saitoh183 137 Posted May 7, 2015 Posted May 7, 2015 It is a weird issue set 2 sync jobs with the same settings for the same mkv file one for my Android and one for the Windows 8.1 app when i checked the converted files they werent the same size i opened both in the convert destination and they both had sound when they were both synced to there respective devices, The Android one was working and the Win 8.1 file didnt play. Opened the file in VLC and it had no sound. When i check the mediainfo on the file, only video info is shown...no audio Here are the logs from server for conversions and transfer: Android Logs: https://www.dropbox.com/sh/y5b47uebwpyhydc/AACNaOoFXmlX25Ddfu5FSCaLa?dl=0 Win8 app :https://www.dropbox.com/sh/6eilxmxchqpw9ky/AABP9_ua79zPOZSOdTPXkN6ka?dl=0
Luke 42184 Posted May 7, 2015 Posted May 7, 2015 the win8 log doesn't appear to be from win8 so i stopped - but the synced files won't be the same, they're creating using the profiles from the apps
saitoh183 137 Posted May 7, 2015 Author Posted May 7, 2015 @@Luke the win8 log file is the one that starts with the word log. And the rest of the files are the server
saitoh183 137 Posted May 7, 2015 Author Posted May 7, 2015 @@Luke Ok...for the size but why would the the file loose audio once transferred? The version sent to the Android worked but the audio was a bit out of sync.
