DarkKniyt (John) 6 Posted May 6, 2015 Posted May 6, 2015 I am having issues in WMC with TV Collections. Pertinent information: Server Version 3.0.5597.1 MB Classic/WMC Version 3.0.266.0 TV Collection: BATMAN The Batman multiple Seasons Batman Beyond multiple Seasons Batman Animated multiple Seasons The New Batman multiple Seasons Beware The Batman multiple Seasons I Select the top level of BATMAN I Select BATMAN BEYOND It takes over 30 seconds for the Batman Beyond collection to open. I am having this same issue with other TV Shows that do not have multiple TV Shows/Collections like Battlestar Galactica. I have cleaned the cache, restarted the Emby Server, the PC Server. Nothing is making any difference. I have 3 Windows PCs using MB Classic and have tested each one and have the same issue on all three. I've attached the log file. Any help would be appreciated. Thanks! Log.txt
ebr 16334 Posted May 7, 2015 Posted May 7, 2015 Try turning off "Automatically select first unwatched item".
DarkKniyt (John) 6 Posted May 7, 2015 Author Posted May 7, 2015 ebr, are you referring to "Default To First Unplayed Item" under the "General" tab of the MB-Classic Config-Menu? If you are, it is already Unchecked/Turned-Off. Any other thoughts?
ebr 16334 Posted May 7, 2015 Posted May 7, 2015 Okay, then try turning off showing unwatched counts on folders.
AdrianW 1058 Posted May 7, 2015 Posted May 7, 2015 I have one TV collection containing over 50 different series. It opens within a couple of seconds and I have both "show unwatched count" and "default to first unplayed item" set on. This is on an i5 NUC. I'm still experiencing the problem with unwatched count going negative on the collection folder - as described in this thread from last year.
ebr 16334 Posted May 7, 2015 Posted May 7, 2015 I think his issue stems from the fact that he has nested his series under a sub-folder. In situations I can predict, I've tried to mitigate the effect of some of those options.
DarkKniyt (John) 6 Posted May 7, 2015 Author Posted May 7, 2015 OK, what seems to be happening now is when I select the TV Collection (Batman TV Shows in this case), I still get a long delay. It will finally open though. I then select one of the Series in the collection (Batman Beyond), same delay happens. It will finally open to the Seasons. Weird thing here is that there are 3 Seasons in Batman Beyond and when I scroll the 3 seasons not all are populated with the episodes. Meaning, Season 1 when opened shows the 13 episodes but when Season 2 is opened there is nothing in it. Then if I back out of the Series and come back into, there is no delay and all the season are populated with the episodes. I tried this on four separate TV Collections and it behaves the exact same way. I also tried this on Battlestar which contains just the series (no collection), I get the long (30+ seconds) delay before it opens. same issue with episodes. I back out of it. Select the Series again, no delay and all episodes are present. ???? I'm confused!!!
DarkKniyt (John) 6 Posted May 7, 2015 Author Posted May 7, 2015 I think his issue stems from the fact that he has nested his series under a sub-folder. In situations I can predict, I've tried to mitigate the effect of some of those options. Not true for Battlestar Galactica.
DarkKniyt (John) 6 Posted May 7, 2015 Author Posted May 7, 2015 I think his issue stems from the fact that he has nested his series under a sub-folder. In situations I can predict, I've tried to mitigate the effect of some of those options. ebr, aslo happening to other TV Series, Bates Motel is one I just tried, took over 30 seconds to open and season 3 has no episodes showing. I backed out and back in and now all episodes are there.
solidus28 12 Posted May 7, 2015 Posted May 7, 2015 I can't help but notice this sounds very similar to what I reported in http://emby.media/community/index.php?/topic/20808-refresh-emby-classic-image-cache/ It was proposed I may be having a hardware problem, but everything seems to be running healthy and I don't have delays when accessing files/data off my server from other apps/services. Not saying I couldn't be having a separate issue with similar symptoms, but it seems there are getting to be too many reports for it to be a coincidence. There must be something we all have in common.
DarkKniyt (John) 6 Posted May 7, 2015 Author Posted May 7, 2015 solidus28, Same Thing Here! No problems when accessing my media from my tablets, cells or the web interface in general. Just the Classic/WMC. This is really killing me. I love this app but in the past couple of months I have run into numerous issues. I've even completely removed EMBY Server and Classic and reinstalled - no change in issues. As I stated earlier, I have numerous PCs running the Classic/WMC app, all have the same problems. ebr, I hope this doesn't sound like complaining, we all appreciate the work you put in and the quick responses to our issues!
ebr 16334 Posted May 7, 2015 Posted May 7, 2015 You posted a server log. I really need to see an MBC log.
