michael_sutherland 0 Posted May 3, 2015 Posted May 3, 2015 Hi All, Spent the last couple of days trying to set up Emby on a Radxa Rock. So far i have done really well. Found a lot of bumps in the road having to compile a lot of Emby dependencies from scratch. I will post all my steps on here as soon as i am finished but i have come across two errors and was hoping somebody could help. When i start emby on the radxa over ssh i recieve the following two errors: #ERROR 1 Error, ImageMagick, Error loading webp: *** Error Report *** Version: 3.0.5597.1 Command line: /opt/mediabrowser/MediaBrowser.Server.Mono.exe -ffmpeg /root/bin/ffmpeg -ffprobe /root/bin/ffprobe Operating system: Unix 3.0.36.0 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /opt/mediabrowser/ProgramData-Server Mono: 4.0.1 (tarball Tue Apr 28 12:05:30 UTC 2015) Application Path: /opt/mediabrowser/MediaBrowser.Server.Mono.exe no encode delegate for this image format `PNG' @ error/constitute.c/WriteImage/1167 ImageMagickSharp.WandException at ImageMagickSharp.WandCore`1[imageMagickSharp.MagickWand].CheckError (Boolean status) [0x00000] in <filename unknown>:0 at ImageMagickSharp.MagickWand.SaveImage (System.String path) [0x00000] in <filename unknown>:0 at Emby.Drawing.ImageMagick.ImageMagickEncoder.TestWebp () [0x00000] in <filename unknown>:0 I have tried installing webp but the error still persists... #ERROR 2 Error, HttpServer, Exception loading certificate: /opt/mediabrowser/ProgramData-Server/ssl/cert_9c31b7884ea5475c8687970fc5996297.pfx *** Error Report *** Version: 3.0.5597.1 Command line: /opt/mediabrowser/MediaBrowser.Server.Mono.exe -ffmpeg /root/bin/ffmpeg -ffprobe /root/bin/ffprobe Operating system: Unix 3.0.36.0 Processor count: 4 64-Bit OS: False 64-Bit Process: False Program data path: /opt/mediabrowser/ProgramData-Server Mono: 4.0.1 (tarball Tue Apr 28 12:05:30 UTC 2015) Application Path: /opt/mediabrowser/MediaBrowser.Server.Mono.exe Input data cannot be coded as a valid certificate. System.Security.Cryptography.CryptographicException at Mono.Security.X509.X509Certificate.Parse (System.Byte[] data) [0x00000] in <filename unknown>:0 at Mono.Security.X509.X509Certificate..ctor (System.Byte[] data) [0x00000] in <filename unknown>:0 at System.Security.Cryptography.X509Certificates.X509Certificate2.Import (System.Byte[] rawData, System.String password, X509KeyStorageFlags keyStorageFlags) [0x00000] in <filename unknown>:0 at System.Security.Cryptography.X509Certificates.X509Certificate2.Import (System.String fileName, System.String password, X509KeyStorageFlags keyStorageFlags) [0x00000] in <filename unknown>:0 at System.Security.Cryptography.X509Certificates.X509Certificate2..ctor (System.String fileName) [0x00000] in <filename unknown>:0 at SocketHttpListener.Net.EndPointListener.LoadCertificateAndKey (System.Net.IPAddress addr, Int32 port, System.String certificateLocation) [0x00000] in <filename unknown>:0 InnerException: System.IndexOutOfRangeException Array index is out of range. at Mono.Security.ASN1..ctor (System.Byte[] data) [0x00000] in <filename unknown>:0 at Mono.Security.X509.X509Certificate.Parse (System.Byte[] data) [0x00000] in <filename unknown>:0 Any help would be much appreciated Mike
michael_sutherland 0 Posted May 3, 2015 Author Posted May 3, 2015 Just for clarification: the Radxa Rock Specs are as follows: Model: ROCK PRO(Mid 2014) CPU: ARM Cortex-A9 quad core @ 1.6Ghz Memory: 2GB DDR3 @ 800Mhz Storage: 8GB Nand Flash, Micro-SD SDXC up to 128GB GPU: Mali400-mp4@533Mhz, OpenGL ES 2.0 Digital Video: HDMI 1.4 up to 1080p@60hz Analog Video: AV output Network: LAN 10/100M Ethernet port WIFI: 150Mbps 802.11b/g/n with antenna Bluetooth: Bluetooth 4.0 Audio: S/PDIF, headphone jack USB HOST: 2 USB 2.0 standard A type Serial: Serial Console for debugging IR Support: self defined IR remote So far i have compiled the following from scratch: Mono SQLite3 MediaInfo ImageMagick FFMpeg with all required encoders Operating system is Debian Wheezy everything seems to be running ok except the two errors. Emby still runs but experiancing issues when performing some tasks on the web interface. i have extracted emby to /opt/mediabrowser the one thing i havent done is create a mediabrowser user/group and set the file/folder permissions. is this required?? (that may sound dumb) Many thanks to anyone that can help
michael_sutherland 0 Posted May 4, 2015 Author Posted May 4, 2015 Thanks (if that's not sarcastic, lol) Any help on the errors?
Luke 42242 Posted May 4, 2015 Posted May 4, 2015 you'd have to give more info about the problem you're experiencing
michael_sutherland 0 Posted May 4, 2015 Author Posted May 4, 2015 Intermittent crashing causing the rada to actually reboot. Does emby keep a log? Where is it?
thefirstofthe300 292 Posted May 6, 2015 Posted May 6, 2015 The cryptography exception is generally seen when using Mono 3.2.8. If you are using that version you will want to upgrade to Mono 3.6 or higher (but 3.12 is NOT recommended due to bugs that were introduced in that version of Mono). The ImageMagick exception seems to mean that you don't have ImageMagick compiled with PNG enabled. What is the output of "convert -list configure"?
