When playing sometimes get msg "Opening signal"
Iorifly
I do not know what's going on, sometimes when trying to play movie or show, I get the msg opening signal and stands ....
   Ja desmarquei the option:
   "Play from http instead of SMB"
Still time work hours this msg appears and nothing happens.
Iorifly
If I restart my kodi, back to work.
Angelblue05
@lorifly can you post your log as we are trying to make playback smart - if it fails to access you path for direct play then it will try to direct stream instead.
However, if it's failing because you have special characters, a fix will be available for it today.
Sent from my iPhone using Tapatalk
Edited by Angelblue05
Iorifly
Angelblue05, xnappo and im85288,
     Your work this plugin this wonderful ... I will generate a log when it happens again.
   Thank you for answering my topic.
Angelblue05
@lorifly
Did it happen again since? Let me know if this is fixed so I can mark the thread as completed. Thanks :)
If not, have you tried v0.1.81 to see if it resolves your problem? :)
Guest