DarkKniyt (John) 6 Posted May 7, 2015 Author Posted May 7, 2015 solidus28, can you tell which Theme you are using?
solidus28 12 Posted May 7, 2015 Posted May 7, 2015 Been on Chocolate for years (Black specifically if that matters).
DarkKniyt (John) 6 Posted May 7, 2015 Author Posted May 7, 2015 OK, I'm using subdued. I just finished testing using the Classic-Theme. Same issues.
DarkKniyt (John) 6 Posted May 7, 2015 Author Posted May 7, 2015 Yeah, I'll have it posted in a couple of mins.
DarkKniyt (John) 6 Posted May 7, 2015 Author Posted May 7, 2015 OK, here's the MBC Log.I restarted MBC, opened Battlestar, Seasons 1,2 and 3 had episodes, season 4 did not.I backed out, went back in, Season 4 has all episodes.Selected Batman Collection, Selected The Batman Series, Long Delay opening it. Season 1 & 2 had episodes, 3,4 & 5 no episodes.Backed out of Series, Back into Series, Long Delay, Season 1,2,3 & 4 had episodes, 5 no episodes.Backed out went back in, all season have episodes.Backed out went into Batman Beyond Series, no delay, all 3 seasons no episodes,When backing out, Long Delay. Back in, all episodes. To Note: I turned off all options in MBC. No backgrounds, No Counts or indexing, etc... Only thing on is Cover-Art.------------------------------- 2015-05-07 09:36:43.3240,Debug,,Attempting to wake server at address 2C-27-D7-28-08-77,1,Application2015-05-07 09:36:43.3300,Debug,,Wake command sent,1,Application2015-05-07 09:36:43.3450,Debug,,=========System looking for assembly: System.Data.SQLite,, Version=1.0.61.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139,1,Application2015-05-07 09:36:43.3460,Info,,System.Data.SQLite,, Version=1.0.61.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139 is being resolved to System.Data.SQLite,, Version=1.0.88.0,, Culture=neutral,, PublicKeyToken=db937bc2d44ff139,1,Application2015-05-07 09:36:43.3540,Info,,==========Using new SQL Repo========,1,Application2015-05-07 09:36:43.5800,Info,,Playstate initialization took 0.01 seconds.,1,Application2015-05-07 09:36:43.6180,Info,,Successfully loaded fastload data for : C:\ProgramData\MediaBrowser-Classic\Cache\playstate MediaBrowser.Library.Entities.PlaybackStatus,12,Worker thread for FastLoadLoader2015-05-07 09:36:43.6370,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\strings-en.xml,1,Application2015-05-07 09:36:43.6470,Info,,Total Kernel Init took 0.33 seconds.,1,Application2015-05-07 09:36:43.7080,Info,,Finished validating : C:\ProgramData\MediaBrowser-Classic\Cache\playstate MediaBrowser.Library.Entities.PlaybackStatus,12,Worker thread for FastLoadLoader2015-05-07 09:36:43.7080,Info,,Dictionary loading and validation took 0.13 seconds.,12,Worker thread for FastLoadLoader2015-05-07 09:36:44.0110,Info,,Information DisplayText: Welcome to Media Browser,1,Application2015-05-07 09:36:44.0360,Info,,Media Browser (version 3.0.266.0 ) Starting up.,1,Application2015-05-07 09:36:44.0360,Info,,Startup parameters: ,1,Application2015-05-07 09:36:44.0510,Debug,,Having to get media experience by reflection due to bug in Windows 7,1,Application2015-05-07 09:36:44.0510,Debug,,GetMediaExperienceUsingReflection was unsuccessful,1,Application2015-05-07 09:36:44.1810,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/System/Info/Public?format=Json,1,Application2015-05-07 09:36:44.4830,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/Public?isDisabled=False&format=Json,1,Application2015-05-07 09:36:44.5960,Info,,Connected to server HomeServer-PC at http://192.168.10.5:8096,1,Application2015-05-07 09:36:44.5960,Info,,Server version: 3.0.5597.1,1,Application2015-05-07 09:36:44.6010,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/MetroLoginPage,1,Application2015-05-07 09:36:44.6510,Info,,Application Init took 1.00 seconds.,1,Application2015-05-07 09:36:47.8700,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/ParentalPINEntry,1,Application2015-05-07 09:36:48.0150,Info,,Information DisplayText: Welcome to Media Browser,1,Application2015-05-07 09:36:53.1900,Debug,,Sending Http Post to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Authenticate?format=Json,16,Worker thread for Common 2015-05-07 09:36:53.2530,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/System/Configuration?format=Json,16,Worker thread for Common 2015-05-07 09:36:53.3420,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/System/Info?format=Json,16,Worker thread for Common 2015-05-07 09:36:53.4070,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/Root?format=Json,16,Worker thread for Common 2015-05-07 09:36:53.6420,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Plugins?format=Json,16,Worker thread for Common 2015-05-07 09:36:53.6520,Info,,*** Theme in use is: Subdued,16,Worker thread for Common2015-05-07 09:36:53.6670,Debug,,=========System looking for assembly: MediaBrowser,, Version=3.0.260.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64,1,Application2015-05-07 09:36:53.6670,Info,,Plug-in reference to MediaBrowser,, Version=3.0.260.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64 is being linked to version 3.0.266.0,1,Application2015-05-07 09:36:53.6670,Debug,,Added Plugin assembly: Chocolate,, Version=3.0.8.2,, Culture=neutral,, PublicKeyToken=cbacf2b624ff6ad4,1,Application2015-05-07 09:36:53.6720,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Packages?packagetype=UserInstalled&targetsystems=MBClassic&format=Json,24,Worker thread for Common 2015-05-07 09:36:53.6720,Debug,,=========System looking for assembly: MediaBrowser,, Version=3.0.243.