Script error after 0.1.1 upgrade
tropicaljoe
I auto upgraded to the latest version of the plugin and all of my clients now get a "script error" log is attached. Does the sever version need to be at a certain level for this? My Emby Server version is 3.0.5572.0 and I am using Windows 7 sp1 with Kodi 14.2 RC2 and the latest spmc on a fire tv with the same result. I tried from scratch on both and recieve the same error regardless
kodi.log
  • Like 1
marcelveldt
Yes you need to be on the latest server version as the server has been adjusted to work with the kodi sync
  • Like 1
tropicaljoe
Thanks very much, I will upgrade tonight and give it a spin
Guest
