Angelblue05 4132 Posted May 14, 2015 Posted May 14, 2015 (edited) I'm trying to implement the general commands in Emby for Kodi. There's one thing I just can't get to work and it's the volume slider/ which I'm guessing is the SetVolume(Arguments: volume scale 0-100). I'm able to get the volume to change in Kodi, but the volume slider does not remain in place, it seems to always reset back to 0 visually. I'm guessing I need to tell this information to the server, but I can't figure out what or where I tell the server the current volume set in Kodi. Can anyone point me in the right direction? Thanks Edit: Nevermind, found the answer in an unexpected wiki section: https://github.com/MediaBrowser/MediaBrowser/wiki/Playback-Check-ins Edited May 14, 2015 by Angelblue05
Angelblue05 4132 Posted May 15, 2015 Author Posted May 15, 2015 Yes, I didn't noticed the first time around, but I figured it out thanks ebr Sent from my iPhone using Tapatalk
