DarkKniyt (John) 6 Posted June 4, 2015 Author Posted June 4, 2015 ebr, This still seems to be a problem though since installing the Dev version it is much better. Still getting delays in TV Series. Info: Server - Version 3.0.5625.23705 EMC - Version 3.0.273.0 Chocolate EMC Log attached... MBClassic-462015891aacd36f954e3d9bea00a9b6807f34.log
ebr 16334 Posted June 4, 2015 Posted June 4, 2015 Blackcat - can you find the log that had the problem and tell me exactly which item it was and post the log? DarkKniyt - once again you are getting a time-out on a simple retrieval from the server. I still don't know why.
heula 192 Posted June 4, 2015 Posted June 4, 2015 (edited) Heula - please try the dev version and also please try testing with Chocolate. I think what has happened here is the stability improvements for extenders have forced some things to run not in the background that were before so some themes/situations are having problems with that. Updated Emby Classic to Version 3.0.272.0 and changed from square to Chocolate. All works fast again. Square is also fast again. Edited June 4, 2015 by heula
pgriffith 88 Posted June 7, 2015 Posted June 7, 2015 Just want to throw my hat in the ring here as well Running Dev 273 with chocolate, getting loooong delays on some TV series as well. I can reproduce it reliably on 'The Daily Show with Jon Stewart' It only contains the last season 20 of the show, and it has no theme.mp3, so that rules out that process.
ebr 16334 Posted June 7, 2015 Posted June 7, 2015 Just want to throw my hat in the ring here as well Running Dev 273 with chocolate, getting loooong delays on some TV series as well. I can reproduce it reliably on 'The Daily Show with Jon Stewart' It only contains the last season 20 of the show, and it has no theme.mp3, so that rules out that process. Log please.
pgriffith 88 Posted June 7, 2015 Posted June 7, 2015 (edited) Log please. Log attached. Deleted all existing logs Started Emby WMC, waited for the Emby is up to date message Went into TV Went to Daily Show and selected it Took about 30 secs or so Went to Season 20 Played 1st episode for a few seconds Backed out and exited to Media Center If I try to use the back key or Green MCE button while its taking its time, I will always get the Program Not Responding popping up Hope this helps MBClassic-862015a0c2ca648bad4d898b3bbd3d261f9cdb.log Edited June 7, 2015 by pgriffith
ebr 16334 Posted June 8, 2015 Posted June 8, 2015 Thanks. I'm not sure it is going to make any difference but please update to 274 and try your test with that show again.
pgriffith 88 Posted June 8, 2015 Posted June 8, 2015 (edited) Thanks. I'm not sure it is going to make any difference but please update to 274 and try your test with that show again. Seems to be no difference, still taking around 30 seconds or so to get in, and I checked half a dozen other shows with the same results. I chose a mixture of shows that are either: 1. Completely finished and complete 2. Ongoing with some completely up to date and others missing past episodes or entire seasons 3. Completely finished missing past content All reacted the same Ones with theme.mp3 files play the theme INSTANTLY, then 30 seconds ish later it enters the show. Some series go in instantly as is the expected behavior. Occasionally it will just crash back to Media Center on trying to enter a show VERY inconsistent unfortunately. Let me know if you want me to do any specific testing, dummy up a series folder etc etc Cheers Edited June 8, 2015 by pgriffith
ebr 16334 Posted June 8, 2015 Posted June 8, 2015 Okay, try disabling the special TV view in Chocolate settings...
pgriffith 88 Posted June 8, 2015 Posted June 8, 2015 (edited) Already disabled, hate that view Edit... Just to be clear, you mean the Use Custom View for Series option yes ? Edited June 8, 2015 by pgriffith
ebr 16334 Posted June 8, 2015 Posted June 8, 2015 Yes, that's what I meant. I wonder if that is a common factor... (having that disabled). Try 275.
