Hi all
Not sure if it's a known issue or just my setup but I'm experiencing an issue with audio playback to all clients except MBC.
It appears to be a problem with ffmpeg, it starts up when I hit play but then quits after a few seconds. I can see an error in the transcode logs when playing podcasts.
Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height.
This is also happening with the Windows Phone app, everything appears to start and then ffmpeg gives up the ghost.
Any pointers in the right direction would be greatly appreciated.
Thanks
Edited by mangis
Answered by Luke in another thread - will be resolved in the next server release.
