MndWrp 101 Posted May 7, 2015 Posted May 7, 2015 (edited) Hello! I noticed that some of my movies do not have the play trailer button when entering the detail page, even though they do have trailers listed when i go down where the extras etc are. Movies are organised with a Trailers subfolder and the movies that only have one Trailer.mkv do have the button and the ones that have more than one named trailer 1 trailer 2 etc have the missing button... Im running the android tv app on a nexus player Edited May 7, 2015 by MndWrp
ebr 16335 Posted May 7, 2015 Posted May 7, 2015 That is by design. If there is only one trailer, it just shows a button (because there is no need to take up space with a list with one item in it). If there are multiples, it gives you the row showing them all and you can pick and choose which one(s) to play.
MndWrp 101 Posted May 7, 2015 Author Posted May 7, 2015 Should it not work like other apps where the button is always present and plays the first one in the list alphabetically? The list at the bottom can be absent if there is only one item to play but most people (wife factor in mind) will just not realise that there is a trailer to be played down there... Anyway just my 2 cents on this Great app still!
