Josh4u 3 Posted May 10, 2015 Posted May 10, 2015 Hi Folks - anyone know how to remove the green "number of episodes" icon or reduce it in size? On my Sony Bravia 2013 model you can hardly see the series artwork as the green icon takes up nearly half the image?? I've added a pic to let you good folks know what I mean. Apparently at this time there is also no way of being able to "hide" an empty series folder once you have deleted the shows after watching them - seems odd? Thanks in advance
Josh4u 3 Posted May 12, 2015 Author Posted May 12, 2015 Sorry should have said my bravia is a KDL-55W905A. The green icons showing for "the number of episodes" in each folder are way too big? Any way of reducing the size or turning off that feature?
Luke 42239 Posted May 12, 2015 Posted May 12, 2015 at the moment, no. it will be looked at in a future release.
Josh4u 3 Posted May 13, 2015 Author Posted May 13, 2015 Many thanks for the reply Luke - very nice piece of software.
Luke 42239 Posted August 27, 2016 Posted August 27, 2016 The latest beta of Emby Server, 3.1.125, has numerous fixes for Sony Blu ray players from years 2013-2016. The changes will also be in the next stable release of Emby Server. Since I have a device for testing I am now able to test it fully and with the changes I've made everything is now playing perfectly. It's possible that some of these improvements can be applied to older players or sony bravia tv's, but I do not have those devices available to test with, so for that I'll need to rely on community help. Enjoy.
