genesisforlive 7 Posted May 7, 2015 Posted May 7, 2015 Hi , first sorry für English transelate :F here is the German Post http://emby.media/community/index.php?/topic/21134-https-und-emby/I 'm still in the testing phase with Emby : DCurrently I am extremely pleased in terms of browser history and co. Now to my problem :I have everything everything goes smoothly on https port 443 and created and the browser .Unfortunately, neither the Kodi Addin nor the Media Theater or the IOS App and co Works . In Wiki I could see not the all applications are designed for https .Is there a road map or a list of Anwensungen / apps already run on https ? Emby itself I find it cool and it's fun , it would even help with Livetime Abbo . But would the mindestvorraussetztung https for everything for me . greeting
pir8radio 1313 Posted May 8, 2015 Posted May 8, 2015 wow that translator sucks... I'm sure its just as bad going from English to German so I wont even try. I don't know the answer to your question, but I'm going to repeat your question for the people that gave up reading half way through... You want a list of Emby apps that support HTTPS, and a possible time frame that other apps will support HTTPS. FYI The Emby web browser client looks pretty good on almost all devices and web browsers support https....
Angelblue05 4132 Posted May 8, 2015 Posted May 8, 2015 @@pir8radio lol, you'd think translator would evolve with time, but it's still terrible in 2015. @@genesisforlive I've added support for HTTPS with the Emby for Kodi addon. Are you saying it's not working? What settings are you using?
genesisforlive 7 Posted May 8, 2015 Author Posted May 8, 2015 Thx for the awnsers i use port 443 for emby in house and from external i use 1 DNS name like https://emby.domain.de for both (in and external) i have try last day with the kodi addon and Port 80 ok und 443 not (need a extra setting?) @@pir8radio yes web is nice und works great but only with stereo sound, no dts or ac3 greeting @@genesisforlive I've added support for HTTPS with the Emby for Kodi addon. Are you saying it's not working? What settings are you using?
genesisforlive 7 Posted May 9, 2015 Author Posted May 9, 2015 Da die Lösung Emby for Kodi is what you want: http://emby.media/co...kodi-open-beta/ First you install this repo in Kodi: http://cdn.mediabrow....kodi-1.0.1.zip Then in the repo > Video add-ons > Emby for Kodi Primary server address is your Emby server address Port should be 8920 unless you changed it (it tells you what it is in your Emby dashboard) Enable HTTPS Sorry that I missed this information earlier. You will be pleasantly surprised, I'm sure! If you need help, don't hesitate to ask. 1
