yardameus 221 Posted December 3, 2013 Posted December 3, 2013 I would assume no, kinda defeats the purpose. Just remove the password.
swhitmore 781 Posted December 3, 2013 Posted December 3, 2013 I would assume no, kinda defeats the purpose. Just remove the password. Not really. A lot of people want a password because they are opening ports to use MB3 externally. It's on every other client. Luke has said that Auto Login is coming though. 1
Ghostm 75 Posted December 3, 2013 Posted December 3, 2013 So after understanding the importance of reclock while staring at mpc-hc osd and noticing eventually a small microstutter and repeated frames racking up i want to resend my feature request to replace reclock for internal wasapi i made yesterday in this forum, unless luke is able to build his own reclock internally into mbt somehow which would probably be a huge undertaking. With that said now that i worked out the kinks in reclock, what can we do about the video backdrop audio dropout due to reclock syncing? Following media browser theater suggestion i purchased the backdrops and they are incredible, but the issue remains if we are to use reclock to remove microstutter, the audio drops out when browsing movies and when the video backdrop plays....this is quite a concern and quite annoying as i browse movies and the backdrop plays, the audio constantly drops at the start so reclock can sync the audio. I dont know what can be done about it though. Can we somehow block reclock from being activated when backdrops play? And only activate when MBT internal video player is active? Can this be accomplished somehow? 1
cylon 15 Posted December 4, 2013 Posted December 4, 2013 (edited) I personally am amazed that we have decided to go with the re-clock option.. I believe we are fixing a problem with a mistake.. Re-clock is a great tool for power users and for those that get their stuff from al over the web, but if you rip the movies correctly you should not need re-clock or similar utilities. Having said that, re-clock is in MBT as a option ( I tried it but it runs to much interference) and since MBT still uses external codecs, there maybe room for other choices.. It all depends on what you are doing. If you are doing frame rate switching it is best to do the pulldown at the source rather than on your TV/Projector. ReClock can help stop motion judder and audio sync issues in this regard. Having said that if you are using madVR with Smooth Motion Frame Rate Changer (SMFRC) enabled then there is no need for ReClock as it multiplies the source frame rate out to "infinity" and then divides it back into the display frame rate. Having the option to use both madVR and ReClock doesn't make a lot of sense to me but I have a powerful enough GPU to use madVR and take the workload off the CPU. If your machine is that low speck that madVR is not an option then there is an advantage is using ReClock. Edited December 4, 2013 by cylon 1
ronvp 92 Posted December 4, 2013 Posted December 4, 2013 Following media browser theater suggestion i purchased the backdrops and they are incredible, but the issue remains if we are to use reclock to remove microstutter, the audio drops out when browsing movies and when the video backdrop plays....this is quite a concern and quite annoying as i browse movies and the backdrop plays, the audio constantly drops at the start so reclock can sync the audio. I personally am amazed that we have decided to go with the re-clock option.. I believe we are fixing a problem with a mistake.. Re-clock is a great tool for power users and for those that get their stuff from al over the web, but if you rip the movies correctly you should not need re-clock or similar utilities. Having said that, re-clock is in MBT as a option ( I tried it but it runs to much interference) and since MBT still uses external codecs, there maybe room for other choices..
joshstix 25 Posted December 4, 2013 Posted December 4, 2013 I have a question about expected behaviour with MBT. Should MBT be able to continue to play a video file that is already started if the MB server is restarted for the install of an update etc? I expect it to but in my situation it gives an error that kills the player as soon as it is responded to.
yardameus 221 Posted December 4, 2013 Posted December 4, 2013 Not really. A lot of people want a password because they are opening ports to use MB3 externally. It's on every other client. Luke has said that Auto Login is coming though. I was thinking along the lines of multiple users (parental controls). What you said makes sense though.
