items/c3667828dc50a862f8aa35f1337fb8e9?format=json 2013-12-19 10:15:44.3458, Debug, ApiClient, Received OK status code after 7.0004 ms from GET: http://192.168.0.10:8096/mediabrowser/Users/a15b6c3574fba386e933f67b3e696667/Items/c3667828dc50a862f8aa35f1337fb8e9?format=json 2013-12-19 10:15:44.3458, Debug, App, Navigating to DetailPage 2013-12-19 10:15:44.3578, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/c3667828dc50a862f8aa35f1337fb8e9/CriticReviews?format=json 2013-12-19 10:15:44.3778, Debug, App, Navigation complete to DetailPage 2013-12-19 10:15:44.3778, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/c3667828dc50a862f8aa35f1337fb8e9/ThemeMedia?InheritFromParent=True&UserId=a15b6c3574fba386e933f67b3e696667&format=json 2013-12-19 10:15:44.4108, Debug, ApiClient, Received OK status code after 52.003 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/c3667828dc50a862f8aa35f1337fb8e9/CriticReviews?format=json 2013-12-19 10:15:44.4268, Info, App, Removing resource ResourceDictionary 2013-12-19 10:15:44.4268, Debug, ApiClient, Received OK status code after 35.002 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/c3667828dc50a862f8aa35f1337fb8e9/ThemeMedia?InheritFromParent=True&UserId=a15b6c3574fba386e933f67b3e696667&format=json 2013-12-19 10:15:44.4268, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/c3667828dc50a862f8aa35f1337fb8e9/Images/Logo?Quality=100&Tag=d104ad35-39cc-3de8-5699-ee2fed4b7039&EnableImageEnhancers=True 2013-12-19 10:15:44.4818, Debug, ApiClient, Received OK status code after 51.003 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/c3667828dc50a862f8aa35f1337fb8e9/Images/Logo?Quality=100&Tag=d104ad35-39cc-3de8-5699-ee2fed4b7039&EnableImageEnhancers=True 2013-12-19 10:15:44.9358, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/c3667828dc50a862f8aa35f1337fb8e9/Images/Primary?Width=550&Quality=100&Tag=acfde41a-60ab-a1bd-ff13-eaf0e0be8d9b&EnableImageEnhancers=True 2013-12-19 10:15:45.0448, Debug, ApiClient, Received OK status code after 91.0052 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/c3667828dc50a862f8aa35f1337fb8e9/Images/Primary?Width=550&Quality=100&Tag=acfde41a-60ab-a1bd-ff13-eaf0e0be8d9b&EnableImageEnhancers=True 2013-12-19 10:15:45.1898, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Items/c3667828dc50a862f8aa35f1337fb8e9/Images/Backdrop/0?Width=4320&Quality=100&Tag=49290bf4-48f7-d649-e118-4774b3bda239&EnableImageEnhancers=True 2013-12-19 10:15:45.6618, Debug, ApiClient, Received OK status code after 471.0269 ms from GET: http://192.168.0.10:8096/mediabrowser/Items/c3667828dc50a862f8aa35f1337fb8e9/Images/Backdrop/0?Width=4320&Quality=100&Tag=49290bf4-48f7-d649-e118-4774b3bda239&EnableImageEnhancers=True 2013-12-19 10:15:46.7339, Debug, ApiClient, GET http://192.168.0.10:8096/mediabrowser/Users/a15b6c3574fba386e933f67b3e696667/Items/c3667828dc50a862f8aa35f1337fb8e9/Intros?format=json 2013-12-19 10:15:46.7339, Debug, ApiClient, Received OK status code after 3.0002 ms from GET: http://192.168.0.10:8096/mediabrowser/Users/a15b6c3574fba386e933f67b3e696667/Items/c3667828dc50a862f8aa35f1337fb8e9/Intros?format=json 2013-12-19 10:15:46.7339, Info, DirectShowPlayer, Playing Dude, Where's My Car?. Reclock: False, Madvr: False, xySubFilter: False 2013-12-19 10:15:46.7339, Info, DirectShowPlayer, Playing Path \\RANDOM-PC7\Movies\Dude, Where's My Car_ (2000)\Dude, Where's My Car_ (2000).mp4 2013-12-19 10:15:46.9619, Error, DirectShowPlayer, Error beginning playback Cannot play back the audio stream: the audio format is not supported. System.Runtime.InteropServices.COMException at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous) at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args) at System.Windows.Forms.Control.Invoke(Delegate method) at MediaBrowser.Theater.DirectShow.InternalDirectShowPlayer.InvokeOnPlayerThread(Action action) at MediaBrowser.Theater.DirectShow.InternalDirectShowPlayer.<PlayTrack>d__d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Theater.DirectShow.InternalDirectShowPlayer.<Play>d__2.MoveNext() 2013-12-19 10:15:51.4222, Info, App, Disposing ApplicationHost 2013-12-19 10:15:51.4222, Info, App, Disposing TaskManager 2013-12-19 10:15:51.4222, Info, App, Disposing HttpClientManager 2013-12-19 10:15:51.4222, Info, App, Disposing InstallationManager 2013-12-19 10:15:51.4222, Info, App, Disposing IsoManager 2013-12-19 10:15:51.4222, Info, App, Disposing ApiClient 2013-12-19 10:15:51.4222, Info, App, Disposing ApiWebSocket 2013-12-19 10:15:51.4222, Debug, ApiWebSocket, Stopping web socket timer 2013-12-19 10:15:51.4222, Debug, ApiWebSocket, Disposing client web socket 2013-12-19 10:15:51.4222, Info, ApiWebSocket, Sending web socket close message 2013-12-19 10:15:51.4222, Info, App, Disposing PismoIsoManager 2013-12-19 10:15:51.4222, Info, App, Disposing BackdropsEntryPoint 2013-12-19 10:15:51.4222, Info, App, Disposing ScreensaverEntryPoint 2013-12-19 10:15:51.4222, Info, App, Disposing ThemeSongEntryPoint 2013-12-19 10:15:51.4222, Info, App, Disposing WebSocketEntryPoint Edited December 19, 2013 by trusselo
Luke 42237 Posted December 20, 2013 Author Posted December 20, 2013 It'll be a little while before you guys get this in a build, but i think you'll like the slide out panel that we're working on. 5
Latchmor 584 Posted December 20, 2013 Posted December 20, 2013 Likey! I like the current slide out but this does look better!