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64,1,Application2015-05-07 09:36:53.6720,Info,,Plug-in reference to MediaBrowser,, Version=3.0.243.0,, Culture=neutral,, PublicKeyToken=59fc04479785fd64 is being linked to version 3.0.266.0,1,Application2015-05-07 09:36:53.6920,Info,,Subdued - Creating Theme,1,Application2015-05-07 09:36:53.7070,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\The Original.mcml,1,Application2015-05-07 09:36:53.7070,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\The Original.mcml,1,Application2015-05-07 09:36:53.7070,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\White Shadow.mcml,1,Application2015-05-07 09:36:53.7070,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\White Shadow.mcml,1,Application2015-05-07 09:36:53.7080,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 1.mcml,1,Application2015-05-07 09:36:53.7080,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 1.mcml,1,Application2015-05-07 09:36:53.7080,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 2.mcml,1,Application2015-05-07 09:36:53.7080,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 2.mcml,1,Application2015-05-07 09:36:53.7080,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Blue Note.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Blue Note.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Cold as Ice.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Cold as Ice.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Neon.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Neon.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Redrum.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Redrum.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Red.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Red.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Blue.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Blue.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Green.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Green.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Orange.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Orange.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Verifying bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Yellow.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Skipping bundled style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Yellow.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Validating installed styles,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Blue Note.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Cold as Ice.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Neon.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Redrum.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 1.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Spy vs. Spy 2.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Blue.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Green.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Orange.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Red.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Yellow.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\The Original.mcml,1,Application2015-05-07 09:36:53.7090,Info,,Subdued - Checking installed style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\White Shadow.mcml,1,Application2015-05-07 09:36:53.7190,Info,,Subdued - Theme Creation took 0.03 seconds.,1,Application2015-05-07 09:36:53.7190,Debug,,Added Plugin assembly: Subdued,, Version=3.0.1.17,, Culture=neutral,, PublicKeyToken=cbacf2b624ff6ad4,1,Application2015-05-07 09:36:53.7440,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\Chocolate-strings-en.xml,1,Application2015-05-07 09:36:53.7590,Info,,Chocolate Theme (version 3.0.8.2) Loaded.,1,Application2015-05-07 09:36:53.7590,Info,,Subdued - Initializing Theme,1,Application2015-05-07 09:36:53.7590,Info,,Subdued - Checking active style: C:\ProgramData\MediaBrowser-Classic\Subdued_Styles.mcml,1,Application2015-05-07 09:36:53.7640,Info,,Subdued - Setting active style: C:\ProgramData\MediaBrowser-Classic\Plugins\Configurations\SubduedStyles\Subtle Red.mcml,1,Application2015-05-07 09:36:53.7790,Info,,Using String Data from C:\ProgramData\MediaBrowser-Classic\Localization\Subdued-strings-en.xml,1,Application2015-05-07 09:36:53.7840,Info,,Subdued - Theme Initialization took 0.02 seconds.,1,Application2015-05-07 09:36:53.7840,Info,,Subdued - Version 3.0.1.17 ready,1,Application2015-05-07 09:36:53.7840,Info,,Plugin Loading and Init took 0.13 seconds.,1,Application2015-05-07 09:36:53.8040,Debug,,=========System looking for assembly: WebSocket4Net,, Version=0.12.0.0,, Culture=neutral,, PublicKeyToken=eb4e154b696bf72a,1,Application2015-05-07 09:36:53.8040,Info,,Resolving WebSocket4Net,, Version=0.12.0.0,, Culture=neutral,, PublicKeyToken=eb4e154b696bf72a to C:\ProgramData\MediaBrowser-Classic\websocket4net.dll,1,Application2015-05-07 09:36:53.8340,Info,,Connected to ws://192.168.10.5:8096/mediabrowser,1,Application2015-05-07 09:36:53.8340,Debug,,Sending Http Post to