cw-kid 192 Posted May 7, 2015 Posted May 7, 2015 Hi Why do my TV Shows look like this? When I select "Shows" all I see are some of my sub-folders. If I click in to one of the Videos sub-folders then I can see the TV Shows but they are listed as Seasons My folder structure is as follows: Server \TV \DVD \VIDEOS \Nameofshow1 \Nameofshow2 \Kids TV \DVD \VIDEOS \Nameofshow1 \Nameofshow2 The episode Video files are all named correctly for Kodi. Thanks
Solution Luke 42184 Posted May 7, 2015 Solution Posted May 7, 2015 You need to adjust your library setup. See the section on complex structures here: https://github.com/MediaBrowser/Wiki/wiki/TV%20naming 1
cw-kid 192 Posted May 7, 2015 Author Posted May 7, 2015 Hi Luke In the Emby server setup I added the folders TV and Kids TV So by the sounds of it, I should have not added these top level folders, but instead added the sub-folders VIDEOS "In more complex situations where your top-level directory is further sub-divided before the show folders, the recommended option is to create a TV media folder and add the sub-folder locations instead of the top level folder." I will try and change this then. Thanks 1
cw-kid 192 Posted May 7, 2015 Author Posted May 7, 2015 OK that works! I changed it to be this: So what about the path substitution Am I meant to add them for these VIDEOS sub-folders as well? Cheers 1
