cw-kid 192 Posted May 12, 2015 Posted May 12, 2015 (edited) Hi I seem to be having issues with my TV files that are multi episodes An example: Star Wars The Clone Wars - S02E01-E02 - Holocron Heist & Cargo of Doom.avi Star Wars The Clone Wars - S02E01-E02 - Holocron Heist & Cargo of Doom.nfo This is supported in Kodi / XBMC. Looking on your Wiki here is also seems this should be supported: S01E02-E03 episode name.avi However for this in the Emby web GUI there is a red triangle next to it The Kodi created nfo has information in for both Episode 1 and Episode 2. How do I correct this issue? Thanks Edited May 12, 2015 by cw-kid
cw-kid 192 Posted May 12, 2015 Author Posted May 12, 2015 (edited) I just ran an Advanced Refresh on the entry as shown in the screen shot above in the metadata manager and now the red triangle has gone. Why did I have to do this? Also Emby has not correctly set the Played status to Watched. The original Kodi nfo file for both these episodes said <watched>true</watched> Thanks Edited May 12, 2015 by cw-kid
Luke 42186 Posted May 15, 2015 Posted May 15, 2015 the red triangle could be more clear, and i'll work on that, but what it means is that there was some failure when attempting to download metadata. it could mean nothing was found due to inability to match on tvdb/tmdb, etc. or it could mean an http request failure. stacked episodes with multiple episodes in one nfo are a relatively new thing and it's the one thing we're missing with nfo support. we'll try to get it in soon, if not for the next release. in the meantime if you could provide an example file that would be helpful, thanks.
cw-kid 192 Posted May 15, 2015 Author Posted May 15, 2015 Great thanks Luke! I don't have loads of video files that contain multiple episodes, but for everyone of them I did have the red triangle on them and a missing watched status tick. I ran the refresh on each of these episodes to clear the red triangle and manually set them as watched if they were.
cw-kid 192 Posted July 22, 2015 Author Posted July 22, 2015 Looking at these TV Show files that contain more than one episode in both Kodi and the Emby web GUI I don't seem to be getting any metadata like the synopsis text for the episodes. Emby Web GUI: Kodi Helix with Emby add-on: Native Kodi Helix with MYSQL: As you can see the native Kodi seems to handle these types of episodes differently and there is an instance for each episode, even though the two episodes are actually in the same video file. Thanks
ebr 16307 Posted July 22, 2015 Posted July 22, 2015 What happens if you get rid of the "E1-2" at the beginning of that file name?
cw-kid 192 Posted July 22, 2015 Author Posted July 22, 2015 Hi Thanks for your reply! The file is actually named as "Knight Rider - S01E01-E02 - Knight Of The Phoenix.avi" All my multi episode video files are named the same as that format and native Kodi is OK handling them. Here is a screen shot from the file server:
Luke 42186 Posted July 22, 2015 Posted July 22, 2015 The issue is we merge metadata in this situation where Kodi keeps them separate. It's on the roadmap to revisit.
cw-kid 192 Posted July 22, 2015 Author Posted July 22, 2015 OK cool thanks Luke I will leave it for now then.
Marv 9 Posted February 27, 2016 Posted February 27, 2016 Hi everyone, I'm new to Emby and love it! I use Emby Server with unRAID in a docker container and just installed the Kodi addon. Everything is working perfect except the issue described above by cw-kid. Is there a workaround somehow or a setting because it seems that this issue is not solved yet. Can someone clear me up please. Thanks
cw-kid 192 Posted February 27, 2016 Author Posted February 27, 2016 There was some work done on the Kodi add-on to display multi episodes better than it was, this is how it looks now.
Marv 9 Posted February 27, 2016 Posted February 27, 2016 Hm, strange... because for me it seems that Emby does not import anything from the nfo file (I also don't see anything in the Emby Server Web Interface) I use nearly the same structure as you. The only difference is the naming syntax, I use: S01E01E02 instead of S01E01-E02 Does this make the difference maybe or is there some setting inside the Kodi addon to display multi-episode files!?
cw-kid 192 Posted February 27, 2016 Author Posted February 27, 2016 There is no setting for this in the add-on and I doubt the file naming is the problem. How do the multi episodes look in the Emby web GUI?
Marv 9 Posted February 28, 2016 Posted February 28, 2016 it looks like this: So it doesn't import any information from the nfo file aswell
cw-kid 192 Posted February 28, 2016 Author Posted February 28, 2016 I can see on your screen shot you have missing synopsis. If your talking about nfo files created by Kodi's library export routine there was lots of issues and bugs with how Emby read them, some where fixed after I reported them others may not have been. Have you now got Emby server configured to create its own new nfo files? It will also edit update existing ones. Only thing I can suggest is to delete the nfo files for these multi episode files and let Emby do its own thing and get the metadata for them, you maybe able to just do a refresh in the Emby metadata manger for these episodes or you may have to remove the files out of the watched folder so they are removed from the Emby library and then put them back etc.
Marv 9 Posted February 29, 2016 Posted February 29, 2016 I always use MediaElch to create my nfo files for Kodi. There has never been a problem reading them. This is why I actually don't want Emby to create its own nfo files. I will try to overwrite them with the metadata manager first I think. Maybe that way Emby changes the syntax of the nfo files!?
cw-kid 192 Posted February 29, 2016 Author Posted February 29, 2016 If you preffered you could have NFO file creation disabled on the Emby server there is a setting for it. Then maybe try adding the multi episodes to the Emby library without your MediaElch NFO files being present, Emby should just add them correctly then.
cw-kid 192 Posted February 29, 2016 Author Posted February 29, 2016 I know there is / was some differences between the NFO files that native Kodi created and those that Emby server creates they are not 100% compatible with each other. Main issue I have remaining now is native Kodi does not display Media Codec Icons for my AVI DIVX / Xvid files because the codec Info in the Emby generated NFO files is not understood by native Kodi. If your using the Emby add-on for Kodi then you won't see this problem as their add-on does some mapping to work around these types of issues.
cw-kid 192 Posted February 29, 2016 Author Posted February 29, 2016 And just so you can see, this is how a multi part episode should look like in the Emby Server web GUI.
Marv 9 Posted February 29, 2016 Posted February 29, 2016 Thanks for your help. I let Emby fetch the metadata for my multi-episodes now. Everything works now. But I'm not very happy with this solution. Hopefully Emby will be compatible in the future for standard multi-episode nfo files