http://192.168.10.5:8096/mediabrowser/Sessions/Capabilities?format=Json,1,Application2015-05-07 09:36:53.8940,Debug,,Navigating to Media Folders item type MediaBrowser.Library.FolderModel,1,Application2015-05-07 09:36:53.8950,Debug,,Loading display prefs for C:\Users\HomeServer\AppData\Roaming\MediaBrowser-Server\root\default,1,Application2015-05-07 09:36:53.8990,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/DisplayPreferences/b21ccc945ed35ac08c3b35d5de9e71f3?userId=87d2924f1a0a122212d5b98e0f6d9d3b&client=MBC&format=Json,1,Application2015-05-07 09:36:53.9730,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items?ParentId=e9d5075a555c1cbc394eec4cef295274&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&years=&format=Json,29,Worker thread for Common 2015-05-07 09:36:54.0710,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/Page,1,Application2015-05-07 09:36:54.6300,Debug,,=========System looking for assembly: Subdued,1,Application2015-05-07 09:36:54.6300,Info,,Resolving plug-in reference to: Subdued,1,Application2015-05-07 09:36:55.5120,Debug,,Loading display prefs for C:\Users\HomeServer\AppData\Roaming\MediaBrowser-Server\root\default,1,Application2015-05-07 09:36:55.5720,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Localization/ParentalRatings?format=Json,1,Application2015-05-07 09:36:55.8770,Debug,,Loading display prefs for C:\Users\HomeServer\AppData\Roaming\MediaBrowser-Server\root\default\Movies,1,Application2015-05-07 09:36:55.8770,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/DisplayPreferences/c8ca023cdbb96c78e4de5fcb477df512?userId=87d2924f1a0a122212d5b98e0f6d9d3b&client=MBC&format=Json,1,Application2015-05-07 09:36:55.9220,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items?ParentId=c8ca023cdbb96c78e4de5fcb477df512&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&years=&format=Json,24,Worker thread for Common 2015-05-07 09:36:57.5610,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f1a0a122212d5b98e0f6d9d3b/Items?ParentId=c8ca023cdbb96c78e4de5fcb477df512&limit=20&sortBy=DateCreated&sortOrder=Descending&fields=Overview,,IndexOptions,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&Filters=IsUnplayed&ImageTypes=&recursive=True&genres=&Ids=&studioIds=&ExcludeItemTypes=series,,season,,musicalbum,,musicartist,,folder,,boxset&ExcludeLocationTypes=Virtual&personIds=&personTypes=&years=&format=Json,30,Worker thread for Common 2015-05-07 09:36:57.6130,Info,,RAL child retrieval for Movies option unwatched took 0.08 seconds.,30,Worker thread for Common2015-05-07 09:36:57.6130,Debug,,unwatched list for Movies loaded with 20 items.,30,Worker thread for Common2015-05-07 09:36:57.6180,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/DisplayPreferences/cefb66f9-4fb6-ff5e-848c-dd0579ac6364?userId=87d2924f1a0a122212d5b98e0f6d9d3b&client=MBC&format=Json,30,Worker thread for Common 2015-05-07 09:37:00.1050,Debug,,Loading display prefs for C:\Users\HomeServer\AppData\Roaming\MediaBrowser-Server\root\default\TV Shows,1,Application2015-05-07 09:37:00.1050,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/DisplayPreferences/d4f1aeb3b8343a7c04f02bd596d038f3?userId=87d2924f1a0a122212d5b98e0f6d9d3b&client=MBC&format=Json,1,Application2015-05-07 09:37:00.1150,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items?ParentId=d4f1aeb3b8343a7c04f02bd596d038f3&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&years=&format=Json,31,Worker thread for Common 2015-05-07 09:37:00.2220,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f1a0a122212d5b98e0f6d9d3b/Items?ParentId=d4f1aeb3b8343a7c04f02bd596d038f3&limit=50&sortBy=DateCreated&sortOrder=Descending&fields=Overview,,IndexOptions,,SortName,,DisplayMediaType,,Path,,DisplayPreferencesId,,DateCreated,,Taglines,,Metascore,,MediaStreams,,ParentId,,DateLastMediaAdded,,MediaSources,,SpecialEpisodeNumbers&Filters=IsUnplayed&ImageTypes=&recursive=True&genres=&Ids=&studioIds=&ExcludeItemTypes=series,,season,,musicalbum,,musicartist,,folder,,boxset&ExcludeLocationTypes=Virtual&personIds=&personTypes=&years=&format=Json,31,Worker thread for Common 2015-05-07 09:37:00.3420,Info,,RAL child retrieval for TV Shows option unwatched took 0.12 seconds.,31,Worker thread for Common2015-05-07 09:37:00.3420,Debug,,unwatched list for TV Shows loaded with 50 items.,31,Worker thread for Common2015-05-07 09:37:00.3420,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/9f519b27-b1c3-a104-ea4b-1ab38caba0b7?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.3620,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/9f519b27-b1c3-a104-ea4b-1ab38caba0b7?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.3720,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/8443a76d-8088-0850-c5ae-11b218870b9b?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.3820,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/8443a76d-8088-0850-c5ae-11b218870b9b?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.3870,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/eb419622-ab48-8295-0907-61f0b509feb0?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.3920,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/eb419622-ab48-8295-0907-61f0b509feb0?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.3970,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/c796dbe2-bbce-1042-278b-395bcdebc8c2?