MrWebsmith 598 Posted June 8, 2015 Posted June 8, 2015 (edited) eric... im remoted into my server.. wanted to quick test on 275.. try this on your setup.. goto tv serries (im coming from mb plus if it matters).. then go into a series.. 1st time is super fast.. like maybe not even a sec and im seeing the seasons.. then just hit back immediately.. then dont move.. choose the same series/show and go right back into it.. DELAY... at least here same kind of thing happens if you change shows but im just trying the simplest steps to repro for you.. im getting logs nows, stand by https://www.dropbox.com/s/y9o0e07zvfj4gfa/MBClassic-862015475071f4a6254978b833519d222c6165.log?dl=0 3rd rock from the sun.. entered it a total of 3 times.. 1st time was fast.. 2nd and 3rd had a delay Edited June 8, 2015 by MrWebsmith
pgriffith 88 Posted June 8, 2015 Posted June 8, 2015 I have 3 machines here all running 273/274 now. 2 are in use machines (lounge & bedroom) the 3rd is my main work/gaming machine, this has the special view still enabled (I keep this with stock settings, no changes at all) and the same delay exists Off to try 275
ebr 16334 Posted June 8, 2015 Posted June 8, 2015 Web - I cannot reproduce a delay with your steps (or any others) so I have been working blind trying to figure out what the common ground is. I have tried it on the largest series I have (ER - 15 seasons) but I still get in in under a second.
pgriffith 88 Posted June 8, 2015 Posted June 8, 2015 (edited) Same with 275 Very inconsistent again... Started at the start of my shows, first 4 went in fine, then 5 & 6 had the delay, next few were fine, then some more with delay. Went BACK to the start and then 1 & 3 which were fine the first time around now had the delay again. Edited June 8, 2015 by pgriffith
ebr 16334 Posted June 8, 2015 Posted June 8, 2015 Web - do you have the server log that matches that last MBC log? Also, can you reconcile the times between the two machines? Thx.
MrWebsmith 598 Posted June 8, 2015 Posted June 8, 2015 (edited) emby server (dev as of this morn) and htpc with just updated 275 both currently show (in windows 10:56am) https://www.dropbox.com/s/v7g0kn2tlhwmtoc/server-63569352156.txt?dl=0 ^server log that should cover the time i was testing with 3rd rock (not sure what else reconcile the time's between them could mean)... .. i think? i have your user on my server.. i can give you the ddns via PM if wanted Edited June 8, 2015 by MrWebsmith
ebr 16334 Posted June 8, 2015 Posted June 8, 2015 That's what I meant by reconcile but I need it to the second if you can get it...
pgriffith 88 Posted June 8, 2015 Posted June 8, 2015 Started from beginning of TV library, and log attached for the following. Shit my Dad Says - Fine 2 Broke Girls - Fine 12 Monkeys - Fine 24 - Fine 30 Rock - Fine The 100 - Delay 666 Park Avenue - Fine The 4400 - Fine Adventure Time - Fine Alcatraz - Fine Alice - Fine Allegiance - Fine Almost Human - Fine American Dad - HUGE delay, didn't play theme till it entered show American Horror Story - Played theme immediately, then delay The Americans - Delay before playing theme, then another delay to enter show Archer - Played theme immediately then delay to enter show MBClassic-962015c5a27b1c936d4d4ea4fa500f823ef487.log
MrWebsmith 598 Posted June 8, 2015 Posted June 8, 2015 (edited) server is +14s from htpc (as in 14s ahead) Edited June 8, 2015 by MrWebsmith
pgriffith 88 Posted June 8, 2015 Posted June 8, 2015 I synched my server and client exactly to the second and repeated the above. Got through to American Dad before any delay, the 3 after were fine this time, but several more following those had the delay. A couple played the theme and then just crashed back to Media Center (with the associated dialog box pop up)
ebr 16334 Posted June 8, 2015 Posted June 8, 2015 server is +14s from htpc (as in 14s ahead) Interesting because the log timings appear to be a few minutes apart. In any case, the time-out does not appear to be related to the server response which is what I was suspecting. I've tried something as a test in 276. See what happens.
MrWebsmith 598 Posted June 8, 2015 Posted June 8, 2015 (edited) upped to 276 3rd rock from the sun... for 3 total "entry trips"..same results.. 1 is fast/immediate.. 2 and 3 were delayed then "24".. again 1st time into this show no delay.. 2nd time delay...3rd delay mbc log for 276: https://www.dropbox.com/s/q8ufxabcufd2rec/MBClassic-862015e820d908b41d491285266090419d0e45.log?dl=0 emby server log updated: https://www.dropbox.com/s/v7g0kn2tlhwmtoc/server-63569352156.txt?dl=0 windows time capture: https://www.dropbox.com/s/877opdb8fy0dy0y/clocks.jpg?dl=0 Edited June 8, 2015 by MrWebsmith