Ghostm 75 Posted December 4, 2013 Posted December 4, 2013 (edited) Isn't the smooth motion in madvr for playing back 23.976 bluray content at 60hz for example for tv's that cant do 23.976? And i thought it was to be avoided if your tv can do 23.976? And 50hz, and 60hz, and most refresh rates? The problem for me is ati systems or nvidia i dont believe can do exactly 23.976, and hence the occasional microstutter.... Not a big fan of reclock but unless luke would be able to do something internally like reclock with wasapi and syncing i dont think we have much choice. It is a big problem that video backdrops are a huge part of mbt presentation and reclock basically causes audio to drop whenever they load however. Also as someone who rips 1:1 blurays with a projector i dont know if its an option im eager to use? From madashi "23-25fps -> 60Hz: minimal sharpness loss, nearly invisible 24fps -> 24Hz: visible sharpness loss60fps -> 24Hz: very noticeable sharpness loss" Edited December 4, 2013 by Ghostm
Ghostm 75 Posted December 4, 2013 Posted December 4, 2013 (edited) May i also ask who is working on mbt? Its such a great player with so much potential, but alot to be done yet, is it really just luke basically working on this?I hope he can get some help in this.....I cant imagine the work he has to put in.... the sooner i can finally switch from xbmc for good. I wish i knew more and could help, but instead I will just donate. I know he said server comes first, but mbt has so much potential yet with some work and kinks to be ironed out i think if he has enough support working on it, it can be an incredible solution for htpc users within months. Edited December 4, 2013 by Ghostm
Luke 42237 Posted December 4, 2013 Author Posted December 4, 2013 i have another developer who has just started, and another guy from doom9 helping out with the video player. but i need another wpf developer. so any recruiting help would be welcome. 1
cylon 15 Posted December 4, 2013 Posted December 4, 2013 (edited) "23-25fps -> 60Hz: minimal sharpness loss, nearly invisible 24fps -> 24Hz: visible sharpness loss 60fps -> 24Hz: very noticeable sharpness loss" Yeah, I read that too when I started testing SMFRC. I also have 1:1 Blu-ray copies; my HTPC is outputting to my projector at 60Hz and I have SMFRC turned on permanently. So I am in the 23-25fps -> 60Hz boat. I have always hated jitter but I hate smooth motion even more so I was sceptical that SMFRC would be a solution to all my problems. But after many hours of watching multiple types of content I can honestly say that I love it. Picture quality is as good as it has always been and motion is fantastic, I have had friends ask how I have managed to get motion flow working without it being distracting. I am sure the 23-25fps purists are cringing as they read this but I suggest you give it a go. Edited December 4, 2013 by cylon
madfloyd 0 Posted December 4, 2013 Posted December 4, 2013 My understanding is that reclock prevents bitstreaming of high rez audio tracks. Is this correct? If so, why would anyone use it?
Luke 42237 Posted December 5, 2013 Author Posted December 5, 2013 Our new contributor has just implemented auto-login, so i've moved that to the done list. it's not going to go public right away but rest assured the wheels are moving a little faster now with an extra set of hands. 7
joshstix 25 Posted December 5, 2013 Posted December 5, 2013 Great to hear you are getting help on this, the work you've already done is brilliant and I'm sure it will get even better with you having a team to work on it now.
kamakamadaun 6 Posted December 5, 2013 Posted December 5, 2013 (edited) Maximixing/minimizing the windows I got this: See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.NullReferenceException: Object reference not set to an instance of an object. at MediaBrowser.Theater.DirectShow.DirectShowPlayer.SetAspectRatio(Nullable`1 ratio, Boolean setVideoWindow) at MediaBrowser.Theater.DirectShow.DirectShowPlayer._hiddenWindow_SizeChanged(Object sender, EventArgs e) at System.EventHandler.Invoke(Object sender, EventArgs e) at System.Windows.Forms.Control.OnSizeChanged(EventArgs e) at System.Windows.Forms.Control.UpdateBounds(Int32 x, Int32 y, Int32 width, Int32 height, Int32 clientWidth, Int32 clientHeight) at System.Windows.Forms.Control.UpdateBounds() at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at MediaBrowser.UI.HiddenForm.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18052 built by: FX45RTMGDR CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll ---------------------------------------- MediaBrowser.UI Assembly Version: 3.0.5086.905 Win32 Version: 3.0.5086.905 CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/MediaBrowser.UI.exe ---------------------------------------- PresentationFramework Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18060 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll ---------------------------------------- WindowsBase Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18060 built by: FX45RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll ---------------------------------------- System Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18044 built by: FX45RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- PresentationCore Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18060 built by: FX45RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll ---------------------------------------- System.Xaml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18015 