VideoNodes issue with Emby for Kodi 0.1.1
saitoh183
@@marcelveldt
First issue: When creating another profile in kodi the Emby scan creates the VideoNodes under the Master profile. @@Angelblue05 corrected the issue for me and im guessing she will add it to a git pull (see attached file)
Second issue:
With the new way the videoNodes are added, it seems that when you load a second kodi profile the nodes are removed and the only way to get them back for that specific profile is to restart Kodi. Once you restart they are back. If i then switch back to the Master profile, same problem.
the log always indicates after the profile switch:
23:17:18 T:1700  NOTICE: Emby addon -> Error while creating videonodes listings, restart required ?
Full log: http://pastebin.com/DQWyebhp
Utils.txt
Edited by saitoh183
Angelblue05
I've tried and I'm also getting the issue. Maybe we should consider something different than deleting everything and recreating every time a profile loads/kodi restarts.
marcelveldt
I'll look into it later today...
marcelveldt
@@saitoh183
I just pushed version 0.1.3 of the addon to the beta repo. This contains the fix for the videonodes (I hope). Could you please test ?
I'm also going to publish a new beta for my titan skin which builds all the smart shortcuts automatically for the emby video nodes including widgets and stuff
saitoh183
@@marcelveldt
I will test it out as soon as i can
  • Like 1
Angelblue05
@@marcelveldt
I just tested and I'm still getting an error (tags are there):
19:26:51 T:17452  NOTICE: 'NoneType' object is not callable
marcelveldt
@@marcelveldt
OK, thanks, I will investigate further. Will have to create some extra profiles on my testmachine too..
Angelblue05
@@marcelveldt
Yeah, you just need to basically reload your masterprofile via Kodi profile switch so it deletes the nodes and tries to recreate them.
Edited by Angelblue05
Angelblue05
This is fixed in 0.1.4.
Guest
