mprassel 19 Posted May 7, 2015 Posted May 7, 2015 I have never had the next up notification work for me. I've attached a log but I'm not sure if it's helpful enough. Let me know if I should enable debug logging. Thanks! 01_KODI.log
im85288 1493 Posted May 7, 2015 Posted May 7, 2015 Have you enabled it in the settings? Also it might be worth checking/changing the time from the end for when it pops up..
nosaj72 0 Posted May 7, 2015 Posted May 7, 2015 I haven't been able to get it working either. Under what conditions should I expect it to show up?
im85288 1493 Posted May 7, 2015 Posted May 7, 2015 As long as you have enabled it in settings it should show up 20 seconds before the end of playback of an episode that is un watched and has a next episode in the season available to play. You can configure the time where it pops up in settings (I changed mine to 30 seconds). Did the older "auto play episode" work for you previously
Deihmos 170 Posted May 7, 2015 Posted May 7, 2015 (edited) It will only show up if you didn't already view the next up episode. It worked fine for me. Edited May 7, 2015 by Deihmos 1
mprassel 19 Posted May 7, 2015 Author Posted May 7, 2015 It's definitely enabled and has been in previous versions. Never worked for me.
Iorifly 15 Posted May 8, 2015 Posted May 8, 2015 This not working with me, notification option next chapter of the series. Ja reseted my BD. Anyone know what this is missing? Series: Daredevil.
Angelblue05 4132 Posted May 8, 2015 Posted May 8, 2015 (edited) @@im85288 I added it to the trello board for reviewing I guess? https://trello.com/c/KKHVRFX3/57-netflix-style-next-up-not-working-for-everyone Remember if you are having the issue, you can always vote on the card to prioritize. Edited May 8, 2015 by Angelblue05
im85288 1493 Posted May 8, 2015 Posted May 8, 2015 It's a strange one, it works consistently for me and others. For those who it's not working for does the next episode to play appear in your next up list? Are you sure there is an episode next up to watch in the season that is unwatched? What skins are you using? The screenshot I posted is from my custom version of Arctic 1
Iorifly 15 Posted May 8, 2015 Posted May 8, 2015 (edited) I am using the skin Arctic: Zephyr Yes the next episode is unassisted. Edited May 8, 2015 by Iorifly
im85288 1493 Posted May 8, 2015 Posted May 8, 2015 Are you using my custom version? Can you try again with version 0.1.7 of the addon. Not sure why it works for some and not others. If you check on the web client is the playback status reported, does it get marked as watched and your ongoing episodes widget updated correctly.
Iorifly 15 Posted May 9, 2015 Posted May 9, 2015 I'm using the normal version skin, I'm not using your mod.
badaas 139 Posted May 17, 2015 Posted May 17, 2015 Same issue here, it flicked up once then havent seen it again. I gather this doesnt rely on skin, but is a plugin bundled with the addon?
badaas 139 Posted May 17, 2015 Posted May 17, 2015 Ok here is log, this is interesting: 18:41:57 T:5380 NOTICE: -->Python Interpreter Initialized<-- 18:41:57 T:5824 NOTICE: script.tv.show.next.aired: ### TV Show - Next Aired starting GUI proc (6.0.14) 18:41:57 T:5380 NOTICE: Parameter string: 18:41:57 T:5380 WARNING: Attempt to use invalid handle 25 18:41:58 T:5636 WARNING: Previous line repeats 10 times. kodi.log
im85288 1493 Posted May 17, 2015 Posted May 17, 2015 The log does not help in this case I'm afraid. It does not rely on the skin so should work regardless. Can you do the following: 1. Adjust the time for the notification in the settings to 30 seconds 2. Start a episode where you know there will be a next one in that season to watch. 3. Goto to the web client and assure it is being shown under Active Devices with progress. 4. Fast forward or skip to about a minute from the end. 5. If nothing pops up with approx 30 seconds remaining check the web client again for progress notification. 6. Assuming nothing worked, assure the next episode is appearing in the "ongoing episodes" section If all of this reveals nothing I may need to add some more logging to see what's going on
badaas 139 Posted May 17, 2015 Posted May 17, 2015 (edited) ok bud, 1. was already 30 2. done, started from from home continue watching (netflix style zephyr) with 3 epsidoes left unwatched 3. kodi active with correct episode 4. done 5. client still showed progess of current episode 6. nothing happened, but episode was not marked as watched after finish,so still is unwatched in kodi but marked watched on emby. Edited May 17, 2015 by badaas
im85288 1493 Posted May 17, 2015 Posted May 17, 2015 Thanks, step 6 seems to be an issue then..as immediately after playback has ended it should sync with the Kodi DB to set the show as watched. I'm going to add some further log statements to see if we can get to the bottom of this one..but the first thing that needs to be resolved (which is not linked to this issue) is why your local Kodi DB is not getting notified of the watched status... Have you noticed this behaviour repeatedly? Ie is your ongoing episodes/continue watching section getting out of sync a lot?
mprassel 19 Posted May 17, 2015 Author Posted May 17, 2015 ok bud, 1. was already 30 2. done, started from from home continue watching (netflix style zephyr) with 3 epsidoes left unwatched 3. kodi active with correct episode 4. done 5. client still showed progess of current episode 6. nothing happened, but episode was not marked as watched after finish,so still is unwatched in kodi but marked watched on emby. I'm seeing the exact same behaviour.
im85288 1493 Posted May 17, 2015 Posted May 17, 2015 Could you start a new thread with logs when the episode is not being updated in Kodi. It really should be updating within seconds of you pressing stop or the show ending. This is key to keeping your local Kodi library in sync with Emby so needs to be resolved. Thanks 1
badaas 139 Posted May 17, 2015 Posted May 17, 2015 I watched some episodes last night and they got marked watched in kodi by the time the video finished and returned to the season view.
Angelblue05 4132 Posted May 17, 2015 Posted May 17, 2015 (edited) @@badaasAre you saying it didn't mark as watched in Emby as well.@@mprasselMy guess and the only time i was able to duplicate this is if the scan is running in background and you have a lot of items to update. It will create delays.The best thing to try is to leave your kodi running until you see sync exiting database (or somethig like that) in your log. Then try again to play an item and see if it reports/sync playstate correctly. Let us know in a new thread as im85288 said The exact lines you should see in your log are: Sync DB -> syncDatabase Exiting EMBY Service -> Doing_Db_Sync: syncDatabase (Finished) True I forgot to mention, it's quite possible there's a bigger update than normal since I plugged back in Emby actual playcount information.Sent from my iPhone using Tapatalk Edited May 18, 2015 by Angelblue05
badaas 139 Posted May 17, 2015 Posted May 17, 2015 @@badaas Are you saying it didn't mark as watched in Emby as well. @@mprassel My guess and the only time i was able to duplicate this is if the scan is running in background and you have a lot of items to update. It will create delays. The best thing to try is to leave your kodi running until you see sync exiting database (or somethig like that) in your log. Then try again to play an item and see if it reports/sync playstate correctly. Let us know in a new thread as im85288 said I forgot to mention, it's quite possible there's a bigger update than normal since I plugged back in Emby actual playcount information. Sent from my iPhone using Tapatalk Sorry was marked watched in both normally, but no upnext was shown at all. Will try db reset and start again see if cures.. 1
Angelblue05 4132 Posted May 18, 2015 Posted May 18, 2015 (edited) @@badaas You can also try uninstalling reinstalling the addon to see if it works better. Thanks Edited May 18, 2015 by Angelblue05 1
badaas 139 Posted May 18, 2015 Posted May 18, 2015 Just doing that as i cant update past 1.85 for some reason.. 1