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.4020,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/c796dbe2-bbce-1042-278b-395bcdebc8c2?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.4070,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/9069dbeb-7f5c-7129-d115-9b6b734bebcf?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.4120,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/9069dbeb-7f5c-7129-d115-9b6b734bebcf?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.4170,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/151db7a6-e451-4a20-dfe8-0dfe91d980ac?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.4220,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/151db7a6-e451-4a20-dfe8-0dfe91d980ac?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.4270,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/5861b0d7-a55c-04f2-9de3-d029629f2bdc?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.4320,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/5861b0d7-a55c-04f2-9de3-d029629f2bdc?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.4420,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/e07f9931-9e50-80c3-5a98-7f2f01a464f3?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.4420,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/e07f9931-9e50-80c3-5a98-7f2f01a464f3?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.4470,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/b53e871f-66c0-890c-1c77-a1c168cdbb41?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.4520,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/b53e871f-66c0-890c-1c77-a1c168cdbb41?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.4620,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/4a383259-274b-1fd9-253c-13c31ba53514?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.4620,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/4a383259-274b-1fd9-253c-13c31ba53514?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.4670,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/1e2d403f-0bbb-09ed-69c5-7eb64f7d6982?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.4720,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/1e2d403f-0bbb-09ed-69c5-7eb64f7d6982?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.4770,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/602dfa6c-b2bf-745c-b53e-f050ff9d67da?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.4820,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/602dfa6c-b2bf-745c-b53e-f050ff9d67da?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.4820,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/a2fdd37a-fcf8-a5fa-201d-b5db69dae047?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.4870,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/a2fdd37a-fcf8-a5fa-201d-b5db69dae047?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.4920,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/706e3682-5882-a6af-5c61-a0ad243a2ac2?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.4970,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/706e3682-5882-a6af-5c61-a0ad243a2ac2?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.5020,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/6b37427f-540d-95b1-519c-1f8289944583?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.5070,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/6b37427f-540d-95b1-519c-1f8289944583?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.5120,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/30115ed7-552d-4641-2774-e1f6d29aecf1?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.5120,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/30115ed7-552d-4641-2774-e1f6d29aecf1?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.5170,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/356bf59d-3933-5a5b-1dbd-33388641d96b?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.5220,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/356bf59d-3933-5a5b-1dbd-33388641d96b?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.5270,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/8bec4eab-61dc-9fce-1426-6e7cf5517ed4?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.5270,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/8bec4eab-61dc-9fce-1426-6e7cf5517ed4?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.5320,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/e407a2f2-7bb2-be84-a00c-d3bf46fe29e6?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.5420,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/c24c7f56-036a-e905-94b1-f9661f031cdd?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.5470,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/6c41703b-6c0f-6223-7451-58319aed9441?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.5520,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/6c41703b-6c0f-6223-7451-58319aed9441?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.5620,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/5cd4f87d-8cdd-63ba-1eff-9d208339ef07?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.5670,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/5cd4f87d-8cdd-63ba-1eff-9d208339ef07?