Kodi emby v0.1.0 addon problems on pi
Go to solution Solved by bluc,
Got the new version of emby kodi installed first let me say fantastic job on building library super fast and I see it also adds file in background the same way kodi does great work. Ok so straight forward install on pc no problems what so ever so far but on the pi/openelec I cant get anything to play, the library builds ok( and super fast at that about 10 minutes down from 2+ hours) . Any tips tricks to get it working I tried to rebuild the database like I had to on old .33 but still no luck. Anything I have to enable disable?
Here is my log file help much appreciated..
http://xbmclogs.com/pvx9iyazz
Edited by bluc
  • Like 1
I am using millhouse nightly openelec builds for the pi. I went backwards a few builds and is now working so all good will wait a few days before updating again.
marcelveldt
Ok, thanks for sharing your solution! This may help other users
After more testing it seems it only the #504 build causing problems. I am on #503 on two devices and they both work flawless :) will wait for next build and skip 504 and see what happens.
Edited by bluc
  • Like 1
  • Solution
Tried todays build #0505 and all good just yesterdays build it was glitching on by the looks.
  • Like 1
Guest
