mangis 10 Posted May 15, 2015 Posted May 15, 2015 Hi Scott I'm having some issues with playing just audio in the app at the moment - both from the podcasts channel and music. It looks like the ffmpeg process is stopping just after the transcoding starts. I can't see anything in the transcode logs when music playback is attempted (although I wouldn't know what to look for) but when trying podcasts I am seeing - Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height. So it's entirely possible that it's not an issue with the app at all and is something server side. Just wondering if you've come across anything like this. Thanks mate.
Solution Luke 42240 Posted May 15, 2015 Solution Posted May 15, 2015 the audio issue is resolved for the next server release 1
mangis 10 Posted May 15, 2015 Author Posted May 15, 2015 Awesome. Thanks mate, appreciate the quick response. It'll stop me from playing around with settings all night
sprtfan 3 Posted June 8, 2015 Posted June 8, 2015 I mentioned in another thread I was having problems getting Music to start/play in the phone app but thought the questions probably belonged here. Has the server update that fixed this rolled out yet? I just want to see so I don't spend time trying to find a problem on my end if its just a matter of waiting for a new server release. Thanks
ScottIsAFool 517 Posted June 8, 2015 Posted June 8, 2015 It should have been, yes. Can you clear out the logs (in the about window), then try playing some music again. If/when that fails, go back to the about screen and send the logs, I'll see if there's anything in there.
sprtfan 3 Posted June 9, 2015 Posted June 9, 2015 (edited) I sent the log. Thanks for any help. Edit : I ended up sending a second log as well because the first one didn't look like there was much in it. Thanks Edited June 9, 2015 by sprtfan
ScottIsAFool 517 Posted June 9, 2015 Posted June 9, 2015 Thanks. If you sign out of Connect, and sign back in (all within the app), will it start the audio then?
sprtfan 3 Posted June 9, 2015 Posted June 9, 2015 I signed out, and then signed back in and was still not able to get the audio to start. Thanks
scorchedcortex 1 Posted July 4, 2015 Posted July 4, 2015 I'm experiencing the same issue with the current app downloaded from the Windows Phone store. It worked fine up until a week or so ago. Any fix for this in the pipeline? Thanks for your help!
ScottIsAFool 517 Posted July 6, 2015 Posted July 6, 2015 Hang on, so you were having no issues playing music up until a week ago? Any issues at all before that?
scorchedcortex 1 Posted July 6, 2015 Posted July 6, 2015 Hang on, so you were having no issues playing music up until a week ago? Any issues at all before that? No issues at all. I was able to play audio with no problem. It may have been a little more than a week ago, but not much longer. I hadn't used the app during that time, but when I used it a couple of days ago it wouldn't play audio.