Brendon 124 Posted December 21, 2013 Posted December 21, 2013 It'll be a little while before you guys get this in a build, but i think you'll like the slide out panel that we're working on. Now you're just theatre teasing us
candybar213 7 Posted December 21, 2013 Posted December 21, 2013 The only thing I am currently waiting on to fully implament the new MBT on my media center is the green button support and full remote support do you have any idea when these will be worked on? really digging this. 1
jdpg2 8 Posted December 21, 2013 Posted December 21, 2013 Should the scenes section be working in this release (my library is ISO's) or is that a future feature?
Luke 42237 Posted December 21, 2013 Author Posted December 21, 2013 the seeking to a scene may eventually work but the server doesn't currently extract the images from iso's
jdpg2 8 Posted December 21, 2013 Posted December 21, 2013 (edited) the seeking to a scene may eventually work but the server doesn't currently extract the images from iso's That would be good enough, the skip fwd and fast fwd functions on the built in player are painfully slow when streaming an ISOs from the server. Edited December 21, 2013 by jdpg2
Ghostm 75 Posted December 26, 2013 Posted December 26, 2013 (edited) Just curious does anyone get bad screeching or static when they launch a movie using lav, and bitstream? Its randomly a split second when i launch a movie, but im worried it may blow my speakers. I have not really noticed it in mpc-hc, or xbmc. Also seems like games tab has disappeared? Edited December 26, 2013 by Ghostm
Ghostm 75 Posted December 27, 2013 Posted December 27, 2013 My bad games tab showing up after a server restart.
mph55 1 Posted December 29, 2013 Posted December 29, 2013 Hi, I've been using the MBT alpha once I heard the internal player was integrated with madvr. I think it's working better than some of the other media centers that are also integrated with madvr. Not bad for an alpha! I was wondering if you could add support for the ffdshow raw video filter for video post-proessing (not for video decoding). I still use ffdshow because it's the only directshow filter I'm aware of that's able to run avisynth scripts during playback. THere are avisynth scripts and plugins available that are better than the equivalent pixel shaders offered with madvr. Also, avisynth has scripts for debanding, etc. that until recently wasn't an option with Madvr or has yet to be developed. Thanks for your consideration.
DigiTM 60 Posted January 2, 2014 Posted January 2, 2014 My media is in mkv format and 3D Bluray ISO. Want to know if MBT is at a stage where I can have it play mkv's through the internal and only have TMT6 play the ISO 3D movies?
cylon 15 Posted January 2, 2014 Posted January 2, 2014 (edited) My media is in mkv format and 3D Bluray ISO. Want to know if MBT is at a stage where I can have it play mkv's through the internal and only have TMT6 play the ISO 3D movies? Full BD MKV playback is working perfectly with the internal MBT player. I am in the process of converting all my ISOs to MKV as it is a much nicer experience. I am yet to setup TMT6 as the external player for 3D ISOs. Edited January 2, 2014 by cylon
DigiTM 60 Posted January 2, 2014 Posted January 2, 2014 Just thought of another option for 3D. Can MBT include a MVC Decoder? Then I would transfer my 3D ISO to 3D mkv full frame. Just a thought. I don't know if this costs money though, although being just a codec I cannot see why it's payable. If it costs then have it as an addon for a cost, I'm sure there are people that would pay for the feature. 1
robnix 3 Posted January 2, 2014 Posted January 2, 2014 Just thought of another option for 3D. Can MBT include a MVC Decoder? Then I would transfer my 3D ISO to 3D mkv full frame. Just a thought. I don't know if this costs money though, although being just a codec I cannot see why it's payable. If it costs then have it as an addon for a cost, I'm sure there are people that would pay for the feature. This would be spectacular. I would gladly throw in more cash for MVC MKV support.
Ghostm 75 Posted January 3, 2014 Posted January 3, 2014 (edited) Just wondering does mbt support trailers yet as in trailers for our movie collection? I just use the streaming option for trailers, and was hoping in mbt it could play the trailers like xbmc by streaming also. Is only local trailers supported in mbt? And if so will we ever see streaming trailer option in mbt? I prefer not to download them if i dont have to. Edited January 3, 2014 by Ghostm