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.5720,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/f71c677c-3529-08d4-0dec-ff3630dc8963?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.5770,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/5f974892-aea5-469c-cd73-be75060b6289?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.5820,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/aea488cc-3b78-bc47-6386-429e6f54fc8c?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.5870,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/fe4f02a8-7e01-c97e-a351-f69c0e6defdf?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.5870,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/7fb1dacc-6e07-93b6-6296-ef62cfb0c5fa?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.5920,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/dd5e22be-8845-ac22-40b6-75be6fca8a43?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.5970,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/dc0ed2bb-4357-ebc6-6c71-ca549ad9b89b?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.6020,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/dc0ed2bb-4357-ebc6-6c71-ca549ad9b89b?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.6070,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/fda64b54-e52c-f791-926e-d64acc341126?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.6070,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/fda64b54-e52c-f791-926e-d64acc341126?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.6120,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/a4e0e720-cc4f-8e98-8cd4-8e64e17a5126?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.6170,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/f6fb5c1c-64fe-f198-ac05-9c6b7afa1491?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.6170,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/d9192569-9a32-00f3-b192-1f7b2f927bd7?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.6220,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/e17d5108-4735-b917-d7ef-7a30e6fe1d8c?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.6270,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/972488f0-50e8-9b89-8a12-ac297be13045?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.6370,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/11cb93c3-fc13-f621-854b-e6458870e772?format=Json,31,Worker thread for Common 2015-05-07 09:37:00.7040,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/DisplayPreferences/d7e9b60c-5ffb-ea82-4bb5-bf383b90dd4b?userId=87d2924f1a0a122212d5b98e0f6d9d3b&client=MBC&format=Json,31,Worker thread for Common 2015-05-07 09:37:00.7340,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/DisplayPreferences/d7e9b60c-5ffb-ea82-4bb5-bf383b90dd4b?userId=87d2924f1a0a122212d5b98e0f6d9d3b&client=MBC&format=Json,30,Worker thread for Common 2015-05-07 09:37:00.7340,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/DisplayPreferences/d7e9b60c-5ffb-ea82-4bb5-bf383b90dd4b?userId=87d2924f1a0a122212d5b98e0f6d9d3b&client=MBC&format=Json,25,Worker thread for Common 2015-05-07 09:37:03.6930,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Plugins/RegistrationRecords/mbsupporter?Mb2Equivalent=mbsupporter&format=Json,24,Worker thread for Common 2015-05-07 09:37:03.8230,Debug,,Navigating to TV Shows item type MediaBrowser.Library.FolderModel,1,Application2015-05-07 09:37:03.8280,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/Page,1,Application2015-05-07 09:37:03.8380,Debug,,Loading display prefs for C:\Users\HomeServer\AppData\Roaming\MediaBrowser-Server\root\default\TV Shows,1,Application2015-05-07 09:37:03.8580,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Localization/ParentalRatings?format=Json,1,Application2015-05-07 09:37:03.9350,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Packages/MBClassic?format=Json,25,Worker thread for Common 2015-05-07 09:37:04.2020,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items?ParentId=7d0fdf62ee408f08b39f1a896d14067c&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&years=&format=Json,32, 2015-05-07 09:37:04.2070,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/DisplayPreferences/f63033ff6886ecc7083a696cbeced1b0?userId=87d2924f1a0a122212d5b98e0f6d9d3b&client=MBC&format=Json,32, 2015-05-07 09:37:04.2110,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items?ParentId=03f04a06fde12c45dbbd0015709e2760&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&years=&format=Json,32, 2015-05-07 09:37:04.2350,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/DisplayPreferences/dfd065f5787fb957a750d76dcf835aad?userId=87d2924f1a0a122212d5b98e0f6d9d3b&client=MBC&format=Json,32, 2015-05-07 09:37:04.2390,Info,,Subdued - GetRecursiveChildCountString for '12 Monkeys' took 0.04 seconds.,32,2015-05-07 09:37:04.8140,Info,,==== MB Classic is up to date.,25,Worker thread for Common2015-05-07 09:37:06.2240,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items?ParentId=95d02bfe50cb4d469b589550799c7c47&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&years=&format=Json,32, 2015-05-07 09:37:06.2340,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items?ParentId=cd450c4cd1fe4d0a1a7e981482af779c&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&years=&format=Json,32, 2015-05-07 09:37:06.2440,Info,,Subdued - GetRecursiveChildCountString for 'The Andromeda Strain (2008)' took 0.02 seconds.,32,2015-05-07 09:37:07.2780,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items?ParentId=a2fdd37afcf8a5fa201db5db69dae047&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&years=&format=Json,32, 2015-05-07 09:37:07.2830,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items?ParentId=706e36825882a6af5c61a0ad243a2ac2&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&years=&format=Json,32, 2015-05-07 09:37:07.3080,Info,,Subdued - GetRecursiveChildCountString for 'Backstrom' took 0.03 seconds.,32,2015-05-07 09:37:08.0200,Info,,Information DisplayText: MB Classic is up to date,1,Application2015-05-07 09:37:08.5770,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items?ParentId=dc0ed2bb4357ebc66c71ca549ad9b89b&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&years=&format=Json,32, 2015-05-07 09:37:08.5870,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items?ParentId=fda64b54e52cf791926ed64acc341126&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&years=&format=Json,32, 2015-05-07 09:37:08.6280,Info,,Subdued - GetRecursiveChildCountString for 'Battlestar Galactica (1978)' took 0.05 seconds.,32,2015-05-07 09:37:10.2460,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items?ParentId=873c1bbb994bfaa31d231b535426de1a&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&years=&format=Json,32, 2015-05-07 09:37:10.2610,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items?ParentId=dee6f5b00bb3cfb3b07811f90b447467&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&years=&format=Json,32, 2015-05-07 09:37:10.2950,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items?ParentId=3fa9fc893fb2347bd61581c95375cde3&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&years=&format=Json,32, 2015-05-07 09:37:10.3330,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items?ParentId=ba0f4b3cca9315c431d32a6a7cb0a8c6&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&years=&format=Json,32, 2015-05-07 09:37:10.3730,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items?ParentId=f9fab157d4560491931c013390327c16&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&years=&format=Json,32, 2015-05-07 09:37:10.4130,Info,,Subdued - GetRecursiveChildCountString for 'Battlestar Galactica (2003)' took 0.17 seconds.,32,2015-05-07 09:37:12.3580,Debug,,Navigating to Battlestar Galactica (2003) item type Chocolate.WholeSeriesFolderModel,1,Application2015-05-07 09:37:12.3580,Debug,,Loading display prefs for \\HOMESERVER-PC\TvEnded1\Battlestar Gallactica,1,Application2015-05-07 09:37:12.3630,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/873c1bbb-994b-faa3-1d23-1b535426de1a?format=Json,28,Worker thread for Common 2015-05-07 09:37:12.3630,Debug,,Loading display prefs for \\HOMESERVER-PC\TvEnded1\Battlestar Gallactica,1,Application2015-05-07 09:37:12.3980,Debug,,Sending Http Post to http://192.168.10.5:8096/mediabrowser/DisplayPreferences/f63033ff6886ecc7083a696cbeced1b0?userId=87d2924f1a0a122212d5b98e0f6d9d3b&client=MBC&format=Json,1,Application2015-05-07 09:37:12.4030,Debug,,GoToPage: resx://MediaBrowser/MediaBrowser.Resources/Page,1,Application2015-05-07 09:37:12.4330,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Localization/ParentalRatings?format=Json,1,Application2015-05-07 09:37:12.5470,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/dee6f5b0-0bb3-cfb3-b078-11f90b447467?format=Json,27,Worker thread for Common 2015-05-07 09:37:12.5480,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items?ParentId=dee6f5b00bb3cfb3b07811f90b447467&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&years=&format=Json,18,Worker thread for Common 2015-05-07 09:37:12.5480,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/3fa9fc89-3fb2-347b-d615-81c95375cde3?format=Json,16,Worker thread for Common 2015-05-07 09:37:12.5480,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/ba0f4b3c-ca93-15c4-31d3-2a6a7cb0a8c6?format=Json,28,Worker thread for Common 2015-05-07 09:37:12.5480,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items?ParentId=3fa9fc893fb2347bd61581c95375cde3&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&years=&format=Json,29,Worker thread for Common 2015-05-07 09:37:12.5480,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items?ParentId=ba0f4b3cca9315c431d32a6a7cb0a8c6&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&years=&format=Json,30,Worker thread for Common 2015-05-07 09:37:12.5490,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/f9fab157-d456-0491-931c-013390327c16?format=Json,31,Worker thread for Common 2015-05-07 09:37:12.5490,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items?ParentId=f9fab157d4560491931c013390327c16&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&years=&format=Json,25,Worker thread for Common 2015-05-07 09:37:12.5770,Debug,,Forced Refresh of UI on Season 1 called from: <Queue>b__3,18,Worker thread for Common2015-05-07 09:37:52.5670,Error,,Error getting response from http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items?ParentId=ba0f4b3cca9315c431d32a6a7cb0a8c6&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&years=&format=Json ( Exception. Type=System.Net.WebException Msg=The operation has timed out Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.ApiInteraction.MbHttpClient.Get(String url) ),30,Worker thread for Common 2015-05-07 09:37:52.5670,Error,,Error getting response from http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items?ParentId=3fa9fc893fb2347bd61581c95375cde3&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&years=&format=Json ( Exception. Type=System.Net.WebException Msg=The operation has timed out Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.ApiInteraction.MbHttpClient.Get(String url) ),29,Worker thread for Common 2015-05-07 09:37:52.5670,Debug,,Forced Refresh of UI on Season 3 called from: <Queue>b__3,30,Worker thread for Common2015-05-07 09:37:52.5670,Debug,,Forced Refresh of UI on Season 2 called from: <Queue>b__3,29,Worker thread for Common2015-05-07 09:37:52.5670,Error,,Error getting response from http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items/f9fab157-d456-0491-931c-013390327c16?format=Json ( Exception. Type=System.Net.WebException Msg=The operation has timed out Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.ApiInteraction.MbHttpClient.Get(String url) ),31,Worker thread for Common 2015-05-07 09:37:52.5670,Error,,Error getting response from http://192.168.10.5:8096/mediabrowser/Users/87d2924f-1a0a-1222-12d5-b98e0f6d9d3b/Items?ParentId=f9fab157d4560491931c013390327c16&sortBy=&CollapseBoxSetItems=False&fields=Overview,,Path,,ParentId,,DisplayPreferencesId,,DateCreated,,IndexOptions,,DateLastMediaAdded,,Metascore,,MediaStreams,,SortName,,Taglines,,MediaSources,,SpecialEpisodeNumbers&ImageTypes=&recursive=False&genres=&Ids=&studioIds=&ExcludeItemTypes=&IncludeItemTypes=&ExcludeLocationTypes=&personIds=&personTypes=&years=&format=Json ( Exception. Type=System.Net.WebException Msg=The operation has timed out Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.ApiInteraction.MbHttpClient.Get(String url) ),25,Worker thread for Common 2015-05-07 09:37:52.5670,Debug,,Forced Refresh of UI on Season 4 called from: <Queue>b__3,25,Worker thread for Common2015-05-07 09:37:52.6670,Info,,Subdued - GetRecursiveChildCountString for 'Season 1' took 0.00 seconds.,32,2015-05-07 09:37:52.6870,Debug,,Keep alive call,, IsCurretntlyVisible=True,1,Application2015-05-07 09:37:52.7270,Info,,Subdued - GetRecursiveChildCountString for 'Battlestar Galactica (2003)' took 0.00 seconds.,32,2015-05-07 09:37:52.7270,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Localization/ParentalRatings?format=Json,1,Application2015-05-07 09:37:53.0570,Info,,Subdued - GetRecursiveChildCountString for '12 Monkeys' took 0.00 seconds.,32,2015-05-07 09:37:53.3070,Info,,Subdued - GetRecursiveChildCountString for 'Battlestar Galactica (2003)' took 0.00 seconds.,32,2015-05-07 09:37:54.4470,Info,,Sending Http Get to http://192.168.10.5:8096/mediabrowser/Localization/ParentalRatings?format=Json,1,Application
ebr 16334 Posted May 7, 2015 Posted May 7, 2015 It would be helpful if you tested with Chocolate as I have no idea what is going on in some of the other themes but, here is the basis of the problem: 2015-05-07 09:37:52.5670,Error,,Error getting response from http://192.168.10.5:...rs=&format=Json ( Exception. Type=System.Net.WebException Msg=The operation has timed out Src=System Method=GetResponse Line=0 Col=0 [n] StackTrace= [n] at System.Net.HttpWebRequest.GetResponse() [n] at MediaBrowser.ApiInteraction.MbHttpClient.Get(String url) ),30,Worker thread for Common Your server is not responding with what should be a simple list of children for an item in any reasonable time.
DarkKniyt (John) 6 Posted May 7, 2015 Author Posted May 7, 2015 ebr, here's the log file using Chocolate. Basically the same issue. Thanks again for all your help! MBClassic-7520157712de6b590e4178bd7f41d4fc8ee608.log
DarkKniyt (John) 6 Posted May 7, 2015 Author Posted May 7, 2015 OK, have another update to this. I decided to load MB-Classic on the same PC as EMBY-Server. Using both the Chocolate and Subdued Themes, I had NO ISSUES!! What the HEL*! I can only assume that this is a network issue and not EMBY-Server or Classic. ebr, if you have any thoughts (or anyone else) i'd appreciate it! Solidus28, could you tell me if you are running Classic from a seperate PC or the same box that you're running EMBY-Server from? Thanks All.
solidus28 12 Posted May 7, 2015 Posted May 7, 2015 Separate boxes. Small HTPC in the living room running Emby Classic, server in my office running Emby Server. Both wired with Cat6 into a gigabit Buffalo switch.
DarkKniyt (John) 6 Posted May 7, 2015 Author Posted May 7, 2015 Are you still having Delay Issues? (I'm assuming you are!) If so, could you try running MB-Classic on your server and see if you get delays? I'm also running Cat6 from my server to my htpc via an ASUS gigabit router.
solidus28 12 Posted May 7, 2015 Posted May 7, 2015 Yep, just tried to enter a tv series. I can hear the music from the background video (but can't see the background video), but it's just hung on my list of tv series. I know it will go through in 30 seconds or so. Not sure how to try it on the server, though. I'm running Windows Server 2012.
DarkKniyt (John) 6 Posted May 7, 2015 Author Posted May 7, 2015 OK, I don't think you can run MB-Classic on 2012. I'm using Win7. I'm doing some testing on my network. If I come up with anything i'll post it. Thanks for your help.
