irishfrog 0 Posted May 12, 2015 Posted May 12, 2015 Hi I setup android user that needed a password now if i log into server on the server none of the users wanna work Tries rest password but still im getting error username or password incorrect I am unable to get into server at all but the wmc pc can still see server and works fine
Luke 42217 Posted May 12, 2015 Posted May 12, 2015 if you can login from the wmc app then it sounds like more of a connectivity problem then a password problem
irishfrog 0 Posted May 12, 2015 Author Posted May 12, 2015 yes but i fixed it by deleting users under appdata .....tks anyway
chope915 0 Posted May 12, 2015 Posted May 12, 2015 I have never been able to reset a password from a FireFox browser for some reason. If you're using FireFox try using another browser instead. Chrome works great for me.
omar85 0 Posted October 30, 2019 Posted October 30, 2019 My password works to login here, but it doesn't work to login to http://app.emby.media/. Please help.
pwhodges 2028 Posted October 30, 2019 Posted October 30, 2019 The forum and your Emby server have entirely different logins.
Happy2Play 9806 Posted October 31, 2019 Posted October 31, 2019 (edited) My password works to login here, but it doesn't work to login to http://app.emby.media/. Please help. Sorry, but do you have a Emby server installed? If so can you log in with your local user? Edited October 31, 2019 by Happy2Play
ebr 16313 Posted October 31, 2019 Posted October 31, 2019 The forum and your Emby server have entirely different logins. That isn't 100% true as it is possible to connect a forum account to your server and, thus, use that id/password to access it. This is what we call Emby Connect but it must be setup for a user on your server.
pwhodges 2028 Posted October 31, 2019 Posted October 31, 2019 Oh, sorry - I hadn't realised the link between the forum and Emby Connect (which I don't use, having found it more confusing than useful when I was first trying Emby).