built by: FX45RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll ---------------------------------------- MediaBrowser.Theater.Implementations Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/MediaBrowser.Theater.Implementations.DLL ---------------------------------------- MediaBrowser.Common.Implementations Assembly Version: 3.0.5083.366 Win32 Version: 3.0.5083.366 CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/MediaBrowser.Common.Implementations.DLL ---------------------------------------- MediaBrowser.Common Assembly Version: 3.0.5083.366 Win32 Version: 3.0.5083.366 CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/MediaBrowser.Common.DLL ---------------------------------------- MediaBrowser.Model Assembly Version: 3.0.5083.365 Win32 Version: 3.0.5083.365 CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/MediaBrowser.Model.DLL ---------------------------------------- System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18060 built by: FX45RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18060 built by: FX45RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- NLog Assembly Version: 2.1.0.0 Win32 Version: 2.1.0.0 CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/NLog.DLL ---------------------------------------- System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18047 built by: FX45RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18021 built by: FX45RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.ServiceModel Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18055 built by: FX45RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll ---------------------------------------- System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17929 built by: FX45RTMREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- System.Data Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18047 built by: FX45RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll ---------------------------------------- System.Runtime.Serialization Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18055 built by: FX45RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll ---------------------------------------- MediaBrowser.Theater.Presentation Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/MediaBrowser.Theater.Presentation.DLL ---------------------------------------- PresentationFramework.Aero Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17929 built by: FX45RTMREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll ---------------------------------------- MediaBrowser.Theater.Core Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/MediaBrowser.Theater.Core.DLL ---------------------------------------- MediaBrowser.Theater.Interfaces Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/MediaBrowser.Theater.Interfaces.DLL ---------------------------------------- SimpleInjector Assembly Version: 2.3.6.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/SimpleInjector.DLL ---------------------------------------- ServiceStack.Text Assembly Version: 3.9.70.0 Win32 Version: 3.9.70.0 CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/ServiceStack.Text.DLL ---------------------------------------- Microsoft.GeneratedCode Assembly Version: 1.0.0.0 Win32 Version: 4.0.30319.18060 built by: FX45RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- MediaBrowser.Plugins.DefaultTheme Assembly Version: 3.0.5086.904 Win32 Version: 3.0.5086.904 CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/MediaBrowser.Plugins.DefaultTheme.DLL ---------------------------------------- MediaBrowser.IsoMounter Assembly Version: 1.0.5079.1480 Win32 Version: 1.0.5079.1480 CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/MediaBrowser.IsoMounter.DLL ---------------------------------------- MediaBrowser.Theater.DirectShow Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/MediaBrowser.Theater.DirectShow.DLL ---------------------------------------- DirectShowLib-2005 Assembly Version: 2.0.0.0 Win32 Version: 2.0.0.0 CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/DirectShowLib-2005.DLL ---------------------------------------- pfmclrapi Assembly Version: 0.0.0.0 Win32 Version: CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/pfmclrapi.DLL ---------------------------------------- MediaBrowser.ApiInteraction Assembly Version: 3.0.5083.604 Win32 Version: 3.0.5083.604 CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/MediaBrowser.ApiInteraction.DLL ---------------------------------------- System.Net.Http Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17929 built by: FX45RTMREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Net.Http/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Net.Http.dll ---------------------------------------- Anonymously Hosted DynamicMethods Assembly Assembly Version: 0.0.0.0 Win32 Version: 4.0.30319.18052 built by: FX45RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll ---------------------------------------- SimpleInjector.Compiled_1 Assembly Version: 0.