MndWrp 101 Posted May 12, 2015 Posted May 12, 2015 Hi all ! here is my situation I have a lot of blu-ray rips stored on my Nas. I rip them myself with MakeMkv and do not recompress the files to keep optimum quality. I have a pretty fast gigbit router and devices galore to play the files but the key componenent i'm missing is a dedicated server. I was thinking of going with an i7 NUC with at least 16 gigs of ram, for the size of it and the low power consuption. Question 1 Obviously... is the NUC a good choice to be able to transcode at the most 3-4 simultaneous streams. I guess about half my rips are vc1 and the other half h264 ... with the odd mpeg2 ... Question 2 I did read somewhere that vc1 only transcodes via ffmpeg on only 1 core .. will that be a problem considering the NUC im looking to buy ? would it be better to bite the bullet and recompress them as h264 ? Question 3 In my rips i keep the original PGS subtitles and that obvioulsy triggers transcoding when i play them. Again... will that be an issue down the line or should i painstakingly switch them to srt files ? i'm still fairly new to all this, so any help and opinions are most welcome ! thanks !
MndWrp 101 Posted May 12, 2015 Author Posted May 12, 2015 stumped huh ? i thought i would get some answers at least ...
