BigBlueBall 0 Posted May 12, 2015 Posted May 12, 2015 (edited) Hi! I have posters for all but 1 of my Videos. Anyone know how I can generate the poster? I use Cover Art 4.0. Edited May 12, 2015 by BigBlueBall
MndWrp 101 Posted May 12, 2015 Posted May 12, 2015 if it's a movie or tv show that can be easily found online if it's a home movie or something rarer i guess you can screegrab via vlc or something... what is the video ?
BigBlueBall 0 Posted May 12, 2015 Author Posted May 12, 2015 (edited) It's a home video. Cover Art generated all of the others. Why won't it generate this 1 family video? Edited May 12, 2015 by BigBlueBall
MndWrp 101 Posted May 12, 2015 Posted May 12, 2015 i'm not really sure ... is it in a different file format ?
BigBlueBall 0 Posted May 12, 2015 Author Posted May 12, 2015 mp4 file. My other mp4 files have posters.
MndWrp 101 Posted May 12, 2015 Posted May 12, 2015 do you have vlc installed ? i guess you can make a screengrab and manually add that as a thumbnail.
BigBlueBall 0 Posted May 12, 2015 Author Posted May 12, 2015 I'd like to get Cover Art 4.0. working again for new videos that I will add.
MndWrp 101 Posted May 12, 2015 Posted May 12, 2015 i dont use it myself .. so that might be an issue for someone else then
ebr 16307 Posted May 12, 2015 Posted May 12, 2015 CoverArt doesn't actually create these - the server does - if you have the ScreenGrabber enabled for that item type. First ensure that, and then do an advanced refresh on the item from the metadata editor - replacing all images.
