ebr 16334 Posted June 9, 2015 Posted June 9, 2015 If an item doesn't have at least a minimum amount of metadata information, it will direct play instead of showing a detail page with basically no information in it. This can be overridden with the "Always show details" option under General Behavior.
olskool 0 Posted June 9, 2015 Posted June 9, 2015 The shows have all the metadata information and this used to work, but the Always show details fixed the problem. Thanx for all you work
ebr 16334 Posted June 9, 2015 Posted June 9, 2015 Yeah, that appears to be a bug introduced by some of the stability changes in 266. I've fixed it for the next release.
spaid 2 Posted June 10, 2015 Posted June 10, 2015 Just wanted to add I'm also noticing a huge increase in speed after this update, so thanks! 1
Overseer 66 Posted June 10, 2015 Posted June 10, 2015 Thank you for the hard work you've put in hunting down a bug like that. Well worth an extra donation. Wish I could do more. They can take my EMC when they pry my remote from my cold, dead fingers. 2
dansblackcat 37 Posted June 11, 2015 Posted June 11, 2015 Fantastic effort. Runs perfectly. Faster than ever. 2
derekd 3 Posted June 11, 2015 Posted June 11, 2015 Been following this topic for a while now. Around March/April I thought my hardware was wonky... I reinstalled 3 or 4 times, tried on a bunch of different systems, borrowed a friend's switch, and sacrificed a few goats. So glad to see v282 fix it! Browsing is super quick. Thanks to everyone in this thread for the development work and massive amount of testing! As other's have mentioned, worth the extra donation 3
genro 4 Posted June 11, 2015 Posted June 11, 2015 Wanted to chime in to thank EBR for all the work. I originally reported this bug and I can understand the challenges to identify and resolve it. The current version is easily the fastest and smoothest I've seen. Thank you Ebr and the rest of the folks that contribute to Emby. 3
Scoobz 2 Posted June 14, 2015 Posted June 14, 2015 Looks good on my install also. I would also like to thank the devs for fixing this. The support for this product is outstanding. Thank you.
nickyrat 2 Posted June 15, 2015 Posted June 15, 2015 I was having these same issues with delays and I just wanted to chime in and say think you for all of your hard work! I kept forgetting to look for help because it only happened late at night after work when I was trying to watch a show. But I've got things updated, and now things are good to go! So, nothing informative here...just wanted to say thank you!
heula 192 Posted June 17, 2015 Posted June 17, 2015 For me also the issue is solved. Deleting items has been faster in present time. It takes about 8 seconds after deleting an episode before Emby returns back to the episode screen. If this can be faster again it would be fantastic. Emby log Thanks.
ebr 16334 Posted June 17, 2015 Posted June 17, 2015 We need to wait for the deletion to actually occur on the server.
heula 192 Posted June 18, 2015 Posted June 18, 2015 We need to wait for the deletion to actually occur on the server. Ok, then the server needs to speed up this process?
DarkKniyt (John) 6 Posted June 20, 2015 Author Posted June 20, 2015 Been away for a bit but wanted to add a few more comments. EMBY Team - Thank You! EMBY Classic is working great again. As mentioned above, smoother, faster, better. Also to note, I have tested using the Subdued Theme - No Issues! So happy to have my EMBY back and my favorite theme too. Again, thank you for all the hard work and the quick turn-around. You guys do a fantastic job!!
DarkKniyt (John) 6 Posted June 20, 2015 Author Posted June 20, 2015 Oh, one more comment here. I'm running EMBY Classic using the Subdued theme with Active Backgrounds and am having no delays at all! Thanks Again!