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/SimpleInjector.dll ---------------------------------------- Microsoft.Expression.Interactions Assembly Version: 4.0.0.0 Win32 Version: 2.0.20525.0 CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/Microsoft.Expression.Interactions.DLL ---------------------------------------- Microsoft.Expression.Effects Assembly Version: 4.0.0.0 Win32 Version: 2.0.20525.0 CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/Microsoft.Expression.Effects.DLL ---------------------------------------- PresentationFramework-SystemXml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17929 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll ---------------------------------------- UIAutomationTypes Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17929 built by: FX45RTMREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll ---------------------------------------- PresentationFramework-SystemCore Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17929 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll ---------------------------------------- CoreAudioApi Assembly Version: 2.0.0.0 Win32 Version: 2.0.0.0 CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/CoreAudioApi.DLL ---------------------------------------- System.Data.Linq Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18060 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Data.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Data.Linq.dll ---------------------------------------- WebSocket4Net Assembly Version: 0.8.0.0 Win32 Version: 0.8.0.0 CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/WebSocket4Net.DLL ---------------------------------------- WindowsFormsIntegration Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18060 built by: FX45RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll ---------------------------------------- PresentationFramework-SystemData Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17929 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll ---------------------------------------- System.Numerics Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17929 built by: FX45RTMREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll ---------------------------------------- Hyper.ComponentModel.dynamic Assembly Version: 0.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/MediaBrowser.Theater.Interfaces.dll ---------------------------------------- System.Deployment Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17929 built by: FX45RTMREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Deployment/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll ---------------------------------------- MediaFoundation Assembly Version: 2.0.0.0 Win32 Version: 2.0.0.0 CodeBase: file:///C:/Users/no_name_here/AppData/Roaming/MediaBrowser-Theater/system/MediaFoundation.DLL ---------------------------------------- UIAutomationProvider Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.17929 built by: FX45RTMREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box. Also playback of WTV files is choppy. edit: seems it was not just WTV files. I cannot isolate the issue to something specific. Some files are fine. For others the video stutters. Edited December 4, 2013 by kamakamadaun
kamakamadaun 6 Posted December 5, 2013 Posted December 5, 2013 Aha. It stutters in full screen. Not in windowed mode.
Pirlo1966 22 Posted December 7, 2013 Posted December 7, 2013 My understanding is that reclock prevents bitstreaming of high rez audio tracks. Is this correct? If so, why would anyone use it? Not correct. You can bitsream but it is just not recommended. Anyways, reclock outputs PCM (HD audio). There is as far as I know no reason why one would like to bitstream.
Pirlo1966 22 Posted December 7, 2013 Posted December 7, 2013 It all depends on what you are doing. If you are doing frame rate switching it is best to do the pulldown at the source rather than on your TV/Projector. ReClock can help stop motion judder and audio sync issues in this regard. Having said that if you are using madVR with Smooth Motion Frame Rate Changer (SMFRC) enabled then there is no need for ReClock as it multiplies the source frame rate out to "infinity" and then divides it back into the display frame rate. Having the option to use both madVR and ReClock doesn't make a lot of sense to me but I have a powerful enough GPU to use madVR and take the workload off the CPU. If your machine is that low speck that madVR is not an option then there is an advantage is using ReClock. In Europe most DVD's are 25fps. Video and audio are speeded up with 4% vs the original source of 24fps. Therefore Bruce Willis sounds like a little girl. What reclock does is readapting the 25fps into 24fps. Bruce Willis sounds like Bruce Willis again.
madfloyd 0 Posted December 8, 2013 Posted December 8, 2013 Is anyone getting smooth playback of 1080p material with MBT?
pagali 62 Posted December 8, 2013 Posted December 8, 2013 (edited) OK, I need to know what settings all you "Yes" people are using. I'm still getting severe tearing with the MBT internal player. All other players on my HTPC play perfectly. (MPC-HC, ZP, VLC, TMT5, XBMC) Edited December 8, 2013 by pagali
Erik 124 Posted December 8, 2013 Posted December 8, 2013 Here is my setup: HTPCs are very similar. i3 CPUs, 4GB ram and Nvidia chip pci-e video cards (GT430, GT620). 2 are wired Gigabit and one is wireless N. All 3 are virgin windows 8.1 with standard MBT installation (LAV filters). Also installed the most current nvidia drivers. The server is an i7 with 16GB ram and wired Ethernet. Storage is a mix if seagate HD's and WD Red drives through a LSI card. All play 1080p blu-rays without any hesitation through MBT or the Web Browser (transcoding still at 1080p). The only settings I changed in LAV is for bit-streaming to the stereo and enable NVIDIA CUVID. The rest is left at default.
